Old 11-09-2008, 04:58 PM   #1
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
Default wideband. Help!!!!!
just wondering. What will the number be off by if the sensor is installed after the cat?
breezeby is offline   Reply With Quote
Old 11-09-2008, 05:23 PM   #2
06Limited
Member#: 118112
2006 WRX Limited
No way to tell for sure. A lot of it has to do with what kind of cat is on the car. Best place for the WB is 8-32" after the turbo but before the cat.
06Limited is offline   Reply With Quote
Old 11-09-2008, 07:57 PM   #3
quazimoto
Member#: 70395
It will probably be off.
Old 11-10-2008, 07:40 AM   #4
breezeby
Member#: 132658
07 TR vf39ed
Its a highflow cat
Old 11-10-2008, 06:12 PM   #5
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Most tuners (and dynos) put a removeable WB02 sensor in the tail-pipe during tuning/logging/dyno. I have compared my LC-1 directly behind my turbo to a WB02 in the tail-pipe and there was almost no difference in actual AFR - however, there was a definate difference in response.
At a constant throttle, AFR is almost exactly the same, a quick stab of the throttle will show the difference in response - and the WB02 in the tail pipe felt about half a second behind.
Saying that, many reputable tuners have and still do tune with the WB02 in the tail-pipe, so it can't be as bad as it is perceived to be - can it?
wrxsti.l is offline   Reply With Quote
Old 11-10-2008, 07:04 PM   #6
breezeby
Member#: 132658
07 TR vf39ed
Yeah I wish someone would just test it after the cat and before the cat. But I guess I am just getting the o2 bung welded on the DP
Old 11-11-2008, 06:00 PM   #7
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
I have tested before and after the cat and have found EXACTLY the following... No difference in reading, but there IS a difference in response time...
gto7419 is offline   Reply With Quote
Old 11-11-2008, 06:24 PM   #8
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Make sure to mount it at least a 8-10 inches behind the turbo. Wideband sensors read off and can be damaged when they get really hot. Inovate recommends, with their kits, if you have to place the sensor close to the turbo that you either buy there heatsink bung which is about $90 or make a heatsink out of copper sheet metal to go on the sensor. Overheated sensor are not just a problem with their kits it is a universal issue. You can go to Inovate's website and find the instruction manual for any of their kits. They all have a section about this heat sink.
FourOnTheFloor65 is offline   Reply With Quote
Old 11-11-2008, 06:27 PM   #9
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Same - perhaps I wasn't clear enough in my post?
Old 11-12-2008, 08:18 AM   #10
breezeby
Member#: 132658
07 TR vf39ed
yeah i think i am getting a bung welded tomorrow on the DP and i am going to put it about 12 inches away from the turbo or maybe a little more but not to far away.
and i just thought that the cat would ruin the sensor that is why i have been asking
Old 11-12-2008, 06:45 PM   #11
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Mine is in the bung that was already in my dump-pipe. It is only about 6" from the turbo and works flawlessly
Old 11-13-2008, 08:10 AM   #12
breezeby
Member#: 132658
07 TR vf39ed
yeah you went off subject but that's cool
i was just trying to find out if anyone has tried the wideband after the CAT but i have found out from what people are sayin that it just has a time delay
well saving a little bit of money and time for a time delay if fine with me
and maybe down the road i will end up getting a bung welded on my DP
Old 11-13-2008, 04:49 PM   #13
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
I find the same. I have an aps turboback the bung by the turbo is too close for permenent installation. So I have a bung welded alittle farthur down stream. I use the tail mounted innovate mount when i tune on the dyno and if i need the wideband on the street.
robbieshonda is offline   Reply With Quote
Old 11-13-2008, 11:38 PM   #14
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Based upon the feedback in this thread, it seems like it's just a time delay issue. If that is the case, why not consider installing the wideband in the stock REAR O2 sensor position.
Then run the narrowband output to the stock harness.
mickeyd2005 is offline   Reply With Quote
Old 11-14-2008, 08:42 AM   #15
breezeby
Member#: 132658
07 TR vf39ed
yep now i have it hooked up and now i can't get it to log or connect to my computer
any ideas?
Old 11-14-2008, 09:53 AM   #16
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
lol, that's always the way. You finally get it installed and it doesn't wanna play ball
A few questions:
1. Are you using the direct serial plug connection - or a serial-to-usb adaptor?
2. Can you connect to it with LM Programmer (the software comes with the LC-1)?
3. Is it set to "gasolene"?
4. If all the above are ok, what version of RoMRaider are you using to log with?
5. In the RomRaider Logger, did you first go to the "plug-ins" menu and select the LC-1 and it's com port?
6. If yes, did you then select the LC-1 parameter to log it?
7. Try selecting/deselecting the LC-1 parameter a few times, sometimes it takes a couple of turns.
If you did all those things it should work.
Old 11-14-2008, 10:00 AM   #17
breezeby
Member#: 132658
07 TR vf39ed
A few questions:
1--- yes adaptor and installed the adaptor as well
2-- i didn't have the software that cam with it so i have downloaded the log works that came with the LM programmer
3-- yes when logworks comes up it is set to GAS
4-5- the newest version of romraider and i tried to select the comm port for the plug in and it just didn't want to read
6- Yes
7-- i am going to try again during my lunch today but i was just frustrated with it this morning and on my way to work and once i got to work and so i will be trying it later on today
thanks
Old 11-17-2008, 09:14 AM   #18
breezeby
Member#: 132658
07 TR vf39ed
to tell you the truth it doesn't even really seem off time whise
but i could be wrong
how much time delay was it off from?
Old 11-17-2008, 09:15 AM   #19
breezeby
Member#: 132658
07 TR vf39ed
6- Yes
thanks
oh yeah i finally got it to work
i just updated the firmware
Old 11-17-2008, 09:50 AM   #20
gto7419
Member#: 44256
05 outback xt
I was just backing you up!
Time delay appears to be about 3 lines off while logging... Basically, when you're logging, if you close the throttle, you will notice it takes about 3 lines for the afrs on the wideband to catch up to the closed throttle... So, however long that is - YMMV!!!
Old 11-17-2008, 10:32 AM   #21
breezeby
Member#: 132658
07 TR vf39ed
is that when you use log works?
also i haven't tried WOT then just letting off and watching it but then again i haven't done very many logs with it that far back in the exhaust
Old 01-07-2013, 09:33 AM   #22
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I am going to have a AEM Uego installed in my Dp, but Im not going to use the spot already tapped on the do....so after reading, I am assuming to have a bung welded in sayyyy 10in down from where the Dp meets the turbo? Would that be downstream far enough or should I go 12-14in down?
shamrock 05 is online now   Reply With Quote
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
FS : Innovate LC-1 Wideband with XD-Gauge alcoolaid VIC Private Classifieds 0 06-04-2010 04:12 AM
wideband help arco Commercial ECU Reflashes 18 09-18-2007 11:27 AM
wideband help mysticowboy Other Engine Management 1 07-22-2006 03:29 PM
Help with Autronic Wideband O2 (Shiv) Austin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-04-2002 10:32 PM
