#26 |
Member#: 272675
Vehicle:2011 WRX hatch WRB |
#27 | |
Member#: 322385
Vehicle:2006 Civic LX Stage a lot 140BHP |
#28 |
Member#: 174522
South East
Vehicle:08 STI WRB |
08STI. Mine went bad ~40k miles. I had the extended warranty and the dealer replaced the clutch, pressure plate, and throw out bearing.
#29 |
Member#: 299064
Vehicle:2008 Impreza WRX OBP |
If a throwout bearing and a clutch release bearing are the same thing then I had mine replaced under warranty at 50k miles or so. Pretty sure they only swapped out that bearing. I'd have to check my receipt to be sure. Now my clutch is making a DIFFERENT squeaking noise. This one appears to be caused by the brake slave cylinder or something. It's too damn cold out right now to go poking at things to see if the welds are breaking. Here's hoping my pedal assembly doesn't fall on the floor between now and April!
#30 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
LOL at all the people saying "I had mine replaced under warranty while I was still within warranty period so they should fix yours under warranty" when he's OUT OF WARRANTH
#31 |
Member#: 319696
BAIC
Vehicle:2012 Subaru WRX STI DGM |
soooo what are the signs of a bad TOB? (aside from a potentially squeeky clutch)
#32 |
Member#: 52314
South East
Vehicle:2002 PSM WRX 16G-XT '13 500 Abarth |
Noise with the pedal depressed?
And technically isn't the TOB internally lubricated since it's a sealed bearing ![]() |
#33 |
Member#: 268310
Vehicle:2011 STi SSM saloon Church! |
#34 |
Member#: 322385
Other than the squeak, I had a "whirring" sound at 50% clutch travel when the engine's running and in neutral.
