Old 01-01-2013, 11:59 AM   #1
NYp8tBaller07
Member#: 319359
2002 Impreza RS
Default Maple syrup smell
So I have smelled maple syrup twice in the past week. I just got all and I mean all the engine work done about 10k ago. I noticed a possible leak from a hose and was wondering if replacing it may fix the issue.
NYp8tBaller07 is offline   Reply With Quote
Old 01-01-2013, 12:04 PM   #2
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
I know people say coolant has a 'sweet' smell when it gets burned. Although your picture just looks like coolant is dripping onto the timing belt cover. That's just what I can see from your picture.
ManualOverAuto is offline   Reply With Quote
Old 01-01-2013, 12:12 PM   #3
NYp8tBaller07
Member#: 319359
2002 Impreza RS
I'm thinking its getting burned up as the engine warms up and when I drive (first 30 seconds) I smell it. I hope its only a hose issue that I can just replace.
Old 01-01-2013, 12:53 PM   #4
ManualOverAuto
Member#: 304662
Sedona red Pearl
Does that hose leak drip onto the exhaust anywhere?
Old 01-01-2013, 01:12 PM   #5
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Try tightening the clamp and see if that helps if not just replace it, they aren't that much.
alt14 is offline   Reply With Quote
Old 01-01-2013, 01:26 PM   #6
NYp8tBaller07
Member#: 319359
2002 Impreza RS
After
Old 01-01-2013, 01:26 PM   #7
NYp8tBaller07
Member#: 319359
2002 Impreza RS
After looking at it again it seems as though there is a crack in the cover.
Old 01-01-2013, 01:32 PM   #8
NYp8tBaller07
Member#: 319359
2002 Impreza RS
Old 01-01-2013, 01:37 PM   #9
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Replace the hose and the ****ty clamp. Good to go.
Psychoreo is offline   Reply With Quote
Old 01-01-2013, 01:45 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
I hate those OEM clamps. Such a pain to deal with when they're old and crusty.
You probably have a bunch of corrosion under the hose too, take the hose off and clean the sealing areas and replace the clamps. If the hose is over 50k miles old, it's probably best to replace it as well.
Jay
Old 01-01-2013, 01:55 PM   #11
novacivic
Member#: 117980
2005 sti
wr blue
Also remove the hose and clean the metal pipe. Corrosion builds up under the hose and causes leaks
novacivic is offline   Reply With Quote
Old 01-01-2013, 02:00 PM   #12
mattthegeek
Member#: 342131
My old focus did this--My kids would always say they wanted pancakes after riding with me.
mattthegeek is offline   Reply With Quote
Old 01-01-2013, 03:55 PM   #13
NYp8tBaller07
Member#: 319359
2002 Impreza RS
Well I replaced the clamp so I hope that hold me over till I can get a new hose =p
Old 01-01-2013, 07:21 PM   #14
alt14
Member#: 271928
2014 WRX Limited
I've seen a few subaru's with cracks in the cover even places where the accessory belt wore through the cover and they didn't have problems.
Old 01-01-2013, 07:45 PM   #15
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Canadian Spec?
cal_look_zero is offline   Reply With Quote
Old 01-01-2013, 09:44 PM   #16
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
Originally Posted by cal_look_zero View Post
Canadian Spec?
NH8991 is offline   Reply With Quote
Old 01-03-2013, 01:15 AM   #17
CameronMac
Member#: 268843
2001 Impreza Ej22
Canadian Spec?
Nice Coincidentally this Canadian noticed the same thing yesterday. I'll have to check that out! Our coolants 40% Maple syrup, helps with those cold -25 start ups!
CameronMac is offline   Reply With Quote
Old 01-03-2013, 11:04 AM   #18
2005RS2.5
Member#: 342420
That looks like its going to suck...
2005RS2.5 is offline   Reply With Quote
Old 01-04-2013, 01:34 PM   #19
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
I thought that canucks ran maple syrup for your oil, not coolant. Maybe its just burning a little oil.
Replace the hose and clamps and see if the smell goes away. If not, keep worrying and buy more pancakes.
bugeyetex is offline   Reply With Quote
Old 01-10-2013, 05:51 PM   #20
ALX4247
Member#: 336103
2000 Legacy GT
All canadian fluid is maple syrup. Oil/tranny/dif/coolant.
I just replaced my hoses and clamps. I went bulletproof with the Goodyear rubber and Clamp-co T-Bolt Clamp.
there is nothing harder to justify keeping OEM than a subaru hose clamp.
http://www.clampco.com/products/t-bolt-std.asp
ALX4247 is offline   Reply With Quote
Old 01-13-2013, 01:48 AM   #21
Subaru Guy
Member#: 234928
2003 WRX
It's coolant, had my radiator hose blow on my bugeye and it smelled just like it, I was like WTF am I smelling syrup for all the sudden? I was just cruising too.
Pull in the gas station pop the hood.....hello cloud of smoke....hello flatbed tow truck
Coolant everywhere!!!!!!!!!
Subaru Guy is offline   Reply With Quote
Old 01-14-2013, 12:01 PM   #22
shawnhayes
Member#: 330882
Syrup smell in car is ethylene glycol until proven otherwise.
Likely to be the cause of your problem. Replace hose and clamp with good hose and worm clamp.
Shawn
shawnhayes is offline   Reply With Quote
Old 01-15-2013, 01:20 PM   #23
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
When you replace the hose you'll almost surely find hard, green and yellow corrosion buildup between the hose and crossover pipe. Scrape off all the old corrosion with a screwdriver before you put the new hose on or it will leak again.
t3hWIT is offline   Reply With Quote
Old 01-20-2013, 06:52 PM   #24
jules97
Member#: 342996
1997 Impreza Outack
Dark Blue/Silver
Default same issue
I have a 97 impreza outback sport and am having a similar problem in the same spot as you. On mine, I think its the clamp. So I would try replacing the clamp first and if not then possible get a new hose. I just discovered my leak today and smelling it for the last few weeks!
jules97 is offline   Reply With Quote
