Old 12-29-2012, 04:12 PM   #1
twistedmentality
Member#: 276600
2006 impreza 2.5i
Default Lucas Oil help piston slap ?
will lucas oil stabilizer help cold start up piston slap ?
when its cold outside 40*f or colder my engine sounds terrible till it warms up. ive read countless posts about piston slap and the noise being quite common.
ive used lucas oil stabilizer in previous vehicles and was wondering if it would be good for the soob.
thank you.
twistedmentality is offline   Reply With Quote
Old 12-29-2012, 04:20 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
are you serious? do you know how thick that stuff is? please dont buy that crap.
Old 12-29-2012, 04:23 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Nope. Piston slap is not a question of oil viscosity. It's a matter of the tolerance between the cylinder wall and the piston being great enough to allow a miniscule amount of play until heat expansion occurs.
You'd be better off with a block/oil pan heater.
cal_look_zero is offline   Reply With Quote
Old 12-29-2012, 07:23 PM   #4
subi400
Member#: 216984
1996 Impreza outback
Green
Or, simply don't worry about it and just drive your car.... And like someone else said, DO NOT USE the lucas oil stabilizer, just don't...
My 96 2.2 impreza wagon has had piston slap since 121k miles and it has almost 203,000 right now... So, really no need to get in a bunch about this piston slap, ok
subi400 is offline   Reply With Quote
Old 12-29-2012, 07:53 PM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
actually it IS a question of viscosity...as in the oil being too thin and not providing a thick enough film on the cyl walls
this is why using MOST 5w30 oils is a bad idea as they all shear to 20wt and can make this issue worse
i would suggest using a different NOT 5w30 oil
Old 12-29-2012, 08:25 PM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
40F? meh
Don't worry.
Bluefoton is offline   Reply With Quote
Old 12-30-2012, 02:34 AM   #7
GrundleJuice
Member#: 165749
Piston slap is not a product of oil viscosity and any oil cold viscosity had little or nothing to do with the weight it changes to at temp. Oil does not shear down to a lower viscosity when it warms, it just changes due to thermal properties of the oil. If a 30 weight warm oil has properties of a 20 weight then the oil is to blame. Shearing is a result of the oil/additive package not bring up to the conditions.
GrundleJuice is online now   Reply With Quote
Old 12-30-2012, 03:13 AM   #8
Uncle Scotty
OK buy Nates beans
so....the dozen or so subarus that i have encountered that had piston slap on cold start....that i recommended a BETTER, non 5w30 oil to the owner....who then changed the oil and had their piston slap on cold start STOP were just having dilusions and hallucinations
yeah......and i dont think you really understand what is and isnt causing this issue.....or anything about motor oils, either
oh yeah...the other thing is carbon build up on the rings....some seafoan and/or upper cylinder lubricant can help, too
Old 12-30-2012, 09:14 AM   #9
GrundleJuice
Member#: 165749
Ha345
Old 12-30-2012, 12:25 PM   #10
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
You're wrong.
I've had piston slap forever on my Forester. Everytime I switched to a thicker oil such as 5W-40 or 10W-40 from 5W-30, it's gotten WORSE.
FCmaniac is offline   Reply With Quote
Old 12-30-2012, 12:35 PM   #11
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Incorrect sir. If that were the case, piston slap would be a symptom of warm weather where the oil would be less dense upon startup.
The colder it is, the slower the molecules in the oil move, thus making it more dense (Physics 101) and therefore creating a condition resembling higher viscosity. If it were a condition of oil viscosity, piston slap would get worse as the engine got warmer. Not to mention that turboless Subarus really don't tend to shear oil (I ran crap oil for 3k miles on my old 2.2 that I flogged and it still read as a 5w30 when I sent it to Blackstone)
As I said before, it's a condition of tolerances between the cylinder wall and the piston; More so post 1996 after Subaru changed the length of the piston skirts to reduce rotating mass and therefore created less surface area to mate to the cylinder wall. Don't take my word for it though...
The infamous "piston slap"
Summary
Description: Clicking, tapping, or knocking noise eminating from the engine after a cold start. The noise lasts until the engine is warmed, usually 5-15 minutes. The sound may be heard in the passenger compartment.
Affects: 2.5L DOHC engine, particularly from 1997 to 1999.
Diagnosis: The pistons are engineered for operation at temperature. In an effort to save weight in the engine, the piston skirts were shaved down. When the pistons are cool, however, they do not have sufficient contact with the cylinder to keep from 'slapping' or rattling against the cylinder sides. At temperature, due to thermal expansion, the pistons match up properly with the cylinder and do not rattle.
Reported solutions: In some cases, SOA has rebuilt the engine short block, while in others SOA prescribed "countermeasure pistons" with longer skirts that do not slap. Most dealers will initially state the sound is "normal."
Detrimental effects: SOA has said that the noise causes no engine problems or abnormal engine wear; Subaru engine expert CCR Engines of Colorado has said that the engine may experience a 10% reduction in life.
Old 12-30-2012, 01:11 PM   #12
GrundleJuice
Member#: 165749
The 253 shears the crap out of some oils, M1 specifically. The oil weight alone is not a great indicator of how much it has sheared. There is another value, some acronym like HTHP or something, that I cannot remember right now that it's better representation of how much it had sheared. And the reason why piston slap goes away as things warm up is because of thermal expansion of the piston. But I dirges, to avoid turning this into a internet battle of science and experience vs. experience
Old 12-30-2012, 01:32 PM   #13
OldGoat38
Member#: 341773
My '91 Volvo started slapping at 50K miles. It's now at 240K and the slapping is a just a little bit worse. Just drive sensibly when cold and ignore the slap - as long as it goes away when the engine warms up.
OldGoat38 is offline   Reply With Quote
Old 12-30-2012, 01:47 PM   #14
GrundleJuice
Member#: 165749
There are also many examples of high mileage Subarus that have/had piston slap for many of those miles. However, no piston slap is obviously better for the longevity of the engine and the increase wear on the skirts means that aluminum is going into the oil. Unfortunately it's an expensive problem to fix.... errr I mean just pour some 20w30 in. Apparently problem fixed.
Old 12-30-2012, 02:19 PM   #15
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Well that's because M1 is crap, and I wouldn't put it in my 73 ford.
But you voiced what I was saying, how it's a matter of hard parts and not oil that is the cause for piston slap. Damn FHI and their reduction of rotating mass!!! -shakes fist-
Old 12-30-2012, 03:01 PM   #16
twistedmentality
Member#: 276600
2006 impreza 2.5i
Summary
if this is prominent in 97-1999 engines why am i hearing it in a 06 ? are they still using the short skirt pistons ? also i have low millage. i have 55k on my car. Im not trying to start an internet battle of knowledge i am just trying to understand this myself.
thanks.
Old 12-30-2012, 05:36 PM   #17
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
alt14 is offline   Reply With Quote
Old 12-31-2012, 02:31 PM   #18
twistedmentality
Member#: 276600
2006 impreza 2.5i
^^ good videos. i subscribed to his channel.
Old 01-02-2013, 12:44 AM   #19
subi400
Member#: 216984
Green
I have had piston slap in my 96 ej22 phase 1 in just cylinder 4 since 121k miles and the car has 203k miles on it right now. The piston slap actually gets a touch louder once the engine in my car warms up but goes sway once I rev it past 1500 rpms.... In fact, I have seen the bits of material in the oil at times though, but almost can't see it. It's not like a lot but just a few tiny bits though.
Uncle Scotty this is for you... I was using quaker state 5w30 in my 2.2 from 121k miles up to around 178k then I switched to the T-6 5w40 and after 3 or 4 oil changes really only made it smoother after start up and when idling. It DID NOT make the piston slap go away... So oil isn't the one thing that can make a difference...Sometimes a light re-hone and re-ring is in order...
Old 01-02-2013, 02:39 AM   #20
Uncle Scotty
OK buy Nates beans
cupcake.....this was happenin in florida....we aint got a whole lotta winter there
think 50's and 60's.....that is cold weather in florida
so no....piston slap can happen not in winter
and 'density' has NOTHING to do with it and you dont know crap about oil....just like the very vast majority of those out there who THINK they do
