Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-03-2013, 12:31 AM   #26
2fst4you
Member#: 315052
2006 Impreza Wrx
Originally Posted by ToyotaMike View Post
I bought a vf39 with 50k on it for 350 and it had the famous waste gate crack. Crack doesnt matter, most of the ones youll find will have a crack. If it doesn't have the crack you'll pay a lot more for it for really no good reason. I installed the turbo with catless FP, apexi noir exhaust, turbo inlet (put that on that on the must buy list or I can guarantee you'll have a boost leak), sti tmic and splitter, walbro pump and an AEM short ram intake and grimmspeed EBCS. At the time with these parts the car was pro tuned at no limit motor sports by Clark Turner and Dave Brown and the car made 290whp/350wtq on a Dyno dynamics Dyno.
Depending how you drive the car will determine how long the 5 speed will last. I wanted more power so I did 1000cc IDs, 38mm gate and up pipe, ETS TMIC, TGV deletes and a Perrin 3" exhaust and my car is making 360/411 on E85. I drove it around for a few thousand miles and then the clutch started to slip so I put a brand new 07 STI transmission in it...be prepared to spend a few thousand to do the swap...I would say if you don't launch it and Smash the gears that you will be ok with the 5 speed...all depends on the driver.
That's good to know. Ya that's not too bad id like atleast 280-310whp. Ya I rarely launch when I do I slip the clutch only thing I'm worried about is 3rd gear pulls. That's some good.numbers one of these days id like to have 400whp and a sti drive train.
Originally Posted by 06wrx420 View Post
I have a 06 wrx mods are as followed.
cobb ap
lightwight flywheel
cobb lightwight pully
vf39
cobb heat shield
sti tmic
cobb sri with post maf silicone hose and cobb air box
amr 3in hard turbo inlet
PnP intake manifold
TGV deletes
Phenolic spacers 8 mill
Grimmspeed PnP stock exhaust manifold with hi flow crosspipe ceramic coated wrapped
invidia bellmouth downpipe
cobb cat back with a cutout in it.
secondary air pump delete
samco hoses
kartboy short throw kit
gauges I have boost, AEM wideband, oil psi
850cc injectors 38mm EWG and cobb 3 port bcs are going on next week with a etune from IA performance. Cant wait havent drove my car in over 3 months due to a broken foot. Its going to be a huge change.
Should be fun! Any idea what kind of power your laying down?
2fst4you is offline   Reply With Quote
Old 01-03-2013, 01:15 AM   #27
2fst4you
Member#: 315052
2006 Impreza Wrx
This a good deal? Should make as much power as any vf turbo just not sure how quick it spools or falls off. What does the welded shut waste gate do?
http://forums.nasioc.com/forums/show....php?t=2442942
Old 01-03-2013, 01:21 AM   #28
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Force you to spend quite a bit more money on an external waste gate setup.
ProfessWRX is offline   Reply With Quote
Old 01-03-2013, 01:33 AM   #29
2fst4you
Member#: 315052
2006 Impreza Wrx
Ahh got cha. Makes sense im a noob lol. Thanks for the help
Old 01-03-2013, 10:24 PM   #30
2fst4you
Member#: 315052
2006 Impreza Wrx
Found this turbo for sale it's an emusa how does it compare to a vf43 and is it any good?
http://forums.nasioc.com/forums/show....php?t=2443855
Old 01-03-2013, 11:37 PM   #31
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
Slightly larger, similar spool. Overall slightly fatter power band than the VF43. Great turbo, IMO. It doesn't say if it has a 7cm or 8cm turbine housing, which will change its spool characteristics and peak torque.
guroove is offline   Reply With Quote
Old 01-03-2013, 11:58 PM   #32
2fst4you
Member#: 315052
2006 Impreza Wrx
Ok figured it was a stronger turbo but just didn't know if emusa was a good turbo. Anymore input?
Old 03-30-2013, 02:16 PM   #33
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
What did you end up buying
breezeby is offline   Reply With Quote
Old 03-30-2013, 02:19 PM   #34
sc00ter
Member#: 117767
2015 WRX
CWP
I'm curious as well.
sc00ter is offline   Reply With Quote
Old 03-30-2013, 08:10 PM   #35
Lbook
Member#: 351892
2006 STI
Have you put a cold air on it or injectors yet? You'll have to tune it when you do anything, that's probably an easy 20-30 reliable hp.
Lbook is offline   Reply With Quote
Old 03-31-2013, 01:36 AM   #36
DONx3
Member#: 214050
2007 WRX
World Rally Blue
I talked to 3 tuners and 1 said I needed injectors and the other 2 said I am fine with the stockers. I myself felt that I should be fine with the stockers and the vf39 is a stock turbo; I have all the bolts on you can think of. Also, upgrade your fuel pump which is cheap and should help in IDC.
DONx3 is offline   Reply With Quote
Old 03-31-2013, 02:02 AM   #37
Andrewxxcarlson
Member#: 316415
2006 WRX
How would a fuel pump help with IDC's...could help your fuel pump duty cycle...
Andrewxxcarlson is offline   Reply With Quote
Old 03-31-2013, 11:03 AM   #38
breezeby
Member#: 132658
07 TR vf39ed
I run a walbro and vf39 and stock injectors. I think you will be fine
Old 03-31-2013, 11:40 AM   #39
coalslaw
Member#: 324808
2006 IWL Stg2
TD06 turbo is a good match for our 2.5L engines. a good intercooler, ebcs, headers/uppipe and a tune. it should turn out well. keep in mind about cooling because bigger turbo creates more heat. so wrap everything if you can. stock fuel system/air intake is fine. before your tune make sure your maintenance is in good standing.
coalslaw is offline   Reply With Quote
Old 03-31-2013, 12:14 PM   #40
breezeby
Member#: 132658
07 TR vf39ed
I want to get the HTA-71 or whatever it is now. See what I can pull out of that
Old 03-31-2013, 04:21 PM   #41
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
So what turbo are you going with? And you decided to stay with stock injectors?
T_woot is online now   Reply With Quote
Old 03-31-2013, 10:11 PM   #42
coalslaw
Member#: 324808
2006 IWL Stg2
my friend lent me his built STi for a week. its got built 07sti motor, ewg, v7 sti tranny, garrett gt30r, perrin fmic and other perrin supporting mods, race oil pan/cooler, about 386-396hp/lb tq...damn im addicted to it. it drinks like crazy too.
Old 03-31-2013, 10:33 PM   #43
breezeby
Member#: 132658
07 TR vf39ed
Who just lends a car like that? Must be nice
Old 04-01-2013, 11:27 AM   #44
2fst4you
Member#: 315052
2006 Impreza Wrx
Nothing yet but looking at a vf43 or 16g I'm kinda worried about my trans though
Would I notice a cai?
How will just a fuel pump give me more power
Old 04-01-2013, 12:19 PM   #45
breezeby
Member#: 132658
07 TR vf39ed
Upgrading the fuel pump will help when you get tuned. Your tranny will be fine if you drive and shift smooth.
Old 04-01-2013, 03:48 PM   #46
coalslaw
Member#: 324808
2006 IWL Stg2
yeah i know eh...a good friend of mine. my dad called it a "stupid car" lmao
Old 04-01-2013, 07:47 PM   #47
2fst4you
Member#: 315052
2006 Impreza Wrx
Even with the stock turbo? Should hold up to a 16g?
Old 04-01-2013, 08:00 PM   #48
breezeby
Member#: 132658
07 TR vf39ed
No I was mentioning the fuel pump bigger turbos. But I would change it for a VF39 and higher
Old 04-01-2013, 08:31 PM   #49
2fst4you
Member#: 315052
2006 Impreza Wrx
Thinking vf39 or 43 but people say I won't be happy with the gains so now I'm contemplating getting a 16g.
16g would be nice if had for a good price but unsure which one to look for
Old 04-01-2013, 08:49 PM   #50
breezeby
Member#: 132658
07 TR vf39ed
I was happy with my vf39 for a couple of years as a daily driver. I am now looking for a vf48 or hta-71 or 68 for more power now.
