Old 01-02-2013, 09:47 PM   #1
11mikey11
Member#: 328800
2014 STi hatch
wrb
Default Got the WQC-39 Recall, then did these data logs. How do they look?
Hello, I did two different data logs today, and would be grateful if someone would tell me how they look. The first one is the normal wastegate 93oct with the short ram intake http://https://docs.google.com/sprea...3lXMHhPRTVzY3c . The second log is with High wastegate
http://https://docs.google.com/sprea...1llVVZSMUhJX1E
Thank You
11mikey11 is online now   Reply With Quote
Old 01-03-2013, 10:08 AM   #2
Cobb Tuning
Member#: 4803
Thank You
Links do not work for me. What short-ram intake are you running and what is the exact name of the map that you are running?
Bill
Old 01-03-2013, 10:47 AM   #3
11mikey11
Member#: 328800
2014 STi hatch
wrb
Sorry I'm new to this. I'm using the Cobb short ram intake. The first log is Stage1+SF93mtv300
https://docs.google.com/spreadsheet/...TB2NFlDSC1BeEE
The second log is Stage1+sf93mtv300HWG
https://docs.google.com/spreadsheet/...mZfMUk3V0JmQ1E
Old 01-03-2013, 10:53 AM   #4
Cobb Tuning
Member#: 4803
Looks like the first run was done at colder outside temps. You should expect lower boost with colder temps with these cars as the ECU will reduce the target to avoid running of our injector. I think the normal wastegate map is more appropriate for you here, but when it warms up in spring, I would get some additional logs to be sure. Otherwise, logs look good.
Bill
Old 01-03-2013, 10:58 AM   #5
11mikey11
Member#: 328800
2014 STi hatch
wrb
Thank you for the quick reply! Have fun with First Thursday tonight.
