Closed Thread
Old 01-03-2013, 11:08 AM   #1
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
Default need new clutch and flywheel. oem or not?
so i need a new flywheel and clutch at 40k which is weird considering i have not dropped the clutch once since the day i bought it. should i get the oem ones for 800 or should i get aftermarket for around the same price?
eronenris is offline
Old 01-03-2013, 11:23 AM   #2
KD1CA
Member#: 341974
09 WRX
BLAACCKK
I have found an OEM for $400. From autozone
KD1CA is offline
Old 01-03-2013, 11:23 AM   #3
1wrxtra
Member#: 316364
2012 WRX
There's some good information here:
http://forums.nasioc.com/forums/show....php?p=9878792
What do you use the car for? How much power do you/will you have? Some more information could help provide better advice.
1wrxtra is offline
Old 01-03-2013, 12:56 PM   #4
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
it is a DD that i sometimes do a freeway pull with, never tracked it. i plan on staying at ots stage 2 maybe add a top mount and a protune but probably not.
Old 01-03-2013, 03:02 PM   #5
Tripintaz
Member#: 245218
2013 STI Limited
Replace with OEM.
Tripintaz is offline
Old 01-03-2013, 03:12 PM   #6
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
Originally Posted by Tripintaz View Post
Replace with OEM.
thats my plan but just curious, why do you think that is the best option?
Old 01-03-2013, 03:20 PM   #7
BugN0ut
Member#: 326552
02 WRX
From what Ive heard, driveability is basically what it comes down to.
I got the same mods as you, put in the oem clutch and flywheel, took easy the first few hundred miles, but I can let it rip with 0 issues or slips.
Its quiet, easy on my leg in traffic, and easy to drive smooth.
Just my experience.
BugN0ut is offline
Old 01-03-2013, 03:25 PM   #8
leftbraned
Member#: 173364
2003 wrx
you could upgrade to a slightly better clutch but don't get a lightweight flywheel for your dd unless you like drivetrain noise. (from experience)
The oem flywheel filters out a LOT of drivetrain noise, the other downside is that the lighter unit will give your ecu fits of thinking you are having a misfire. The check engine light will eventually turn off but it loves to pop back on - annoying but not dangerous.
I do enjoy the quicker revs - just didn't realize what I'd have to deal with for them.
leftbraned is offline
Old 01-03-2013, 04:08 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. You posted in the wrong forum.
2. Someone posted an EXCELLENT article as to what clutch you need, then you don't read it.
Please be classy. Read what people post and post appropriately.
Unabomber is offline
Closed Thread
