Old 01-03-2013, 10:38 PM   #1
veel86
Member#: 308550
2006 Wrx STi
Default Anti freeze on block
I just noticed that there are puddles of anti freeze on top of the block. From the looks of it it looks like it could be coming from around the knock sensor. Is it possible the sensor could be leaking anti freeze? Or is it not possible?
veel86 is offline   Reply With Quote
Old 01-03-2013, 10:53 PM   #2
ScoobyJD
Member#: 185910
2007 WRX TR
Make sure you clean out all of the coolant that is there and have the car idle afterwards for confirmation on where the leak is. If I had to take a guess it would be the water manifold gaskets.
ScoobyJD is offline   Reply With Quote
Old 01-03-2013, 11:10 PM   #3
veel86
Member#: 308550
2006 Wrx STi
okay thank you for your input. It looks like i'm going to have to take it to the dealer. I've spent two weeks replacing parts on this car and spending a ton of $$$$ sucks. i'm sure most people on this forum know what i'm talking about. You have to pay to play.
Old 01-03-2013, 11:25 PM   #4
emjp4
Member#: 290926
2005 WRX
What year is your car? On older models (might be on new ones too), the plastic end tanks on the stock radiators will develop hair line fractures from the heat cycling. That's my guess anyway.. If you have any pics we could get an idea of any spray patterns that we may be able to see.
emjp4 is offline   Reply With Quote
Old 01-03-2013, 11:50 PM   #5
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Check coolant lines to the upper tank. They dry rot really quick. If its bad cut that part off and reattach. Usually you have enough hose to do it.
sackytar is offline   Reply With Quote
Old 01-04-2013, 12:08 AM   #6
veel86
Member#: 308550
2006 Wrx STi
okay i'll check there. 2006 STi.
