Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 01-04-2013, 12:23 AM   #1
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
Post 2.5l Sti burns oil fast please help
Okay so the other day m 06 Sti started smoking a lot from the exhaust and turned off. I got the car home and saw no oil on the dip stick. All my oil was burnt as soon as I added some oil into the car started right up but burns the oil like crazy. not sure exactly why. What could it be?? I the car doesn't seem okay to drive because the oil is burning pretty quickly and not sure why. Also smoke is coming from the valve that connected the crawsford oil seperator. not exactly sure what the problem could be. Any ideas ?
Last edited by albanhaj; 01-07-2013 at 11:57 PM. Reason: no need for extra info on the car
albanhaj is offline   Reply With Quote
Old 01-04-2013, 06:01 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you blew it up by running it outta oil
what oil...exactly and specifically was in it when you blew it up???
Old 01-04-2013, 07:54 AM   #3
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
I also just gave it an oil change less then 200 miles ago. I dont think I blew it because csr will just turn off if it has no oil and won't allow itself to turn on
Old 01-04-2013, 08:44 AM   #4
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
Wut?
jay25RS is online now   Reply With Quote
Old 01-04-2013, 08:45 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
say wut???
i dont think you know what you are doing.....and if
then its blowed up
Old 01-04-2013, 09:21 AM   #6
mikeythejew
Member#: 141672
07' wrx
Mothballed until winter
Probably a broken piston ring or cracked piston. I hope your mechanically inclined and have the tools. Ridiculously expensive to have repaired at a shop. If you can do a compression test yourself, do so and come back with the numbers.
mikeythejew is offline   Reply With Quote
Old 01-04-2013, 09:22 AM   #7
mikeythejew
Member#: 141672
07' wrx
And if you have a 5 speed transmission behind that engine, that will be the next thing to go.
Old 01-04-2013, 09:27 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Greddy Oil catch can
Optima RED top battery relocated to the rear in the trunk
07 STi trans and drivetrain
Clutchmaster 1000 with the cluthmaster chromeolly flywheel
yeah...no
Old 01-04-2013, 10:08 AM   #9
bboylocob
Member#: 151809
2007 WRX
Its toast. Sorry bro
bboylocob is offline   Reply With Quote
Old 01-04-2013, 10:25 AM   #10
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
car is just burning oil out from exhaust
Old 01-04-2013, 10:27 AM   #11
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
don't think its a big thing
Old 01-04-2013, 10:39 AM   #12
Badler
Member#: 133597
The car does NOT have an oil level sensor. It has an oil pressure sensor that comes on at ~5psi. It's basically useless.
Badler is offline   Reply With Quote
Old 01-04-2013, 10:44 AM   #13
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
Thats what I meant but I never drove car oiless so im okay what u guys think can be??
I have a few ideas but not 100 percent sure
Old 01-04-2013, 10:50 AM   #14
KurtP
Member#: 44836
1999 Fozzy
KurtP is offline   Reply With Quote
Old 01-04-2013, 11:09 AM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
Car has a sensor that knows if it had oil or not so wont turn on if no oil. My problem is could be piston rings vavle seals turbo seal but no sure what could be. I know for fact its not toast. Just trying have idea what it is before send to the shop. I
Oh and a piston ring repair will only cost me about 600 to 800 bucks not to bad hopefully not thought and it just worn valves.
Thats what u meant but I never drove car oiless so im okay haha what u guys think can be??
d0000000000000000000000d....ya got NO as in does NOT have any 'sensor' that knows anything......not
ya gonna have a LOT more damage than just the rings.......think a whole new motor.....if it oil starved ALL the bearings are TOAST...done....NFG....all pau
if it stalled while running and you let it cool and put oil in it and it started and is doing what you say it is
you
destroyed
the
engine
Old 01-04-2013, 11:20 AM   #16
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
The thing is car was sitting for few days after this had happened to me and only cranked as soon as I put oil in it started right up. So who ever says engine is completely toast or blown. Car would start at all. I know its not needing of a new engine worst thing car has is piston rings or a turbo seal. But Im wondering if it can be anything else?
Old 01-04-2013, 11:28 AM   #17
nappingcub
Member#: 222725
2006 WRX
CGM
Since you aren't going to listen to what anyone says, just take it to a shop and have them do the work.
nappingcub is online now   Reply With Quote
Old 01-04-2013, 11:31 AM   #18
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
OP, how old are you?
findurpath is offline   Reply With Quote
Old 01-04-2013, 11:34 AM   #19
bboylocob
Member#: 151809
2007 WRX
Im pretty sure that i have a right and valid say since i, myself have had a blown motor due to oil starvation. My motor was toast. As in all but one head usable. This did not happen during hard driving .it happened while going around the block to my in laws. My motor was always properly maintenance. I just had bad luck that day.
Old 01-04-2013, 11:34 AM   #20
Type2
Member#: 200436
2004 Forester XT
First let's clarify something you don't seem to understand. A blown engine does not mean that it physically is blown up, nor does it mean that it is completely seized either. You can start, run, and even drive a blown engine. It may run for 5 minutes, 5 days, or hell, maybe even 5 weeks. But from what you described every single bearing is scored, melted, bent, and clearly out of tolerance. You heads probably are bad as well. You. Need. A. Complete. Rebuild. That's the most polite way I can think of saying it. Good luck.
Type2 is offline   Reply With Quote
Old 01-04-2013, 11:36 AM   #21
bboylocob
Member#: 151809
2007 WRX
Probl. 16 and his super tuner friends are telling him its nothing. Bc he obviously dont like listening to those who know there stuff or have had personal experience.
Old 01-04-2013, 01:04 PM   #22
tuzzio
Member#: 292532
05 STI
OP is an idiot.
/thread
tuzzio is offline   Reply With Quote
Old 01-04-2013, 01:11 PM   #23
ringlander
Member#: 336100
2011 sti
Since this is the 2nd engine that has blown up due to oil starvation, maybe you should stop changing your own oil.
ringlander is offline   Reply With Quote
Old 01-04-2013, 04:27 PM   #24
albanhaj
Member#: 342487
2002 Subaru WRX
Matte White
Post
i didn't change the oil on it a shop did, i don't think you guys understand fact that car was never driven without oil. car just had a fresh oil change but its recently burning it all. i need is why its being burnt. and its technically only the first engine since the other one was perfectly fine but it was the 2.0 wrx engine. the car just got a oil change 200 miles ago. I understand your point you think the engine is "blown"if it is i don't care my question is what do you think caused it or what else it could be besides blown engine... do you guys only assume the worst on here or something? im amusing the turbo seals and you guys assume a blown engine when it has less then 15,000 miles on it regardless on how much it was beaten on and the car only has 44xxx miles on it... .
Old 01-04-2013, 05:16 PM   #25
bboylocob
Member#: 151809
2007 WRX
Ok understand whether it was driven or not the damage is already done.
