Old 01-04-2013, 12:52 AM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ Built 05 STI with ATP GTX3076 on E85
This is another street monster we built a bit ago that just finished break-in.
Event: Custom Tune/Dyno
Ambient Temp: 50 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2005 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 529whp @ 6000RPM
Peak Torque at RPM: 524ft-lbs @ 4950RPM
Target Boost: 24psi peak
Fuel: E85
Engine/Power Modifications:
EQ Stage 2 Shortblock (CP Pistons, Manley I-Beam Rods)
EQ Stage 2 Heads (valve job, bowl blend, stock cams)
ATP Stock Location GTX3076 with EWG
Tomei EL Header / UP
Tomei full Titanium TBE
EQ Tuning FMIC
EQ Tuning Intake
EQ Tuning Catch Can
ID2000cc Injectors
ID Sidefeed conversion Kit
Aeromotive FPR
Aeromotive 340lph pump with EQ Wiring Kit
Tuned with Cobb Speed Density
This is only at 24psi because the single Aeromotive pump started dropping pressure even with a hardwire kit. We're going to switch to something bigger and turn up the boost.
**** New 2013+ Dyno Calibration ****
Stock 02-05 WRX - 185-195whp
Stock 04-07 STI - 240-250whp
Stock 08-11 STI - 220-230whp
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 01-04-2013, 01:03 AM   #2
Duo
Member#: 38620
2005 Subaru WRX STI
Wow. That thing is a beast.
Duo is offline   Reply With Quote
Old 01-04-2013, 01:08 AM   #3
silverbullet415
Member#: 186457
2010 Subaru STI SE
hey ed? how did this car make 100whp more than mine with the same basic mods and build..just curious
silverbullet415 is offline   Reply With Quote
Old 01-04-2013, 01:14 AM   #4
Airboy
Member#: 72829
2006 WRX
2015 WRX
could be this:
**** Using 2013+ Dyno Calibration ****
Airboy is offline   Reply With Quote
Old 01-04-2013, 01:30 AM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
This is on our new dyno calibration as of 2013 which reads like a Dynojet. Your car would be around 515whp. This car does have a bigger turbo (GTX3076 versus your GTX3071).
Thanks
-- Ed
Old 01-04-2013, 01:34 AM   #6
silverbullet415
Member#: 186457
2010 Subaru STI SE
Thanks
-- Ed
im gonna need a new dyno graph print out lol, when i come in on wednesday !!!!
Old 01-04-2013, 02:28 AM   #7
isca21
Member#: 245029
Finally Dyno jet numbers lol. I'm really starting to finally like this gtx3076
isca21 is offline   Reply With Quote
Old 01-04-2013, 03:38 AM   #8
rasheedn
Member#: 123333
2009 STi
DMG
Wow at only 24 psi!
This is a dynocom right?
rasheedn is offline   Reply With Quote
Old 01-04-2013, 07:55 AM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
How much CF did you add to convert to Dynojet equivalent numbers?
Powerband looks good. I'd be interested to see how the 340 pump does long term, but it sounds like you're going to switch it out anyways. Are you going to try to fit something else into the hanger?
xluben is offline   Reply With Quote
Old 01-04-2013, 09:25 AM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
it looks really good Ed.
Old 01-04-2013, 09:39 AM   #11
KurtP
Member#: 44836
1999 Fozzy
why did you change your correction factor so drastically?
KurtP is offline   Reply With Quote
Old 01-04-2013, 10:09 AM   #12
juanmedina
Member#: 133146
probably because customers complain about their low numbers when comparing cars with similar setups tuned on dynojets etc.
Old 01-04-2013, 10:32 AM   #13
KurtP
Member#: 44836
1999 Fozzy
ah....changing with the times and going from the "heart breaker" to the "sweet heart" calibration.
In Ed's defense he held out for true numbers more than most did, and people around this forum are starting to call their local dynojets and 'wheels-off' variants "heart breakers".
The last people I knew of using real mustang type numbers were Akuma, EQ, and STM. Pretty sure Akuma is on the dynojet calibration now too for the same reason.... I guess, though, if other shops are using the inflated numbers it makes it harder to compete when you say they can make "300" and the other place is saying they can make "350".
Ah well.
Old 01-04-2013, 11:09 AM   #14
PROcede
Member#: 293500
2015 FXT Stage 2
CWP
Ah well.
Exactly! Silverbullet415 and I had this exact discussion about why Ed did this last night. Wish he hadn't since he's been known for lower reading dyno numbers for so long, but as you wrote times have changed.
PROcede is offline   Reply With Quote
Old 01-04-2013, 11:09 AM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by rasheedn View Post
Wow at only 24 psi!
Yep. This is a Dynocom dyno reading with its native calibration with 1.0 CF.
-- Ed
Old 01-04-2013, 11:11 AM   #16
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'm now using a 1.0 CF. I used to have it set at .85 to get mustang numbers.
I have a handful of 340's wired like this with no problems. They've been running around for at least a year. I think we're going to try one of the bigger Walbros on this car.
-- Ed
Old 01-04-2013, 11:15 AM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Ah well.
Yep that's exactly right. I was tired of explaining how dyno's read and why mine is lower blah blah. I'm also tuning a lot of different platforms lately and all those guys just want the big numbers they're used to seeing. At the end of the day I don't care about the absolute numbers, and the bigger numbers make the customers happy. Ultimately my job is to make customers happy, so I finally gave in and changed with the times. It seems there are only 1-2 shops clinging on to the low reading calibrations. I held off long enough and finally decided to make the switch with the new year.
-- Ed
Old 01-04-2013, 11:16 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yes sir. Now we can shoot for the stars with dyno numbers
-- Ed
Old 01-04-2013, 11:19 AM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Back on topic, I'm really liking this turbo a lot. It makes similar power to the old GT3582 but really fills in the powerband before the torque peak. The drivability and transient response are awesome.
-- Ed
Old 01-04-2013, 11:47 AM   #20
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Thanks
-- Ed
Cool. Now I do make almost 400hp on your dyno!
How would your new CF equate to trap speeds now?
Dave D. is offline   Reply With Quote
Old 01-04-2013, 12:59 PM   #21
apetron
Member#: 146874
07 STI Widebody
ETS,Volk,Voltex,Varis
Damn, you keep posting these new ATP GTX series turbos Ed and its making me want to swap out the GT52!
So by my math, my car would now read about 485whp 520 torque on your dyno now??
Matt
apetron is offline   Reply With Quote
Old 01-04-2013, 01:47 PM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Actually closer to 496whp I believe. I'll have to check it out. The nice thing is I can reprint anyone's dyno chart from the past with the new calibration.
-- Ed
Old 01-04-2013, 02:16 PM   #23
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-- Ed
Are they running E85 with the 340?
-- Ed
Why is it that the Subaru community thinks Mustang numbers are "real"? It seems with most other platforms Dynojet are the standard. And Dynojet numbers usually seem to correlate well with manufacturer/SAE crank HP ratings (assuming typical drivetrain losses).
Old 01-04-2013, 02:59 PM   #24
Airboy
Member#: 72829
2006 WRX
2015 WRX
IIRC, Ed's original calibration for the dyno was based matching up results with his road dyno software, which happens to be close the old Mustang results.
Old 01-04-2013, 03:12 PM   #25
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Correct. My old road dyno software came in right at what old Mustang dynos read. That's the only reason I believed those numbers to be more "realistic". But who cares in the end. I do think its odd that Subaru rates the new STI's at 305bhp but they only make about 200whp on the lower reading dynos. To the same degree, however, the 09+ WRX's are rated lower than the STI but make more whp. Manufacturer ratings just don't seem to be all that accurate.
-- Ed
