Old 01-08-2013, 08:59 PM   #51
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Originally Posted by ProfessWRX View Post
If you have tuning software you can easily change the tables of the TCC and shift thresholds to maintain a gear and TCC lockup.
Oooo teach me how to do this on any wrx with any current software! I must be doing something wrong
BlazeRex is offline   Reply With Quote
Old 01-08-2013, 09:10 PM   #52
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Dunno. Must be unmapped if its not common knowledge. I never looked through an auto wrx tune.
Now I have. That's terrible. How do you guys do anything?? Is there that little development for the auto cars??? Not a single trans table.
ProfessWRX is offline   Reply With Quote
Old 01-08-2013, 09:17 PM   #53
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Looks like there's a lot of things you havent done. I can tell you haven't tuned an auto wrx, guess who has?
Old 01-08-2013, 09:21 PM   #54
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Oh don't be bitter.
Old 01-08-2013, 09:23 PM   #55
silvercookie
Member#: 180033
2005 WRX
Calm down ladies.
silvercookie is offline   Reply With Quote
Old 01-08-2013, 09:26 PM   #56
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I'm sorry
Old 01-08-2013, 11:26 PM   #57
SkateAndDestroy
Member#: 133893
JBP 04 Forester XT
PSM 02 WRX Wagon
Hah, I like watching you guys bicker back and forth...
If you wanna lock the converter for dyno purposes etc, you have to make a switch...need the pinouts for the trans first...once you know which wire in the harness that goes to the Trans Control Unit you hook it up to send 12v when you turn the switch on. Just don't turn the switch on at idle . It isn't really good to keep the converter locked during a shift either. I've used this at the drag strip by locking it once I shift into 3rd gear, gains a few mph.
As far as access to trans tables, there isn't enough of a demand for anyone to bother to reverse engineering the ecu logic.
SkateAndDestroy is offline   Reply With Quote
Old 01-09-2013, 02:23 PM   #58
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I'm not used to this wrx world. Proper drag cars are all auto. It's weird coming to a platform where drag racing isn't the dominating performance category. It's a good thing though. Drag racing is a lot of fun but turning is 50x more so. Hence my purchase.
Old 01-25-2013, 12:07 AM   #59
Strider327
Member#: 131280
2004 Impreza WRX
I have no numbers to show. But here is a light launch with a 4eat Hybrid at the time.
Strider327 is offline   Reply With Quote
Old 03-28-2013, 04:40 PM   #60
silvercookie
Member#: 180033
2005 WRX
Well apparently this is what 390wtq and 150+ launches does to a rear diff.
Old 03-28-2013, 07:03 PM   #61
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Don't feel bad. I did that to my r160 diff, although not a 4eat.
shadowmd is offline   Reply With Quote
Old 03-28-2013, 09:48 PM   #62
neo8222
Member#: 311321
2002 WRX STI
and that is why I very rarely ever launch my car.
neo8222 is offline   Reply With Quote
Old 03-28-2013, 11:35 PM   #63
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Looks more like 330wtq worth of damage to me. I need to figure out how to unsubscribe to threads on these mobile apps.
Old 03-28-2013, 11:47 PM   #64
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
If you are putting that much WHP out on the stock 4EAT expect that to die too.
Ask me how I know. And mine is no where near those numbers.
I can't imagine that much power with an IPT trans. That car would be amazing!
WRX_02_227 is offline   Reply With Quote
Old 03-29-2013, 12:11 AM   #65
silvercookie
Member#: 180033
2005 WRX
I have a 2nd trans with ~65k miles being put in out of an 05 wrx. I got the vavlebody done at level10. picked up a new rear diff from jimmydangles on here also.
Hopefully it will last until i stockpile all my 6 speed swap parts.
Stock trans's clutch packs are burnt to ****.
Old 03-29-2013, 10:57 AM   #66
Blackcot
Member#: 186985
wow i am so happy to find this tread !!!!
i curently run a wrx auto trans inmy car with a jdm v9 spec c ecu...
how do you tune your ecu ?
if i leave it in drive it shift at 6800-7000 like a wrx...
and i want it to shift at 8000...
Blackcot is offline   Reply With Quote
Old 03-29-2013, 11:06 AM   #67
silvercookie
Member#: 180033
2005 WRX
Im not really sure how you are doing that.
and a stock wrx motor wont make it to 8krpm safely.
Old 03-29-2013, 11:12 AM   #68
Yellow_turbo
Member#: 5937
2005 Legacy GT
Satin White Pearl
He probably forgot to tell that he have the Engine that fit his ECU
Yellow_turbo is offline   Reply With Quote
Old 03-29-2013, 12:08 PM   #69
silvercookie
Member#: 180033
2005 WRX
Canadians. Sneaky Sneaky.
Old 03-30-2013, 09:35 AM   #70
Blackcot
Member#: 186985
Exactly
Look for blackcot on youtube
I even manage to show the speed in a sti v8 cluster !
The dccd light move with the shift lever !
Old 03-30-2013, 09:37 AM   #71
Blackcot
Member#: 186985
Actualy
Yellow turbo manage to make it work lolll
Old 11-19-2013, 02:00 AM   #72
silvercookie
Member#: 180033
2005 WRX
Just figured i would give a long over due update.
If anyone has any input or questions feel free to ask.
when the weather started to warm up we ran into a single issue.
Every time the wastegate would crack open at low RPM's it would trigger the knock sensor and the DAM would drop and pull timing.
We spent so much time trying to figure out why, and couldn't figure it out.
The only solution that worked was switching to the internal wastegate.
Ran perfectly.
Got it re-dyno tuned and it put down 251 whp, 310 wtq. quite a drastic drop in torque but the car rand perfectly.
I have the external gate back in now with the cold weather and it has been running like a champ.
Now i need another 4 eat due to getting into a accident and the gear lashes got knocked out of whack and the center diff is whining like straight cuts cruising on the highway.
With the stock internal wastegate launching at 15lbs i managed to crack a 4.7 0-60 which is pretty good imo.
Old 10-10-2014, 04:55 PM   #73
silversurfer05
Member#: 366241
2005 05 4eat built
psm
nice! im around 350/350 and just fried the trans after 20k miles of abuse lol, these things last pretty long for stock auto trans
silversurfer05 is offline   Reply With Quote
Old 10-11-2014, 01:55 AM   #74
silvercookie
Member#: 180033
2005 WRX
those are pretty good numbers. Whats your setup?
I have to update this thread quite a bit.
Old 10-13-2014, 01:41 PM   #75
Masters84
Member#: 319235
2005 WRX Blouch 18g
Hey man I have a 4eat ej205 and I'm thinking of a hybrid build how do u like it I have a blouch 18g xt on my wrx with a ton of mods check out my build thread http://forums.nasioc.com/forums/show....php?t=2639773
Does the extra torque limit the down low lag? The blouch 18g xt 8cm is a little lagged with the ej205.
Sent from my SM-N900V using NASIOC mobile app
Masters84 is offline   Reply With Quote
