Old 01-13-2013, 11:55 PM   #1
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
Default 2013 wrx h/u w/subwoofer
what's the best way to hook up a sub and amp to my factory h/u?
fantabulous is offline   Reply With Quote
Old 01-14-2013, 12:06 AM   #2
SlickMoney
Member#: 128517
2012 WRX Ltd 5 Door
Subaru sells a factory Kicker sub/amp if you want to overpay. Though it doesn't sound all that bad in a sedan.
Or you can do a line out converter and use whatever amp/sub you want.
SlickMoney is offline   Reply With Quote
Old 01-14-2013, 08:44 AM   #3
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
As far as the line out converter, is there one you recommend over the other?
Old 01-14-2013, 10:12 AM   #4
luan87us
Member#: 335013
2013 Premium WRX 5dr
Audio Control or PAC.
Old 01-15-2013, 08:13 PM   #5
SlickMoney
Member#: 128517
2012 WRX Ltd 5 Door
This. Audio Control being my first choice.
Old 01-17-2013, 05:07 PM   #6
Sigmoid
Member#: 338595
Depends on the sub, no?
Some subs, especially the powered, under-seat variety like the Sound Ordinance B-8PD, Pyle PLBASS8, Soundstream USB-8A, etc. have speaker level inputs. All you need to do in that case is to connect up a two sets of speaker wires from the back of the head unit and run them to the sub, which is usually mounted under the driver's seat.
On my 2006 Forester, I used the Kenwood KSC-SW1 in that position and it sounded fine, although in my case I had a Pioneer HU and ran RCA cables to carry the signal.
Sig
Sigmoid is offline   Reply With Quote
Old 01-17-2013, 05:13 PM   #7
Molas
Member#: 309163
2012 WRX Premium/Nav
Buy a break out harness from SVDX
Molas is offline   Reply With Quote
Old 01-23-2013, 03:08 AM   #8
Bacillus9
Member#: 342519
2013 WRX Limited
Dark Gray Metallic
I don't think SVXdc has a breakout harness for the Nav HU.
Bacillus9 is offline   Reply With Quote
Old 01-23-2013, 09:45 AM   #9
luan87us
Member#: 335013
He does
Old 01-23-2013, 09:54 AM   #10
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
I've got the oem harness. Subwoofer/amplifier for nav models 08+ if your interested.
