Old 01-05-2013, 09:11 PM   #1
maverick83
Member#: 309577
Default Tune leaner than 14.7
Hi, is there any chance to tune the open loop maps,on a 2011 STI, leaner than 14.7?
Of course just in low loads,where from the factory it comes with 14.7.
I would like to set for example 15 or 15.5 just to save fuel during daily driving at low speed.
With Ecuflash I have seen that with the EVO is possible.
Some of you guys has got a solution for this?
Thanks
maverick83 is offline   Reply With Quote
Old 01-05-2013, 10:17 PM   #2
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Open loop only happens under high load. You def wouldn't want to do that. closed loop it would be possible but the mpg gains would be pretty negligible and probably cause unwanted heat.
Jeffman44 is offline   Reply With Quote
Old 01-06-2013, 08:46 AM   #3
maverick83
Member#: 309577
I've mapped in a way that it goes in open loop even in low loads under certain conditions.
Anyway do you know how to modify the closed loop maps in order to go leaner than 14.7 ?
Old 01-06-2013, 10:09 AM   #4
quazimoto
Member#: 70395
Change the Closed loop AFR target.
quazimoto is offline   Reply With Quote
Old 01-06-2013, 11:38 AM   #5
cowboy_Rob
Member#: 194062
2003 Impreza WRX
If your goal is fuel mileage why would you set it up to go open loop sooner? Closed loop will always be more efficient then open since its being constantly monitored and adjusted on the fly by the ecu
cowboy_Rob is offline   Reply With Quote
Old 01-06-2013, 01:27 PM   #6
maverick83
Member#: 309577
Do you know which is the name of the table to change closed loop AFR target?
Is it CL Fueling Target compensation?
Old 01-06-2013, 01:31 PM   #7
maverick83
Member#: 309577
Believe it or not,is more precise now in maintaining 14.7 than before...
And now it gives less problems with fine learning knock corrections.
Anyway basically in cruise it goes to closed loop quickly than with the oem map.
Old 01-06-2013, 01:37 PM   #8
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I never saw a measurable mileage increase from going leaner than 14.7
Of course its going to be smoother in maintaining AFR in OL, the factory system is designed to jump around a little, plus its always corecting itself up/down.
BlazeRex is offline   Reply With Quote
Old 01-08-2013, 09:48 AM   #9
Jeffman44
Member#: 239072
2005 WRX Wagon
white
So I did a little digging around. The stock way of oscillating the afr actually is because it facilitates a chemical reaction in the cat. Putting it in open loop under low load is going to be fine just raise emmissions. Doesn't solve the original question though.... But I view it from the physics standpoint of conservation of energy. If you are running 14.7:1 you'll be using the full potential of your fuel, same with 15:1 or 16:1 anywhere above 14.7 and you will be maximizing fuel efficiency. Butttt that doesn't account for uncertainty in things like tip in enrichment... Might be worth it.
But yes to change closed loop afr its the 'closed loop fueling target.' Mine was in at 14.47 maybe that is the stock value. I changed it to 14.7 and the car seems to hang around 15.0 mostly. Still doing the oscillating down to 14.6 or so.
Old 01-08-2013, 06:28 PM   #10
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Yes and ECT compensation.
ProfessWRX is offline   Reply With Quote
Old 01-08-2013, 06:33 PM   #11
maverick83
Member#: 309577
Do you have a "closed loop fueling target" table in your ECU?
I just have 2 tables that looks similar to that one and they are compensation tables. But oem they have already many negative values...so I guess I just have to decrease more this values in order to get what I was searching for.
Am I right? ...2011 Sti with 32bit ECU
Old 01-08-2013, 06:47 PM   #12
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Those tables are additive. Meaning negative numbers are below 14.7. You want positive numbers.
Old 01-08-2013, 07:27 PM   #13
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Yea I have that exact table. 16 bit 05 wrx though...
Old 01-11-2013, 09:19 AM   #14
maverick83
Member#: 309577
Thank you
Old 01-11-2013, 12:46 PM   #15
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
To be clear. Clearing out the CL compensation (load and ECT) will make the car target 14.7 full time instead of the 14.2-.4 correct?
endrswrd is offline   Reply With Quote
Old 01-19-2013, 04:56 PM   #16
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Correct
Old 01-19-2013, 11:03 PM   #17
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
I don't think a 2012 sti rom has a cl target afr table, but it should have four "cl fueling target compensation" tables and you have to tweak those to get leaner afr than 14.7:1
alexmartynyuk is offline   Reply With Quote
