Old 01-06-2013, 06:24 PM   #1
CZBugeye2002
Member#: 274892
Issue resolved.
CZBugeye2002 is offline   Reply With Quote
Old 01-06-2013, 09:04 PM   #2
jvallepu
Member#: 325769
My local Subaru shop told me to stay away from cometic HG. Did u use the arp lube? Have you done a block test (for combustion gas in the coolant)?
jvallepu is offline   Reply With Quote
Old 01-06-2013, 09:26 PM   #3
CZBugeye2002
Member#: 274892
Yeah, in hindsight I'd use the oem gaskets. Heads were machined and block checked though. And yes, I used the arp lube on it all. That shouldn't be the problem or I think a leak down test would have shown it with a higher rate of leakage.
Old 01-06-2013, 11:31 PM   #4
CZBugeye2002
Member#: 274892
Where in these motors can water get into oilways other than the head gaskets? I didn't seem to have any additional pressure in my cooling system either.
Old 01-07-2013, 05:23 PM   #5
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Sounds like a cracked head.
Cathexis is offline   Reply With Quote
Old 01-07-2013, 06:13 PM   #6
CZBugeye2002
Member#: 274892
I guess it could be. But even still, my leak down numbers were consistent. I didn't have a weaker cylinder. I would think a cracked head would show additional leakage.
Old 01-07-2013, 11:25 PM   #7
CZBugeye2002
Member#: 274892
Got my lines sorted out. Problems solved.
Old 01-08-2013, 05:47 PM   #8
dead_eye
Member#: 308265
2008 WRX
You could at least leave the information up for the next guy who has problems. Some of us do use the search feature!
dead_eye is offline   Reply With Quote
Old 01-08-2013, 05:57 PM   #9
danger1138
Member#: 279525
04 rex luger!
^^i second that
danger1138 is offline   Reply With Quote
Old 01-08-2013, 06:23 PM   #10
CZBugeye2002
Member#: 274892
Oh, sorry guys. Didn't think this thread had produced many answers, but I'll leave it up.
Old 01-08-2013, 08:32 PM   #11
Elbert Bass
Member#: 283429
There is the lower coolant crossover passage cast into the case halves. It has an o-ring where the two halves meet.
Elbert Bass is offline   Reply With Quote
Old 01-08-2013, 09:06 PM   #12
CZBugeye2002
Member#: 274892
Yeah I'm positive those o-rings were in. That's something I was very cautious about.
Old 01-09-2013, 12:41 AM   #13
wrx1392
Member#: 342331
2003 wrx
blue
make sure you have a oem o-ring in there ,i believe it is orange ....i tried using a oring from the auto parts store....it was a tad too fat ....and i think it kept the block halves from coming together properly....and i spun a bearing in 400 miles on a new rebuild so just a warning guys all those orings in the block are important .....now what gasket sets include all those block orings ,cause the cometic rebuild set i bought from JSC speed did not have them
wrx1392 is offline   Reply With Quote
Old 01-09-2013, 09:16 AM   #14
CZBugeye2002
Member#: 274892
Honestly, I bought an ebay bottom end gasket set and they were all in there.
