Old 01-06-2013, 09:11 PM   #1
muzak
Member#: 101926
06 Subaru WRX STI
Default 2006 STI: Main bearing worn out, best solutions?
2006 STI has roughly 110K miles. Took it in for a service few thousand miles previous, cylinder #2 had broken valve and spark plug. They also did general 100K maintenance (replaced timing belt, water pump, and tune up). Cost roughly 2.8K.
Engine was making noise and took it back. They said the main bearing was worn due to excess pressure from broken valve. They say I need a new engine. Is there any other solution besides a rebuilt or new engine? If not, what would be the best route to go; replace with stock engine and components or upgrade. If upgrade, what should I upgrade and where should I take it? What would the cost be of stock replacement compared to other solutions?
Thanks for the help. I live in the Bay Area, if you could recommend a shop or two I would appreciate it.
muzak is offline   Reply With Quote
Old 01-06-2013, 09:22 PM   #2
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
LIC up in Novato is a great shop. GST in Hayward. I hear Auto HQ is good but have no experience. Same for Speed Element. Start with the first two D they will recommend closer shops if needed
aboothman is offline   Reply With Quote
Old 01-06-2013, 09:34 PM   #3
tanner20
Member#: 327401
2006 STI
If its just a shortblock you need to get you could always just buy a built short block. But first thing is what kind of power are you making or wanting to make in the future. And what is your budget. If your going to be making more power later on or soon. You could order a build street series shortblock from either topspeed or vigilant Motorsports. Both street series blocks can handle up to 440whp (what I was told). A guy I know has the top speed sb and its handling his gtx30r setup quite well. Both these blocks are a pretty good price and sittin around 3000 bucks.
tanner20 is offline   Reply With Quote
Old 01-07-2013, 10:57 AM   #4
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Or a rallispec street spec short block is a great one too.
BlackFighter is offline   Reply With Quote
Old 01-07-2013, 07:01 PM   #5
wrx1392
Member#: 342331
2003 wrx
blue
im wondering how they could hear a worn main bering ???? a rod bearing yes,but a main bearing
wrx1392 is offline   Reply With Quote
Old 01-08-2013, 07:30 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
maybe OP misunderstood what the stealership told him.
Old 01-08-2013, 07:44 AM   #7
sorrowfulkiller
Member#: 170439
I <3 Lamp
excess pressure from a broken valve!? sounds like a load of BS to me.
sorrowfulkiller is offline   Reply With Quote
