Old 01-06-2013, 11:39 PM   #1
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
Default Install advice; ATI Super Damper or Fluidampr
Looking at ATI's product it may not fit so easily and certainly not with the engine in the car.
I'm not pulling the engine again so can anyone comment on the install of either?
Much appreciated.
-Drew
Drew888 is offline   Reply With Quote
Old 01-07-2013, 12:27 AM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'm pretty sure they are both press fit on. I went with the fluidampr because its maintenance free unlike the ATI unit. Both are good though. I installed mine with the ening out so that's all I got.
Old 01-07-2013, 03:41 PM   #3
Drew888
Member#: 6459
^^^Thanks,
I found more info that suggests the ATI is a press fit while the Fluidampr isn't.
Still searching, & calling them later today.
Old 01-07-2013, 09:48 PM   #4
kellygnsd
Member#: 32669
LINK G4 hybrid STi
FYI, the pulley removal and install tools from autozone won't work inserting the Fluidampr. I was able to pull it on with the crank pulley bolt.
It is a slight interference fit but the only tricky part was lining up the keyway as I pulled it on with the crank bolt.
