Old 09-16-2002, 01:05 AM   #1
serious
Member#: 22879
Default Turbo legacy transmission same as wrx?!
HI all- I read that the turbo legacy (usd 91-94 )5 speed manual used the same transmission as the wrx. Is this true? How strong is this tranny? I would like to build an engine up to about 250-300hp. Is this a good choice for a tranny or no?
I'm considering puting this older tranny (from a 92 turbo legacy) into a 96 legacy ls chasis that currently has an auto. Will it bolt right in or will there be issues? What about the axles and the driveshaft?
Thanks
Brent
serious is offline   Reply With Quote
Old 09-17-2002, 12:15 AM   #2
serious
Member#: 22879
N E 1 ?!!
Old 09-17-2002, 05:33 PM   #3
subyteh
Member#: 24703
1992 subaru
Default same tranny
no yhere not the same... the legacy trans has a bolt pattern of four and the wrx has six ok...
subyteh is offline   Reply With Quote
Old 09-18-2002, 03:24 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
during that era yes, the Legacy turbo and impreza WRX V1-4 used the same tranny. there were a few varations but they all had the same basic setups.
Jeremy
Old 09-18-2002, 01:52 PM   #5
serious
Member#: 22879
Thanks for the info!
Brent
Old 09-18-2002, 04:38 PM   #6
stevieturbo
Member#: 20366
The 91-94 legacy MT is the same as used in the impreza.
As for swapping from auto to manual, this is a big enough job. Mechanically its fairly straight forward, but there are wiring issues, once the auto is removed. I have done a converison on a MY00 WRX, but whilst the car is running, all is not as it should be.
Speedo not working, I tried, but havent got it sorted yet.
Car idles at 1500 rpm, again a ecu wiring alteration required, but cant find any details of pinouts for this model.
Also be sure the rear diff corresponds to the front one of the manual box.
From memory, you will need, the entire clutch assembly, including pedal and master cylinder. Flywheel. Propshaft, gear linkage and interior trim surrounds. Gearbox mounting cradle and bolts. Possibly new downpipe as someone said the auto was different???
The manual 5sp isnt renowned for its strength, from any model, be it impreza or legacy
stevieturbo is offline   Reply With Quote
Throttle voltage. Are the first generation Legacy the same as the 93+ WRX or reversed ciper Pre-2002 Factory Turbo Powertrain 4 08-09-2009 01:46 AM
2001 Legacy caliper same as WRX? sean.robb Brakes, Steering & Suspension 0 11-06-2008 11:11 PM
Legacy brake pads - same as wrx? briank Legacy Forum 1 01-21-2006 03:59 PM
2002 RS transmission same as 2002 WRX? Dan_E Transmission (AT/MT) & Driveline 14 10-18-2005 01:26 PM
FS: Saab 9-2X Turbo Lease Takeover $245 a month! - Same as WRX Wagon Ryan92X Private Vehicle 'For Sale' Classifieds 17 06-23-2005 07:17 PM
