Old 01-07-2013, 09:10 PM   #1
randysubie
Member#: 301788
2012 wrx
lr
Default vf 52 lbs?
how much boost can the 2.5 bottom end handle safely
randysubie is offline   Reply With Quote
Old 01-07-2013, 09:11 PM   #2
big18g
Member#: 165872
2005 wrx
black
All Of It
big18g is offline   Reply With Quote
Old 01-07-2013, 09:17 PM   #3
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Originally Posted by randysubie View Post
how much boost can a 52 handle safely
More than you should ever care to run it at. More than your bottom end will approve of. More than would be efficient for making any power than lower boost.
No reason to go to its peak.
The question you want to ask is about your motor, not your turbo.
ProfessWRX is offline   Reply With Quote
Old 01-07-2013, 09:42 PM   #4
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
ive been at 22 psi for 2 years. no issues at all.
424wrx is offline   Reply With Quote
Old 01-07-2013, 09:46 PM   #5
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
30 all day
Slimsti is offline   Reply With Quote
Old 01-07-2013, 10:27 PM   #6
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
On e85 23
smeerone is offline   Reply With Quote
Old 01-07-2013, 10:34 PM   #7
randysubie
Member#: 301788
2012 wrx
lr
what kind of power and mods do you have, how many miles?
Old 01-08-2013, 06:46 PM   #8
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
vf-52 turbo, ptp turbo blanket, tp stage 3.52 tune, grimmspeed ebcs and aos, forge motorsports bpv, perrin catted downpipe, borla catback, tomei el headers and uppipe, perrin cai, perrin tmic, rallitek swaybars, avo endlinks, racecomp/bilstein cup kit with yellow springs, racecomp lowering camber plates, cs style side skirts, jna front lip, kartboy ss, 22b shift knob, rota tarmac3 wheels and re11 tires
never been dynoed. burns no oil. 52k miles today. still on stock clutch and brake pads.
Old 01-08-2013, 07:38 PM   #9
bebesito21
Member#: 176128
5862 ...baby boosted
lost as to the proven power......
dont they teach reading comprehension anymore?
op.....33psi, stock rods, no need for a tune, just get a fuel pressure regulator. let us know how it goes
bebesito21 is offline   Reply With Quote
Old 01-08-2013, 07:56 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
On a small turbo, the turbo regulates it's own boost to some extent. Look at the dyno databases like Cobb or EFI logics. The vf39 / 48 / 52 plots will show boost go up, then taper. On these plots peak power is usually ~16-18 psi, even if the peak boost is 20-25 psi... that's because the turbo ends up running out of flow at high RPM.
So boost only really affects midrange torque. Peak power is going to be the same at any boost level over ~18psi. Running 25 psi in the midrange is possible and even plausible if you tune for it. I know there was a rally guy who wanted max midrange and was tuned with the wastegate welded shut. Not recommended on a stock block, but doable on the right fuel with a built engine.
The max flow of a vf39/48/52 is what it is. "more boost" doesn't equal more power in this situation. Also, the turbo isn't what you need to be worried about, it's the engine.
Concillian is offline   Reply With Quote
Old 01-08-2013, 08:02 PM   #11
yetogetanrs2
Member#: 153106
Don't forget to replace your battery, automatically helps the ecu adjust to the turbo
yetogetanrs2 is offline   Reply With Quote
Old 01-08-2013, 08:02 PM   #12
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
So many replies. The second reply is the only one needed.
Old 01-08-2013, 08:24 PM   #13
randysubie
Member#: 301788
2012 wrx
lr
thanks, so what kind of power can the engine handle reliably? i was thinking of stg3-3.5 w 20-22psi and can anything be done to increase top end power without upgrading turbo
Old 01-08-2013, 08:49 PM   #14
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Reliability decreases as power increases. Just because people get 50k miles on more power doesn't mean its still as reliable. Stock motor? Plan on a new engine if you want to play...
pet3r is offline   Reply With Quote
Old 01-08-2013, 09:03 PM   #15
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
only pretty small gains from stuff like header, external wastegate, etc... In the end you might spend a couple thousand on 5 or 7 HP.
This is why vf dynos are funny, one shop claims 280 WHP and one shop claims 350 WHP and both are maxed out vf turbos on pump gas. People who know what's up realize that this is a difference between dynos know that there's no more than about 20 HP difference in vf setups. People who don't understand how different dynos are will drive themselves crazy chasing the 350 WHP number when their shop uses a lower reading dyno. Variation in dynos is way bigger than the variation of 20 different setups of a given engine+turbo on the same dyno.
Old 01-08-2013, 09:06 PM   #16
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
That's why number hunting is stupid.
Because that 7whp is only peak where the added power under the curve and at non peak points (hey like high rpm!) will show significant gains.
You may gain 7 peak but 20whp 600 rpm higher.
Old 01-09-2013, 12:06 AM   #17
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
22psi PEAK
Probably barely over 15psi by redline.
^This.
And most of them aren't even at 18psi by redline. More like 15-16psi.
But it does depend some on what mods you have (better flow will actually have lower boost at redline).
xluben is offline   Reply With Quote
Old 01-09-2013, 07:58 AM   #18
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
yeah im at about 15-16 by redline. its erics map. you can only push soo much air until its equalized.
Old 01-09-2013, 11:05 AM   #19
Leafy
Member#: 330625
2006 WRX
Just pull the vac line off of the waste gate actuator and find out.
Leafy is offline   Reply With Quote
Old 01-09-2013, 11:26 AM   #20
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
haha! sounds harmless
SenorDucK is offline   Reply With Quote
Old 01-09-2013, 08:26 PM   #21
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I didn't say redline, I said at "peak power"
Peak power will happen at a lower RPM than redline on a vfxx 2.5L.
So we're both correct.
Old 01-09-2013, 09:53 PM   #22
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
You probably don't want to do much more than a downpipe, up pipe, EWG, EBCS, and intercooler on a stock motor. At least if you value reliability. Or you could go beyond and just not tune to the full potential.
drewvdw is offline   Reply With Quote
Old 01-09-2013, 09:57 PM   #23
CatfaceType-R
Member#: 81102
Oof....don't even want to touch this thread with a 10ft pole.
CatfaceType-R is offline   Reply With Quote
Old 01-09-2013, 10:20 PM   #24
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
you said pole.
Old 01-09-2013, 11:05 PM   #25
Back Road Runner
Member#: 60082
2004 Forester STI
On pump gas, you can't make enough power to break the bottom end. You will just blow up the rest of the engine first from knock.
This is such a ridiculously vague thread where 50 answers could be given, and they'd all be correct within their own context.
Short answer is yes.
Longer answer is you're limited by the fuel type in terms of how much boost can be used. Heck, you can throw extra boost and see zero gains if the engine is flow restricted (intake, manifold, cams, heads, up pipe, down pipe, remainder of exhaust, yada yada yada). On 91 octane, you should be able to use around 21psi, give or take. At some point you just won't see more power even if you add more boost. At some point you will find yourself having to cut timing to allow more boost. Eventually you won't see any more torque nor more hp. Torque is fuel type limited. HP is flow limited.
Also, I will HIGHLY suggest you pay money now and take apart the engine and toss in forged pistons. You WILL break piston #4. It will just happen if you plan to continue modding, tuning, and playing with the car. It just happens because #4 runs more timing and is always the first to see detonation. The ringland will fail, and you will need to rebuild the engine. Maybe it's not bad. Maybe you don't need to fix the giant scratch in the block or get metal debris out of the oil. It's just easier and cheaper to be preventative. It's easier to pop pistons out than it is to tear down the whole engine.
In terms of wanting more boost, you should be looking at a couple things: E85 and a different turbo, maybe a GTX3071 or something, you know, something that's designed for high boost applications. The E85 is just cheap race gas, great knock resistance and will allow you to run a good deal more boost and push timing. +100 ft-lbs is pretty common. As long as you have a turbo and supporting engine hardware, that also translates directly to HP gains too. The downside is most folks including you very likely won't have that supporting stuff, so you'll still see mild peak HP numbers due to air flow limits but a big bump in midrange torque.
