Old 01-07-2013, 08:32 PM   #1
02midnightblue
Member#: 266411
2002 wrx
Default Mechanical speedo?
95 impreza L swapped to an 02 Wrx. Will it work if I keep the stock cluster and mechanical speedo. Or do I have to do a dash swap.
02midnightblue is offline   Reply With Quote
Old 01-07-2013, 11:25 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
If you are keeping the L transmission you are fine. If you switch trannies you will have to rewire the speedo to work off the electronic speed sensor.
speedyHAM is offline   Reply With Quote
Old 01-08-2013, 12:36 AM   #3
Ioku
Member#: 164864
95 Impreza coupe
Or you can just unscrew the electronic sender form the WRX trans and insert the mechanical one off your L, did this to my car works fine with the old dash and new trans.
Ioku is offline   Reply With Quote
