Old 01-08-2013, 07:20 PM   #1
impreza07joeh
Member#: 295374
2007 impreza 2.5i
blue
Default O2 sensor signal wire
Hello everyone im trying to find out the color of my signal wire for my o2 sensor on my 2007 impreza 2.5i any thoughts thanks
impreza07joeh is offline   Reply With Quote
Old 01-08-2013, 10:18 PM   #2
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
As your facing the front of the car on the left side of the engine look for two wires, the yellow/orange one is before the cat and the gray is after the cat.
Or are you looking for the wire to hook up a gauge to? If so the stock sensors aren't wide band if that's what you're looking for
alt14 is offline   Reply With Quote
Old 01-08-2013, 10:28 PM   #3
impreza07joeh
Member#: 295374
2007 impreza 2.5i
blue
that is what im looking for. can i buy a wideband that goes in place of the stock o2?
Old 01-08-2013, 10:29 PM   #4
alt14
Member#: 271928
2014 WRX Limited
No, you need to keep the stock one for the car, you can have a shop weld a bung for one in fairly cheap though.
Old 01-08-2013, 10:34 PM   #5
impreza07joeh
Member#: 295374
2007 impreza 2.5i
blue
ok sounds good any good brands/places to find a wideband?
Old 01-08-2013, 10:38 PM   #6
alt14
Member#: 271928
2014 WRX Limited
Bosch, ngk, aem but I'm not sure aem sells it without the gauge.
Getting a wide band gauge with the sensor may be cheaper though
Old 01-08-2013, 11:04 PM   #7
impreza07joeh
Member#: 295374
2007 impreza 2.5i
blue
ok thanks
Old 01-08-2013, 11:25 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
aem makes a UEGO and Innovate Motorsports makes a few options, all of which are quality products. All of the Innovate and the UEGO widebands are compatible with RomRaider in addition to other tuning programs. If you buy the sensor alone, you will need a way to power and control it.
