Old 01-08-2013, 10:38 PM   #1
BerkshireaGuy10
Member#: 337228
Default help* clutch question for my 02 2.5ts wagon
Blew my clutch, a friend of mine has a brand new clutch out of a 98 2.5rs I need to know if I can put it in my 02 2.5ts wagon... Maybe a 98 flywheel match...? Does the tranny spine match a 98..? Help.
BerkshireaGuy10 is offline   Reply With Quote
Old 01-08-2013, 11:25 PM   #2
Tmibiker
Member#: 328048
2002 Impreza 2.5TS
Midnight Black Pearl
I honestly don't think so, but I could be wrong.
I'd be surprised if powertrain components across chassis (GC to GD) are that interchangeable.
EDIT: Nevermind, I'm an idiot. They're the same.
Tmibiker is offline   Reply With Quote
Old 01-09-2013, 12:27 AM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I think they are the same.
Old 01-09-2013, 12:52 AM   #4
subi400
Member#: 216984
1996 Impreza outback
Green
The clutch itself is the same. However, you have two options with the flywheel unless the new clutch comes with one. You can either have your stocker resurfaced with a blanchard grinder or you can get a new flywheel to go with the clutch.
DO NOT PUT the new clutch on the used flywheel, ok
subi400 is offline   Reply With Quote
Old 01-09-2013, 07:56 AM   #5
BerkshireaGuy10
Member#: 337228
So the tranny spine is the same as my ts as the rs regardless of it being (mine) a 02 and the clutch being from a 98
Old 01-09-2013, 07:56 AM   #6
BerkshireaGuy10
Member#: 337228
Ya I would even go as far as getting a lightweight flywheel..
Old 01-09-2013, 08:25 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
When questions like this pop up, I go to www.RockAuto.com and look up the part. They have additional info that will show what year/models the part works on.
You can also verify by looking up the same part for each car and compare part numbers.
One of the biggest differences in Subaru clutches is whether it's a "push type" or "pull type" pressure plate.
Old 01-09-2013, 09:15 AM   #8
BerkshireaGuy10
Member#: 337228
Thanks man, I'm new to the subie world.. I'm a Jeep guy. But I gotta say I'm having some fun with the Wagon in the snow.
Old 01-09-2013, 02:19 PM   #9
BerkshireaGuy10
Member#: 337228
Should I match 98 clutch with up to 01 flywheel?
Old 01-09-2013, 09:56 PM   #10
subi400
Member#: 216984
Green
The 98 new clutch will work if you get a new 2001 fly wheel or have the other one resurfaced.
