Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 03-06-2013, 10:45 AM   #276
bonky
Member#: 220806
2004 Honda
S2k
Originally Posted by kevin85193 View Post
Price: I'd like to stick to < $1400 . If it goes over.. whoops.
Goal: Wheel gap gone.
I also ordered a JNA wagon lip if that counts for anything.
Front struts & mounts are pretty much brand new(doh!)
I'm not tracking my car. It's staying my DD. I would like it as comfortable as possible.
Instead of 235/45R17's I put on 215/45R17's so it wouldn't rub.
Heard good things about feals. You can get a set of BC coils. I think you'll be find with the springs it comes with. Fortunes are nice, built better than bc coils but if they dont usually sell coils for your setup, there is a chance they might get the spring setup wrong.
You can also look into getting some racecomp springs. Not sure how low you want to go but it drops about 10-15mm. This would be a good setup since you have new struts.
bonky is offline   Reply With Quote
Old 03-06-2013, 11:28 AM   #277
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
yeah, I think I might just run springs for now since I have new struts in front. Either swift's or mach v's. All I have to do is change to rear 04-07 strut mounts for the mach v''s & saggy butt spacer.
I'm not looking to drop it a lot.. just enough so it doesn't look like my car is lifted
mach v's
1" front 3/4's Rear
kevin85193 is offline   Reply With Quote
Old 03-06-2013, 11:33 AM   #278
bonky
Member#: 220806
2004 Honda
S2k
mach v's
1" front 3/4's Rear
Make sure they're ok for stock struts. A lot of the springs on the market will blow out the strut due to incompatibilities with the valving.
Old 03-06-2013, 11:57 AM   #279
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
I know the mach v's are. Not sure on the swifts
Old 03-06-2013, 12:54 PM   #280
Jive Turkey
Member#: 219492
honestly, go with Mach V's. dan knows his stuff and tey are a great shop/vendor. when you order make sure to ask for somekind of ridiculous drawing in the comments section
Jive Turkey is offline   Reply With Quote
Old 03-06-2013, 01:20 PM   #281
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
I messaged Dan & asked his opinion. He suggested Mach V's, hah. Someone is selling a set of mach v's.. so we'll see.
Told him I had a <1400 less budget.. and said just to get the springs until your struts go out.
Now do I go group N rear mounts or just 04-07 wrx.
Old 03-06-2013, 02:00 PM   #282
Rocko15
Member#: 218771
'13 STi
ISM
Between normal WRX mounts, and Group N's...I'd just go with a 6spd swap
What's the price difference, and what are you getting for the added cost? Are you really going to adjust your suspension that often? Or is it just ease of alignment on install?
Rocko15 is offline   Reply With Quote
Old 03-06-2013, 02:07 PM   #283
Jive Turkey
Member#: 219492
honestly its not like you can adjust camber with the rear top hat, so you might as well get the OEM to maintain a softer more quiet ride. however Group n still isn't completely solid so its a good upgrade that will last a long time. i think the price is negligeable between them, just go group N.
Rocko, if oyu say you're coming to a meet, and then no show up again, i'll find you and i will kill you
Old 03-06-2013, 02:15 PM   #284
bonky
Member#: 220806
2004 Honda
S2k
did you get new top hats with your new struts? If you did just use them till they go bad. If not, you could upgrade.... or just use the old stock ones till they go. Why fix something that is not broken but if you are, that new part better be damn good.
Old 03-06-2013, 02:18 PM   #285
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
04-07 $52each
Group N $100each
Old 03-06-2013, 02:18 PM   #286
Jive Turkey
Member#: 219492
what eddy said, if your stockers are still good then jut reuse them, no need to upgrade especially since this is street driven you wont feel any kind of gains. no reason to piss money away!
Old 03-06-2013, 02:18 PM   #287
Rocko15
Member#: 218771
'13 STi
ISM
I have a very particular set of skills...
I never said I was DEFINITELY in for greasetrucks. Just that I might be.
Old 03-06-2013, 02:19 PM   #288
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
the fronts are new(keeping them like that) the rears are old.
i'll just go with OEM 04-07
thanks for your help dudes.
Old 03-06-2013, 02:21 PM   #289
Jive Turkey
Member#: 219492
now is it just old, or are they shredding? honestly just buy stock for the rear, spend that 50$ that you saved by doing whiteline rear subframe bushings...or any other whiteline bushing like the steering rack bushings or something.
and AZP installs is a whiteline distributor so they will get you the best deals!
Old 03-06-2013, 02:29 PM   #290
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
they are old. I can't use my stock mounts for the mach v springs. I have to use 04-07 Sedan mounts to make the springs work.
Old 03-06-2013, 02:43 PM   #291
Jive Turkey
Member#: 219492
in all honesty, just get stock...
Old 03-06-2013, 02:52 PM   #292
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
I will. Now just have to sell a few things & I'll be on my way, lol.
Old 03-06-2013, 02:55 PM   #293
Jive Turkey
Member#: 219492
i know that feel bro
Old 03-07-2013, 11:43 AM   #294
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
Got a good deal on used Mach V springs from a guy on here. I was going to wait until I sold some things.. but can't pass up a good deal :0
Old 03-08-2013, 07:57 PM   #295
wutdadilyo
Member#: 53967
2011 WRX Premium
Satin White Pearl
Hey i need some advice from all of u. I just got a brand new spt boost gauge from someone for real cheap and want to mount it on my cluster hood. I don't like how it is mounted when u get it installed from the factory so I was thinking either the SMY gauge cluster hood or the zero sports single gauge pod mounted to the left side of my OEM cluster hood.
Both look great but the SMY cluster hood is cheaper and does look more OEM but I don't like how the left side could block the engine temp portion. Let me know what u guys think
wutdadilyo is offline   Reply With Quote
Old 03-08-2013, 11:29 PM   #296
bjkeed21
Member#: 247029
2010 WRX Hatch (02C)
Proletariat
I have the smy. Honestly you still see the temp needle, just not the point. I bet if you had it, youd be more annoyed at how the left pod is in a slightly off angle because of the temp concerns. Annoys the crap out of me that the gauge faces dont end up even.
bjkeed21 is offline   Reply With Quote
Old 03-08-2013, 11:52 PM   #297
wutdadilyo
Member#: 53967
2011 WRX Premium
Satin White Pearl
Would I be able to see how it looks in your car? I havent seen anyone with this type of cluster in our cars yet and with gauges so that I have an idea of how it would look to me
Old 03-09-2013, 11:51 PM   #298
90crxfreak
Member#: 318642
2012 WRX Premium
90crxfreak is offline   Reply With Quote
Old 03-09-2013, 11:59 PM   #299
bonky
Member#: 220806
2004 Honda
S2k
Originally Posted by 90crxfreak View Post
looks good to me! I assume stage 1?
Old 03-10-2013, 12:09 AM   #300
90crxfreak
Member#: 318642
2012 WRX Premium
picked up an AP for 440
