Old 01-09-2013, 02:42 PM   #1
rushdylan
Member#: 337170
2003 wrx
Default Highly controversal technique for rebuild
I've seen lots of this technique for motocross but none for cars. this is what we like to call, the 'dry' rebuild. dry meaning, no oil! but whoa whoa, you might be thinking 'what?! this guys gonna rebuild his motor with no oil?!' not so fast, what I'm referring to is, the bottom end will have oil/assembly lube and so will the cams/valves, except the pistons and cylinders have no oil. this is done in an attempt to keep from a glazed cylinder to promote the BEST cylinder to ring seal as possible. I've been doing this type of rebuild for years on motocross bikes and my personal bike revs to 13,500rpm with 14.2:1 compression! so don't think this is for the ole mower. I can't tell you with facts if this works to seal better than if you coated the pistons and cylinders with oil but why wouldn't it? because of my recent purchasing of a wrx, I've never gotten into a car motor before besides the rebuild of my ranger so I never really did a dry rebuild on a car. my main worries would be the longer oil passages which would take slightly longer to move oil than my dirtbike would. what is everybody's I lnput? maybe some of you have even done this already. I already know this is going to explode with people freakin out about not using oil but come on now, it's gonna get oil before it gets hot enough to cause damage. now lets get this figured out!
rushdylan is offline   Reply With Quote
Old 01-09-2013, 02:58 PM   #2
Leafy
Member#: 330625
2006 WRX
Is your bike a 2 stroke by chance? If its a 4 stroke and you have oil in the crank case and oil in the cams, you're going to have the oil pump running and you'll have going to the cylinder walls. And if you're just talking about dry assembly of the pistons into the bore, the oil is just added to make it easier to put them in and to make sure they're lubed on the first crank.
Its well documented the best way to break in a 4 stroke car engine, and it must be the best way since F1/NASCAR/raceboats/pro level drag/etc break in their engines. Alternating cycles of high load and high vacuum pulls from low rpm to an rpm limit that slowly gets high as the pulls go on. Pro's do it on the dyno, you can do it in 3rd gear in a large abandoned parking lot, abandoned airstip, closed highway, etc. Engine is assembled with breaking lube, pro guys make their own special concoctions. Oil choice is the big controversy and I've never seen anything mentioning what the NASCAR/F1 engine builders use, I bet we never will. IMO it shouldnt matter, though something with a high zinc content would be preferred and something synthetic.
Leafy is online now   Reply With Quote
Old 01-09-2013, 02:59 PM   #3
Evo-killr
Member#: 252905
2002 Fully Built Wrx
gon rotated psm
hmmm.. im all ears to other peoples opinion and experience
Evo-killr is offline   Reply With Quote
Old 01-09-2013, 06:40 PM   #4
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I install pistons dry. Just a coat of ATF on the cylinders after cleaning and some wd40 on the tapered ring installer.
Crystal_Imprezav is offline   Reply With Quote
Old 01-09-2013, 07:18 PM   #5
ILikeBeans
Member#: 173053
As do I.
ILikeBeans is offline   Reply With Quote
Old 01-09-2013, 07:48 PM   #6
jchafee
Member#: 238453
05 05 WRX
I've always assembled my motocross pistons dry as well. Have yet to do it in an auto application. I will on my upcoming build though. What brand tapered ring compressors are you guys using? And are they as much more effective than a clamp style as they seem?
jchafee is offline   Reply With Quote
Old 01-09-2013, 08:00 PM   #7
rushdylan
Member#: 337170
2003 wrx
my bike is a 4 stroke. and yes you are right, there is oil in the crankcase and oil in the head where the cams/buckets are. however, my cylinders are brand new and cleaned, if not, they are honed and cleaned with a solvent to remove any type of oil. a brand new piston should have no oil and if it does, ill clean it too, i even wipe down the rings. the whole point is to get the rings to seal and set in as good as possible for those 2-3 seconds that the oil has yet to hit the piston from an oil jet. im a little confused with your post, were you saying that f1 and nascar do a dry rebuild as ive described?
Old 01-09-2013, 08:02 PM   #8
rushdylan
Member#: 337170
2003 wrx
i dont see what could be different? my 250f engines always come apart looking awesome and always have great compression! i just wish i had hard proof that this was better, but i dont. however, i dont see why it cant hurt to take ALL measures to increase seal and especially on a boosted engine!
Old 01-09-2013, 08:03 PM   #9
Leafy
Member#: 330625
2006 WRX
They may or may not do a dry rebuild. But do you not prime the oil pump before the initial startup?
Old 01-09-2013, 08:33 PM   #10
jchafee
Member#: 238453
05 05 WRX
The point behind this is to keep the top and second ring dry so they wear into the cylinder walls immediately. Those two are what do the bulk of the sealing. So in theory, if the rings are installed dry, they will remain dry but the skirts will get splashed, provided the oil control rings do their job. Regardless of priming the oil system.
Old 01-09-2013, 09:26 PM   #11
rushdylan
Member#: 337170
2003 wrx
in a way, but you cant neccesarily "prime" an oil pump in a dirtbike. sure, it could prime itself before it finally fires up if ive kicked it 3-5 times. if i split the cases and all oil has drained from all oil passages, i will rotate the crank to get some juices flowing
Old 01-09-2013, 10:15 PM   #12
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
I always use the dry method
woodys77 is offline   Reply With Quote
Old 01-09-2013, 10:22 PM   #13
rushdylan
Member#: 337170
2003 wrx
awesome! this is going over much easier than it has in the past on other forums. ive had people explain how idiotic i am
Old 01-09-2013, 10:42 PM   #14
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I have and always will use marvel mystery oil(like atf) when installing pistons,back when I was building some of the fastest gsxr and hayabusa motors in the country thats how I did the cylinders and the performance spoke for itself.
john 1badSTI is offline   Reply With Quote
Old 01-09-2013, 11:07 PM   #15
rushdylan
Member#: 337170
2003 wrx
well, looks like thats working for you! my dad gave me his busa after he crashed it and quit. i decided to get rid of it too and got me a f250 as straight across trade. pretty sweet deal! just curious, what 1/4 were they doing?
Old 01-09-2013, 11:27 PM   #16
k mier
Member#: 98000
05 sti [email protected]
You're an IDIOT!
Feel better now?
k mier is offline   Reply With Quote
Old 01-10-2013, 12:10 AM   #17
rushdylan
Member#: 337170
2003 wrx
Originally Posted by k mier View Post
You're an IDIOT!
Feel better now?
just like ole times
Old 01-10-2013, 12:11 AM   #18
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
I mean, as soon as you crank the engine the sleeves get oil!
ckyguy68 is offline   Reply With Quote
Old 01-10-2013, 05:03 AM   #19
k mier
Member#: 98000
I've always used a light coating of two stroke oil on the cylinder wall of all my mx rebuilds, two and four stroke. If you follow the proper break in procedure everything will seal without problem.
Back in the day when mx cylinders were cast I'd read several articles, (way before internet), that supported a bike broken in hard and fast would be a faster bike. I would assume that also applies to plated cylinders. Only difference, back then if you foo'bared a top end job you simply went to the next size, today if you mess up it's a $500 cylinder.
Old 01-10-2013, 01:09 PM   #20
rushdylan
Member#: 337170
2003 wrx
I've always rebuilt and raced. by that I mean, I slapped in a top end and then hauled ass! I once read in motocross action that you should 'treat your dirtbike like a chainsaw, open the box and cut wood' what they meant was, start it and ride it hard to get them rings to seal. I do a dry rebuild and ride it hard too! being totally honest, my top ends last longer than my friends who has the same exact bike. who knows
Old 01-10-2013, 05:07 PM   #21
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I'm not for or against at this point. Still thinking about it.
What I'm wondering is the longevity. In your situation you're refreshing something like once or twice a season. For our typical customer they are looking at rebuild once or twice a lifetime.
What I would like to know is while I can see that it would mesh the walls and rings very quickly what are the long term aspects?
Old 01-10-2013, 05:47 PM   #22
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
But the sleeves/cylinder walls aren't pressure oiled, are they? I guess if the rods are notched to spray the cylinders/pistons...or you had oil squirters.
Otherwise the sleeves are splash oiled. So you still have a few seconds of "dry" time to seat the rings.
Or I'm missing something, which is very possible.
tachrev is offline   Reply With Quote
Old 01-10-2013, 06:15 PM   #23
ckyguy68
Member#: 316296
2006 STIROID
Oiling holes in the pistons feed the oil rings which in turn leave a coating of oil on the cross-hatching on the cylinders. The oil rings 'wipe' away the excess but the cross hatching retains a certain amount.
They would be dry until the engine built oil pressure which you should always do before you fire it.
Old 01-10-2013, 06:20 PM   #24
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Amen to that
after a couple times, or a trans fail, 90-95% would have to call it quits putting 5k + labor each time into a 25-30k car probably only worth 15k in good condition at the time of it blowing
Irv Weissmanhowerton is offline   Reply With Quote
Old 01-10-2013, 06:47 PM   #25
woodys77
Member#: 192147
2007 STI EfiLogics
Your not understanding how oil gets to those holes though...
