Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 01-10-2013, 03:39 PM   #1
Rev Works
Vendor Sales Rating: (12)
Member#: 305656
05 STi
Default Drivetrain Deals. A Pedal feel for everyone. A shift so smooth, LIKE BUTTA!
We're proud to offer tons of options to meet your drive train needs. Whether it's a simple bushing upgrade or an OS Giken Clutch and Diff setup. We've got you covered. Check out just some of the options that we have available.
Southbend DXD Clutch Kits:
Stage 1 HD Clutch Kit:
South Bends' DXD HD Clutch Kit is a great kit for anyone looking to retain an as close to stock type feel. These clutches utilize a full face, sprung hub, organic carbon disc. You can expect smooth engagement, moderate pedal pressure increase and very minimal noise.
The kit has a torque capacity rating of 456 ft. lbs so it will hold up very well on a tuned, bolt on, STi. A 500 or so mile break in is required.
http://www.revworksinc.com/South-Ben...Ti-_p_665.html
South Bend Stage 2 Clutch Kit 04+ STi
The DXD Stage 2 Clutch Kit offers something for everyone with some power! These clutch kits utilize South Bend's high performance pressure plate. You can expect a moderate increase in pedal pressure but with dual spring hub, various friction surface options and this pressure plate, you have a clutch that will hold some serious power and last!
Disc Options:
Daily
The Stage 2 Daily kit utilizes a woven, carbon kevlar friction surface with a spring hub. This kit is rated at 495 ft. lbs or torque so it's really able to hold up to a well built, STi. This kit will allow for very smooth engagement, minimal noise and great street manners.
Endurance
The Endurance kit really stands out in the world of STi clutches. This dual friction kit features the same carbon kevlar from the daily kit on the pressure plate side of the disc so that you get smooth engagement and feel but features a segmented iron surface on the flywheel side to hold up to extreme levels of heat. This is the kind of clutch that can last you a very long time and is rated to 565 ft. lbs. This is a clutch that we'd suggest with a serious street car.
Drag
When some chatter and quick engagement is not on the list of cares, this is the clutch for you. With a torque rating of up to 600ft. lbs, this clutch is designed to hold up to the aggressive demands of hard and fast shifts. It does retain a sprung hub so it's equipped to be as pedal friendly as possible.
Please be sure to select the kit that you want and we encourage you to contact us with any questions that you may have. We'll gladly talk you through picking the proper clutch.
http://www.revworksinc.com/South-Ben...STi_p_668.html
South Bend Stage 3 Clutch Kit 04+ STi
The DXD Stage 3 clutch kits by South Bend offer aggressive clamp loads for superior torque capacity. These clutch kits pair a modified pressure plate with three disc options to meet most driving and performance demands.
Disc Options:
Daily
The Stage 3 Daily kit utilizes a woven, carbon kevlar friction surface with a spring hub. This kit is rated at 590 ft. lbs or torque so it's really able to hold up to a well built, STi. This kit will allow for very smooth engagement, minimal noise and great street manners.
Endurance
The Endurance kit really stands out in the world of STi clutches. This dual friction kit features the same carbon kevlar from the daily kit on the pressure plate side of the disc so that you get smooth engagement and feel but features a segmented iron surface on the flywheel side to hold up to extreme levels of heat. This is the kind of clutch that can last you a very long time and is rated to 615 ft. lbs. This is a clutch that we'd suggest with a serious street car.
Drag
When some chatter and quick engagement is not on the list of cares, this is the clutch for you. With a torque rating of up to 695ft. lbs, this clutch is designed to hold up to the aggressive demands of hard and fast shifts. It does retain a sprung hub so it's equipped to be as pedal friendly as possible.
http://www.revworksinc.com/South-Ben...STi_p_670.html
We'll be adding a lot more! Let us know if there is something else that you are looking for. We'll do what we can to get you taken care of.
Marti
__________________
[COLOR=Red][I][B]
-[/B][/I][/COLOR][COLOR=Red][I][B] We will not be beat on price![/B][/I][/COLOR][COLOR=DimGray][COLOR=Black][U]
Phone[/U][/COLOR]-407.542.7[COLOR=DimGray]863[/COLOR][/COLOR]
[COLOR=DimGray][COLOR=Black][U]Email[/U][/COLOR]
[/COLOR]
Rev Works is offline
Old 01-11-2013, 06:52 PM   #2
Rev Works
Member#: 305656
05 STi
Torque Solution Short Shifter 02-07 WRX / 00-04 Legacy
Torque Solution short throw shifter is a direct replacement for your long throw stock unit. Our shifters are made from 4130 Chromoly steel and are tig welded in a precision jig. These are then Black Nickel plated to ensure they last for years. This unit comes with the shifter pivot bushing as pictured for a more solid shifting feel.
Features:
32% throw reduction
1.25" height reduction
4130 Cr-Mo steel
Installs in under 30 minutes
Lifetime Warranty
Made in USA
http://www.revworksinc.com/Torque-So...acy_p_655.html
Kartboy Short Throw Shifter Subaru 2004-2013 STi
This Kartboy Short Shifter replaces the stock shift lever in 2004+ Subaru STI. Overall shift throw is decreased by 40%, providing a noticeable difference and a solid feel. The Shift knob height will also drop 1" as well. Constructed of CNC'd and TIG welded 4130 Cr-Mo steel. It will install with simple mechanic's tools in under 30 minutes.
All Kartboy Products are Hand Made in USA and are 100% Guaranteed.
http://www.revworksinc.com/Kartboy-S...STi_p_497.html
Cobb 6 Speed Shift Knobs
Looking for that interior upgrade that will look and perform great, but not break the bank? Look no further, the Cobb Shift knob is constructed of delrin and has been shaped to fit perfectly in the palm of your hand. It features a billet aluminum base that is anodized in your choice of red or blue. The Cobb logo is also machined into the base so people know what shift knob you rock! This is a direct replacement and screws right on to the shifter.
http://www.revworksinc.com/Cobb-6-Sp...obs_p_304.html
We have these and more great drivetrain parts available to improve your drive. Cleaner, shorter shifts make for a much more pleasurable driving experience and we're all about getting the most joy of out your drive.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 01-14-2013, 12:00 PM   #3
Rev Works
Member#: 305656
05 STi
Help clean up your shifts with Torque Solution bushings. We offer great prices, same day shipping and great bundle prices on these parts with clutches, flywheels, shifters and more. Message me today with any questions that you may have.
Torque Solution Shifter Bushings STi & Legacy GT (6spd)
Torque Solution continues to push the limits of high performance aftermarket products with our "NEW" Shock Factor Shifter Bushings. Developed to perform under the most extreme conditions, Shock Factor Shifter Bushings bridge the gap between ordinary rubber and cheap plastics used in current aftermarket shifter bushings by offering a unique Urethane specifically chosen by Torque Solution engineers to ensure product performance and reliability while drastically reducing shifter end play allowing for crisper, more precise shifts. All this makes it easy for us to stand behind our shifter bushings with a lifetime warranty.
Street or Track Shock Factor Shifter Bushings will always get you in gear!!!
• Improved 60fts / e.t's
• Installs in under 30 minutes
• Eliminates excessive Shifter play
• Solid feeling in gear change
• Street and track torture tested
• 95A durometer polyurethane
• Life Time Warranty
• Made in USA
http://www.revworksinc.com/Torque-So...spd_p_545.html
Torque Solution Rear Shifter Bushing
Torque Solution Shift Tight replaces the stock rear shifter mount bushings.While this product will not change the geometry of the shifting mechanism, it eliminates excessive play in the system for a more solid shift. This bushing is made from lifetime warranty 75A durometer polyurethane. The same proven materials used for 10 years in the Subaru WRX / STI drivetrain is now available for the BRZ!!!
•Improved 60fts / e.t's
•Street and track torture tested
•75A durometer bushings
•Lifetime Warranty
•Made in USA
http://www.revworksinc.com/Torque-So...ing_p_547.html
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 01-15-2013, 11:12 AM   #4
Rev Works
Member#: 305656
05 STi
Remember, we've got a 5% off coupon on our website that is valid on most product lines. Contact us today about your drive train needs and we'll gladly help you pick the best parts and provide the best prices.
WWW.REVWORKSINC.COM
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 01-17-2013, 11:51 AM   #5
Rev Works
Member#: 305656
05 STi
Default ACT Clutch Kits
We proudly offer the ACT Clutch Kits for all of the Subaru platforms. Their HD based clutch kits offer superior grabbing power with excellent engagement.
Consider carefully which clutch is right for your car. First you need a clutch that will hold all the power, but not too excessive. For street use, you also need a long lasting clutch that has a positive feel, smooth engagement and quiet operation. For racing, you need a tough clutch that will enable quick shifts and hard slips all the way to the finish line.
ACT Heavy Duty Clutch Kit 2002-2005 WRX
ACT Heavy Duty Clutch Kit 2004-2013 STi
ACT Heavy Duty Clutch Kit 2006-2012 WRX
These are great clutches that offer various disc options to meet just about any performance demand.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 01-22-2013, 06:20 PM   #6
Rev Works
Member#: 305656
05 STi
get in on some GREAT DEALS! We're here to work with you and do what we can to earn your business.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 01-24-2013, 02:28 PM   #7
Rev Works
Member#: 305656
05 STi
Have you seen the latest clutch options from our friends at Competition Clutch?
Contact us today for GREAT deals on these clutch and flywheel bundles.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 01-25-2013, 02:59 PM   #8
Rev Works
Member#: 305656
05 STi
Happy Friday, everyone! The sun is shining, the shop is very busy and we're in a great mood. Message me today about how we can help you get a great deal on ANYTHING that you need.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 02-06-2013, 06:07 PM   #9
Rev Works
Member#: 305656
05 STi
How can we help you on this Hump Day?
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 02-11-2013, 02:15 PM   #10
Rev Works
Member#: 305656
05 STi
We install dozens of clutches every month. We can help you pick out the perfect clutch to meet your exact needs. Feel free to PM, email or call me today with any questions that you have.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 02-18-2013, 05:10 PM   #11
Rev Works
Member#: 305656
05 STi
don't miss out on the HUGE tax time savings that we're running!
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 02-21-2013, 05:05 PM   #12
Rev Works
Member#: 305656
05 STi
We've got the best deals around on Exedy and other multi-plate clutch kits.
WWW.REVWORKSINC.COM
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 02-25-2013, 11:29 AM   #13
Rev Works
Member#: 305656
05 STi
We've got great deals on single and multi plate clutch kits. You name it, we got it and we'll do the best we can to get you the best deal possible
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 02-27-2013, 04:57 PM   #14
Rev Works
Member#: 305656
05 STi
Remember to use our 5% coupon to save on a wide variety of application product lines.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-04-2013, 04:49 PM   #15
Rev Works
Member#: 305656
05 STi
We've got drivetrain solutions and components to meet any and all needs. Let us work for you.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-06-2013, 04:30 PM   #16
Rev Works
Member#: 305656
05 STi
Happy Hump Day, everyone! Let us know how we can help you.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-08-2013, 03:06 PM   #17
Rev Works
Member#: 305656
05 STi
Contact us today. We want to help you get the perfect parts at the right price.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-11-2013, 11:10 AM   #18
Rev Works
Member#: 305656
05 STi
We've got ACT, Clutch Masters, South Bend, Exedy and more! All available to save you big money on great products.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-14-2013, 03:06 PM   #19
Rev Works
Member#: 305656
05 STi
We've got tons of options at GREAT prices, guys! Let me know how we can help save you money on the parts you need.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-15-2013, 10:46 AM   #20
Rev Works
Member#: 305656
05 STi
HAPPY FRIDAY, EVERYONE! We're already off to a great start for the day so let us know what we can help you with. We're in the mood to make some deals.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-18-2013, 11:48 AM   #21
Rev Works
Member#: 305656
05 STi
Monday, Monday. So good to me! Hope everyone had a great weekend. Please let us know how we can help you. We're here to save you money on the best parts in the business.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-19-2013, 11:24 AM   #22
Rev Works
Member#: 305656
05 STi
South Bend, ACT, Clutch Masters, OS Giken and more! Let us know how we can help you save on the parts that you need.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-20-2013, 02:20 PM   #23
Rev Works
Member#: 305656
05 STi
It's a very busy HUMP DAY! Let us know how we can help you.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-21-2013, 09:28 AM   #24
Rev Works
Member#: 305656
05 STi
Thirsty Thursday BUMP! Let me know how we can help you.
__________________
[COLOR=Red][I][B]
[/COLOR]
Old 03-22-2013, 11:58 AM   #25
Rev Works
Member#: 305656
05 STi
We offer a complete catalog of clutches to meet all of your driving and performance needs. Let me know how we can help you.
__________________
[COLOR=Red][I][B]
[/COLOR]
Closed Thread
