Old 01-10-2013, 07:07 PM   #1
madSTI
Member#: 38961
2004 wrx STI
JAVA BLACK PEARL
Default Strong Smell of Gasoline in Cabin.
Recently during the winter I have been experiencing a strong smell of gasoline in the cabin upon cold start up. Once the car has fully warmed up the smell disappears.
Whether I park this car outside overnight or in a garage overnight the issue is the same.
Any thoughts as to what this might be?
The car does have 186k.
Any helpful comments welcome.
madSTI is offline   Reply With Quote
Old 01-10-2013, 07:13 PM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Carbon canister needs replacement?
ProfessWRX is offline   Reply With Quote
Old 01-10-2013, 07:40 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
It could be a bunch of things:
Car running rich at start up
Charcoal canister
Cracked/rotted/frozen fuel lines(there was a recall on some older wrx's for this)
Are you catless?
Mike
GrimmSpeed is offline   Reply With Quote
Old 01-10-2013, 07:46 PM   #4
MMaxim
Member#: 314456
Just went through this myself on my FXT. It was a loose fuel line in my case. Simple fix, but time consuming. Had to remove intake manifold.
MMaxim is offline   Reply With Quote
Old 01-10-2013, 09:30 PM   #5
FXTRunner
Member#: 104289
05 Forester
CGM
Had the same thing. I went to the dealer and ended up getting them to split the cost on my gas leak fix.
FXTRunner is offline   Reply With Quote
Old 01-10-2013, 09:40 PM   #6
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
#1 source for this ever is here, check/do this first: http://forums.nasioc.com/forums/showthread.php?t=131755
Old 01-16-2013, 07:16 PM   #7
madSTI
Member#: 38961
2004 wrx STI
JAVA BLACK PEARL
With the exception of the SPT intake it's bone stock. I checked the fuel lines and everything looks kosher. I'll take a look in the link. Thanks.
Old 01-16-2013, 07:21 PM   #8
xthecursex
Member#: 224079
subaru issued a recall on the fuel lines. take it to the dealership.
http://http://forums.nasioc.com/foru....php?t=1893471
xthecursex is offline   Reply With Quote
Old 01-16-2013, 07:23 PM   #9
madSTI
Member#: 38961
2004 wrx STI
JAVA BLACK PEARL
Bad link?
Old 01-16-2013, 07:27 PM   #10
Vart
Member#: 325031
2014 Forester XT
Vart is offline   Reply With Quote
Old 01-16-2013, 07:28 PM   #11
madSTI
Member#: 38961
2004 wrx STI
JAVA BLACK PEARL
Looks like my car doesn't fall into the affected range they recalled. I'll just go ahead with the trouble-shoot method one by one.
Old 01-17-2013, 02:44 AM   #12
Tenament
Member#: 246813
I can't believe people still give advice for this occurrence other than the fuel line problem. Trust me... it's 99.9% certain that it is what Unabomber posted.
Tenament is offline   Reply With Quote
Old 01-17-2013, 02:38 PM   #13
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I can't believe you can't grasp the concept of people not knowing common issues due to an immensely vast variety of possible reasons.
Old 01-18-2013, 07:19 PM   #14
2dino
Member#: 41907
Has the fuel filter / pump in the fuel tank even been removed/ replaced?
If so may be check access panel gasket on top of fuel tank.
GL.
2dino is offline   Reply With Quote
