Old 01-10-2013, 10:39 PM   #1
Pickler
Member#: 301247
09 Impreza 2.5i MT
Default help ignition timing problem
my maximum ignition timing during cruising at 2500rpm keeps changing some days. i can hit 35-38 deg max on one day and 42-45 the other. With the higher ignition timing i get much better fuel economy. Most of the time though my car is in 35-38 deg range. i'm wondering whats causing this drop in timing? i also found that if i restart the car after its fully warm it tends to advance the ignition timing? wtf? anyone has any clue?
09 impreza 2.5i sedan premium 4eat stock 40k miles on the odo. changed plugs at 30k miles with laser platinums.
Pickler is offline   Reply With Quote
Old 01-11-2013, 12:58 AM   #2
GrundleJuice
Member#: 165749
Fuel quality/octane or OAT are the most relevant reasons for ignition timing to change, load, rpm and mixture being the same.
Old 01-11-2013, 05:02 PM   #3
Pickler
Member#: 301247
09 Impreza 2.5i MT
i have been suspecting fuel. i have always used e10 87 octane gas. today on the way home i was averaging 42 degrees whilst yesterday only 35 degrees same route.
i forgot to add that once i noticed ign fall to -1 during cruising and back to 35. happend fairly quickly.
Old 01-11-2013, 07:34 PM   #4
GrundleJuice
Member#: 165749
I know the knock correction logic pretty well but not necessarily the ecu decides what timing table to use for cruise. Pull a learning view screen shot and pull your timing tables also. See if there is knock in the range of cruise where the changes are occurring or maybe you are just in between two cells interpolating and it switches back and forth. Seems like a large change in timing for one cell over on the table, though.
Also, this might be discussed better in the engine management forum.
Old 01-11-2013, 09:16 PM   #5
Pickler
Member#: 301247
09 Impreza 2.5i MT
ok thanks for the help
