Old 01-12-2013, 12:40 AM   #1
Subie_kid
Member#: 255923
2006 impreza 2.5i
Regal Blue Purl
Default 257 block with sohc heads? will it work and what will I need.
Quick question guys, spun a bearing the other day in my 06 2.5I and know someone selling a ej257 short block and I was wondering if I put in the short block with the sohc heads will the whole thing Still be plug and play or will it be throwing codes left and right on the stock ecu? If so what will I need to solve the problem
Subie_kid is offline   Reply With Quote
Old 01-12-2013, 10:46 AM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The CR would be low and it would be a slow dog without changing pistons
Old 01-12-2013, 10:48 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I THINK TWE makes a set of pistons for this.
We're helping a rally team this year move to open class and we're going the opposite way - ej257 bottom, sohc heads, and adding a turbo.
Old 01-12-2013, 12:13 PM   #4
Subie_kid
Member#: 255923
2006 impreza 2.5i
Regal Blue Purl
I really wouldn't care if it was slow as hell, it's just to get it back on the road so I can get to work lol no racing now, leaving for the airforce in March
Old 01-12-2013, 09:54 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you did this you would end up with an 8.9:1 CR, and shouldn't throw any codes, since the car doesn't really care what shortblock you have under it's hood. If you are looking for a stock rebuild, this block is a little overkill for your application.
~Josh~
Old 01-12-2013, 10:35 PM   #6
Subie_kid
Member#: 255923
2006 impreza 2.5i
Regal Blue Purl
~Josh~
Thanks, I know it will be over kill but for the price I am getting this short block it's too good to pass up. Plus I will have one little part of the build bought by the time I get back from basic
Old 01-13-2013, 12:03 AM   #7
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Just go for it. I bet you will be surprised how well it runs. I know a shop that imports DOHC turbo motors from Europe and swaps the short blocks into old Outbacks all the time. They run great.
geronimo81 is offline   Reply With Quote
Old 01-13-2013, 01:10 AM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The tq and hp they make its miserable and the gas mileage is even worse. I'm all about getting some good hardware for a great price but if you pay for the savings in gas over a year it's not really the great of a deal anymore
Old 01-14-2013, 03:33 PM   #9
GEE-OTTO
Member#: 201277
2009 Legacy GT
A 8.9:1 N/A H4 would be miserable lol!
GEE-OTTO is offline   Reply With Quote
Old 01-14-2013, 04:34 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
Did someone actually calculate that 8.9:1 CR or just guess? The 257 and 251 heads do not have the same size combustion chambers......
Jay
Old 01-14-2013, 04:48 PM   #11
ballitch
Member#: 74907
98 cam'd EJ251
I did using 99.5mm bore, 79mm stroke. 51cc heads, 22cc sti pistons, .6mm stock sti HG.
~Josh~
Old 01-14-2013, 06:24 PM   #12
mattmak
Member#: 211128
2005 2.5RS 5MT Sedan
Can anyone say with certainty how much hp and tq going from 10:1 to 9:1 would drop?
There was a build on rs25 where one dude rebuilt with low compression with a plan to eventually add a supercharger. However, before the sc, the car pulled very well on low compression (albeit with full exhaust, delta2000 cams, tune). I remember seeing dyno plots, and the owner saying it was getting full timing (not a big surprise there).
mattmak is offline   Reply With Quote
Old 01-15-2013, 01:48 AM   #13
ballitch
Member#: 74907
98 cam'd EJ251
Usually if you go up or down a full point you gain or lose 4% of your CHP, that is a generic number and fluctuates based on engine/head design etc, etc...
~Josh~
Old 10-10-2013, 01:03 AM   #14
Jr_gosetto
Member#: 361946
06 Impreza RS
I'm thinking of doing a NA build now with a 257 block, 2.7 stroker kit, 11.2:1 CR pistons from TWE, SOHC, a aiming for 11.5:1 CR. how would that fair for power??
Jr_gosetto is offline   Reply With Quote
Old 10-10-2013, 03:35 AM   #15
subi400
Member#: 216984
1996 Impreza outback
Green
So 100mm pistons and a 83mm stroker crank? Add a good EL header and some torque cams and you will have torque for days...
subi400 is offline   Reply With Quote
Old 10-10-2013, 08:01 AM   #16
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
100mm pistons don't give you anything except less room to go bigger down the road when the cylinders need to be bored/honed again... and less money in your wallet. Stock pistons are 99.5mm give or take.
Old 10-11-2013, 12:40 PM   #17
subi400
Member#: 216984
Green
Since that guy is talking about an NA build using that stroker kit, really no need to have more room to bore/hone after doing it for the stroker kit.
It would be a blast though for NA because of the torque...
Old 10-11-2013, 02:06 PM   #18
Jr_gosetto
Member#: 361946
06 Impreza RS
And on further research I have found that the stroker kit only goes to 8.5:1 CR the 2.7 stroker kit recommends a sleeved block (pretty much anything over 100mm should be sleeved) so I would think going up to a 2.6 and does that extra .5 mm make that big of a differance?? And plus any extra bore I'd need to match the head aswell, so it's not to heart wrenching if the .5 makes a differance just meens a little more coin to go towards tuning
Old 10-11-2013, 03:46 PM   #19
subi400
Member#: 216984
Green
That compression ratio is designed around a sti 57cc chambered head. Your heads are in the 50cc range or so. Remember, your power density is much lower than a wrx or sti engine so even if you went with 100mm pistons there is no need to worry about that.
I would do the 83mm crank but with the stock 99.5mm diameter pistons. You would have to get a custom piston though because of the wrist pin height being changed due to the longer stroke.
Old 10-11-2013, 06:07 PM   #20
Jr_gosetto
Member#: 361946
06 Impreza RS
Thanks for the info I didn't even think of wrist pin placement I will get ahold of TWE and see wat they can make up .I found a site that sell a brand new empty 257 case for about 1000 so ill need main studs and oil pan and pistons and the stoker kit and ill be able to start building it just I'm looking at about 6g to build the short block + money into head work so this will be a timely and costly project but should be fun once done
