Old 01-12-2013, 02:19 AM   #1
lj8915
Member#: 329252
2012 Subaru WRX
Default stock HIDs vs H9's in halogen projectors
I love the light output from the h9s in my stock halogen projectors, but I miss the hid look/color. I've read that the factory limited wrx/sti hids aren't that great, so would sticking with my h9s be better (light output wise) or should I spend 600 on some used hid lights?
If anyone has comparison pics, that would be awesome.
lj8915 is offline   Reply With Quote
Old 01-12-2013, 11:40 PM   #2
Irisharse3
Member#: 235328
13 WRX Hatch
You could easily retrofit them for less that half of that.
Irisharse3 is offline   Reply With Quote
Old 01-12-2013, 11:55 PM   #3
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
This is my retrofitted lights, high beams are also on
alt14 is offline   Reply With Quote
Old 01-13-2013, 12:20 AM   #4
lj8915
Member#: 329252
2012 Subaru WRX
I'm honestly scared to retro. Maybe if I could find a cheap set of extra lights.
Old 01-13-2013, 12:32 AM   #5
Irisharse3
Member#: 235328
13 WRX Hatch
Do a month of research and you will be fine. The Retrofit source has made things way too easy nowadays. With the user friendly stuff out there now, I could probably do one in less than 2 hours, where as back in the day it was completely a custom job and could take a few days to weeks depending on the work involved.
Old 01-13-2013, 12:47 AM   #6
lj8915
Member#: 329252
2012 Subaru WRX
Would you guys recommend the morimoto $300 "plug and play kit?
One of my main concerns is alignment. I've heard that people had to open their lights back up after they were done to re align the projector or something. I would hate to do that.
Old 01-13-2013, 01:09 AM   #7
lj8915
Member#: 329252
2012 Subaru WRX
This kit?
http://www.theretrofitsource.com/pro...roducts_id=254
Looks like it's $370. Can I find it cheaper anywhere else? I'm assuming I order the one for "08-11 impreza "?
Old 01-13-2013, 01:12 AM   #8
Irisharse3
Member#: 235328
13 WRX Hatch
I don't have any firsthand experience with those. However I would definitely get the matsu****a ballasts as there is already a mounting base under the headlight for them. They are OEM for the limited and STI. I always mount and test the lights without the lenses prior to resealing them to adjust the alignment if need be.
Old 01-13-2013, 01:15 AM   #9
Irisharse3
Member#: 235328
13 WRX Hatch
Originally Posted by lj8915 View Post
This kit?
I'm sure the ballasts and bulbs can be found cheaper elsewhere if you look around. The projectors and those brackets are TRS only products.
Old 01-13-2013, 01:31 AM   #10
lj8915
Member#: 329252
2012 Subaru WRX
The site says the impreza kit comes with the matsu ballasts.
Old 01-15-2013, 08:40 PM   #11
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Stock STi projector HID retrofit. I spent $380, with 85122+ bulbs, 3Five ballasts, clear lenses, projectors . Easy retro to do (no cutting,drilling).
P.Rico is offline   Reply With Quote
Old 01-15-2013, 08:54 PM   #12
lj8915
Member#: 329252
2012 Subaru WRX
Why would you use the sti projectors if you could have gotten the better Morimoto ones for the same price?
Old 01-15-2013, 09:39 PM   #13
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Better by who's standards? The Mini D2S is a (relatively) weak D2S based system and the Mini H1 is hampered by bulb choice and various issues (solenoid, bulb hotspot centering, etc). I would buy an OEM projector over those any day.
Old 01-15-2013, 09:42 PM   #14
lj8915
Member#: 329252
2012 Subaru WRX
I don't know I'm new to this stuff. I just read various people saying the OEM projector isn't good and the moto is better.
Old 01-15-2013, 10:21 PM   #15
alt14
Member#: 271928
2014 WRX Limited
Not that I'm saying they're bad but I don't really think the sti's projectors are that great, but if you do use them a clear lens would make for a good cutoff
If I were to do it all over again without money being an object i'd get Acura tl projectors with rigid industries dually d2's for high beams
Old 01-16-2013, 07:55 AM   #16
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Photos don't show the whole story usually, but here you go.
More here: http://forums.nasioc.com/forums/show...&postcount=153
Besides the weird bowing that I am still trying to resolve, I see no way that the Mini projectors beat these, besides being bi-xenon and having a curved cutoff shield. The beam is full, wide enough to see everything in the woods left and right, and distance is great. If you spend time making your own curved shields then you really get a great system that rivals many good OEM projectors (RX300, TSX), but I don't have the time for that kind of work.
If I had the time and patience to do another retro (or if I get my hand on some extra reflector housings to play with), I would like to do a TL as well, but the burned bowl issues are worrisome.
Old 01-16-2013, 09:04 AM   #17
alt14
Member#: 271928
2014 WRX Limited
That does look good, I guess I'm just used to my brothers tl projectors for stock lights.
Old 01-16-2013, 11:37 AM   #18
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I would certainly choose the STI projectors over any morimoto too. Like P.Rico said they are a good projector with a few tweaks.
frederik is offline   Reply With Quote
Old 01-16-2013, 01:55 PM   #19
alt14
Member#: 271928
2014 WRX Limited
I haven't read much into them but are normal lenes able to be fit? Like a tsx-r or the sti-r ones to replace the fresnel lens
Old 01-16-2013, 02:01 PM   #20
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Yes, member CarbonXe here used TSX-R lenses (probably from TRS), see his thread:
http://forums.nasioc.com/forums/show....php?t=1948106
edit: Off topic: STI-R a completely different, 3 inch lense, for other applications. actually the STI-R 3 inch lens, which is a replica of the bugeye STI lenses, will not fit at all on a bugeye STi. It is smaller in diameter, but it does seem to have a similar optics. Anyways, the bugeye STI HID lenses are already clear lenses. Their problem is really the bowl aluminium plating quality, so there would be no point in changing the lenses.
Old 01-16-2013, 04:22 PM   #21
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
I used TSX-R lenses like CarbonXe did.
The focal length is 24 mm.
There is another lens that TRS now sells that is 29 mm (black body lens I think it's called). The description says it's also applicable for Impreza headlamps, but I'm not sure what the difference in focal length would do to the focus of the beam. I haven't measured the fresnel lens out of the stock projector to see what the focal length is, maybe I should do that soon.
Old 01-16-2013, 05:38 PM   #22
alt14
Member#: 271928
2014 WRX Limited
I see, thanks for the info.
Old 01-22-2013, 12:09 AM   #23
AFP520
Member#: 102932
2014 STI Sedan
where did you get the parts for yours? They look great
AFP520 is offline   Reply With Quote
Old 01-22-2013, 01:05 AM   #24
alt14
Member#: 271928
2014 WRX Limited
Thanks, the lows are morimoto mini d2s projectors, oem ballasts that Trs sells with it along with 4,300k 35watt bulbs. The high beams are morimoto 35 watt ballasts with 35watt 4,300k morimoto bulbs (re based 9005 hid bulbs) I got everything on Trs for $480 a little pricey but worth it for how much desolate roads I drive at night.
Old 01-27-2013, 09:59 AM   #25
lj8915
Member#: 329252
2012 Subaru WRX
How does lightwerkz sell them if they are a trs only projector?
Reason I ask is because I just bought the projector and brackets from the "retro quik" system off lightwerkz for $100 shipped. Hell of a deal.
Now all I need is d2s bulbs and the d2s adapter for my existing PNP ballasts. No need for a relay right (only 35w)?
