Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-12-2013, 02:19 PM   #1
Eddie at PNR
Member#: 332016
1999 Swapped GM6
Default 05 STI Tuning Problems ECUFLASH
Im having troubles with EcuFlash reading my current rom. I can use Romraider and log fine, however EcuFlash Is not connecting to the car correctly. I keep getting error codes
[13:13:37.185] EcuFlash Version 1.44.3721
[13:13:37.185] OS Version Windows 7
[13:13:37.185] Qt Version 4.8.0
[13:13:37.185] 63 memory models read.
[13:13:37.185] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[13:13:37.465] 611 ROM metadata models scanned.
[13:13:37.465] checksum module "subarudbw" loaded.
[13:13:37.465] checksum module "mitsucan" loaded.
[13:13:37.465] checksum module "mitsuh8" loaded.
[13:13:37.465] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:13:37.465] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:13:37.465] flashing tool "wrx02" loaded.
[13:13:37.465] flashing tool "wrx04" loaded.
[13:13:37.465] flashing tool "sti04" loaded.
[13:13:37.465] flashing tool "sti05" loaded.
[13:13:37.465] flashing tool "mitsukernel" loaded.
[13:13:37.465] flashing tool "mitsukernelocp" loaded.
[13:13:37.465] flashing tool "mitsubootloader" loaded.
[13:13:37.465] flashing tool "shbootmode" loaded.
[13:13:37.465] flashing tool "shaudmode" loaded.
[13:13:37.465] flashing tool "subarucan" loaded.
[13:13:37.481] flashing tool "subarucand" loaded.
[13:13:37.481] flashing tool "mitsucan" loaded.
[13:13:37.481] error loading FTD2XX.DLL
[13:13:37.497] J2534 API Version: 04.04
[13:13:37.497] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:13:37.497] Device Firmware Version: 1.12.3688
[13:13:37.497] Device Serial Number: TAyv9EHc
[13:13:37.497] interface close
[13:13:37.528] J2534 API Version: 04.04
[13:13:37.528] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:13:37.528] Device Firmware Version: 1.12.3688
[13:13:37.528] Device Serial Number: TAyv9EHc
[13:13:37.528] interface close
[13:13:37.559] J2534 API Version: 04.04
[13:13:37.559] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:13:37.559] Device Firmware Version: 1.12.3688
[13:13:37.559] Device Serial Number: TAyv9EHc
[13:13:37.559] interface close
[13:14:25.201] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[13:14:25.217] J2534 API Version: 04.04
[13:14:25.217] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:14:25.217] Device Firmware Version: 1.12.3688
[13:14:25.217] Device Serial Number: TAyv9EHc
[13:14:32.712] kernel get version
[13:14:32.915] interface close
[13:14:32.946] J2534 API Version: 04.04
[13:14:32.946] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:14:32.946] Device Firmware Version: 1.12.3688
[13:14:32.946] Device Serial Number: TAyv9EHc
[13:14:33.399] VIN: JF1GD70645L512954
[13:14:33.523] CVN: 2A0086B4
[13:14:33.617] interface close
[13:14:33.648] J2534 API Version: 04.04
[13:14:33.648] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:14:33.648] Device Firmware Version: 1.12.3688
[13:14:33.648] Device Serial Number: TAyv9EHc
[13:14:33.820] SSM2 init
[13:14:33.960] SSM2 ECU ID is 3D12594006
[13:14:34.038] Requesting Seed...
[13:14:34.085] Sending Key...
[13:14:34.132] interface close
[13:14:34.147] interface close
[13:15:25.900] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_sti05.xml
[13:15:25.916] J2534 API Version: 04.04
[13:15:25.916] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:15:25.916] Device Firmware Version: 1.12.3688
[13:15:25.916] Device Serial Number: TAyv9EHc
[13:15:28.218] kernel get version
[13:15:28.421] interface close
[13:15:28.452] J2534 API Version: 04.04
[13:15:28.452] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:15:28.452] Device Firmware Version: 1.12.3688
[13:15:28.452] Device Serial Number: TAyv9EHc
[13:15:28.904] VIN: JF1GD70645L512954
[13:15:29.029] CVN: 2A0086B4
[13:15:29.123] interface close
[13:15:29.154] J2534 API Version: 04.04
[13:15:29.154] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[13:15:29.154] Device Firmware Version: 1.12.3688
[13:15:29.154] Device Serial Number: TAyv9EHc
[13:15:29.326] SSM2 init
[13:15:29.466] SSM2 ECU ID is 3D12594006
[13:15:29.544] Requesting Seed...
[13:15:29.591] Sending Key...
[13:15:29.638] interface close
[13:15:29.653] interface close
If someone could help me out, that would be greatly appreciated.
Eddie at PNR is online now   Reply With Quote
Old 01-14-2013, 09:48 AM   #2
Eddie at PNR
Member#: 332016
1999 Swapped GM6
Anyone got any pointers? I've replaced the previous ECM due to it being bricked by the previous owner. Everything else connects besides ECUFLASH
Old 01-14-2013, 07:35 PM   #3
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
what cable are you using?
Th3Franz is offline   Reply With Quote
