Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 11-04-2011, 01:50 AM   #1
BSOD2600
Member#: 126760
2011 WRX Limited
Default 2011 WRX - excessive moisture inside?
Is there a known leak problem with the 2011 WRX's?
I seem to have an excessive amount of moisture inside my car. yes, I've made sure all the windows and sunroof are completely shut. no, I haven't spilled anything nor keep wet things in the car. for example, in the morning there is moisture inside the front window. get home from work, drive around doing errands, get out of a store 10 min later and the back window inside is fogged up.
BSOD2600 is offline   Reply With Quote
Old 11-04-2011, 03:17 AM   #2
Shewillbemine
Member#: 84680
The moisture buildup is INSIDE the car? Have you been experiencing rainy and humid conditions up there?
Shewillbemine is offline   Reply With Quote
Old 11-04-2011, 11:03 AM   #3
BSOD2600
Member#: 126760
2011 WRX Limited
Well sure, it's Seattle... its always overcast in the winter.
Old 11-04-2011, 11:10 AM   #4
ryyiann
Member#: 259241
2011 WRX Limited 5dr
no i dont think this is normal. There is something wrong or something happened that you didnt realize. If i were you tho i would put a dehumidifyer in the trunk for a few hours
ryyiann is offline   Reply With Quote
Old 11-04-2011, 11:11 AM   #5
TechieTechie
Member#: 299597
BSOD...
One thing I was always told...make sure that all debris is cleaned away from the air vents within the engine compartment...if they get blocked with decaying debris it can cause moisture inside the vehicle.
Jen
TechieTechie is offline   Reply With Quote
Old 11-04-2011, 01:47 PM   #6
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Have you or did someone else put a downpipe on the car? The boy genious that had my car before me put a downpipe on it and decided to reroute the A/C (and defrost) drain from the engine bay to under the carpet.
Y_I_K_E_S is offline   Reply With Quote
Old 11-04-2011, 02:26 PM   #7
BSOD2600
Member#: 126760
2011 WRX Limited
Actually do have a dehumidifier (used in my old 94 legacy sport sedan). I'll put it in the car for a few days, but it still seems like a bandaid to a larger problem.
The car exhaust is still completely stock, unless you count the factory install SPT exhaust.
Old 11-04-2011, 02:56 PM   #8
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Car is still under warranty I assume, why not bring it back to the dealer?
Old 11-04-2011, 03:04 PM   #9
BSOD2600
Member#: 126760
2011 WRX Limited
Why? Because I don't have definitive proof of water leaking/pooling into the cabin so don't want to waste my/their time.
Old 11-04-2011, 04:58 PM   #10
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
If it is very damp outside and the car has been sitting outside, then what happens is moisture will accumulate under the cowl-panel and when you turn on the car, the cabin ventilation system engages and pulls some of that moist air into the car.
Also, when the car is colder than the outside air and that slightly warmer/moist air passes through the cowl-area, it is effectively cooled thus causing excess moisture to drop-out and then it accumulates onto the windshield.
On occasion, use the defroster setting: full or split, or use the a/c in conjunction with a desired temperature setting to effectively pull the moisture out of the car.
You more-than-likely do not have a leak.
Also, do you have the cabin ventilation set to fresh-air or recirculate? It should be set on fresh-air most of the time and to recirculate on occasion - read the owner's manual.
Old 11-04-2011, 05:30 PM   #11
darren94
Member#: 138697
11 WRX Limited 5DR
Satin Pearl
My 09 had a leak in the tube that drains water from the gunnell around the sunroof right off the showroom floor. After a good rain, there would be standing water in the drivers floorboard. There is a TSB from Subaru about it.
darren94 is offline   Reply With Quote
Old 11-04-2011, 10:47 PM   #12
BSOD2600
Member#: 126760
2011 WRX Limited
Fresh air.
I typically leave the environmental controls on full auto, which means often it decides to turn on the A/C.
The example from the other night running errands and continuously getting moisture buildup, I always had the A/C on.
Old 11-05-2011, 12:08 AM   #13
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
If the dealer is close enough, and youre sure that its excessive moisture, why not complain? You paid for the car and the wanrranty, might as well take advantage, thats my feeling.
And I had a similar problem with my first 02 WRX, I doubt its the same issue, but my Vent to Recirc slider had the wrong stickers on it from the factory, so at vent it would recirc and vice versa. It took me a good month to figure it out and why my car was always damp and foggy!
Old 11-05-2011, 02:31 AM   #14
D-rock240
Member#: 284221
2011 WRX GV SSM
2001 Legacy BH 5MT DD
Unless you have mods you don't want them to see, I would play the "dumb owner" act. Just take it in and tell them you have moisture buildup in the car and let them figure it out. If its under warranty I wouldn't worry about wasting their time.
D-rock240 is offline   Reply With Quote
Old 11-05-2011, 03:52 PM   #15
BSOD2600
Member#: 126760
2011 WRX Limited
Nope, nothing to hide.
Guess I'll take it in. Good opportunity for them to fix the damn back shelf rattling too.
Old 11-22-2011, 11:33 PM   #16
BSOD2600
Member#: 126760
2011 WRX Limited
Got the car back from the dealer today. They fixed the shelf rattle, yay! Apparently they, "raised rear shelf, made foam blocks to place in a checkerboard pattern under shelf".
As for my moisture problem, they said its a known issue and I should turn off the auto [fan] setting, which will prevent the evap moisture from contacting the windshield. The service guy said this type of thing has been a problem since the 2005 OB. Really? Why the hell isn't the HVAC computer smart enough to close the outside doors when the car is turned off?
Old 11-22-2011, 11:40 PM   #17
Airplay355
Member#: 213825
2013 BRZ
I've never had this problem. Weird to hear it's always been a problem.
Airplay355 is offline   Reply With Quote
Old 11-23-2011, 12:16 AM   #18
hkalienati
Member#: 301803
I own a 2011 wrx and usually have my fan mode on auto and have not seen this issue too. As for the shelf rattle, are you talking about the shelf on the passenger side door? Because I was getting a rattle on my side panel when I play any songs with a low base. it seems like if I put something inside the door well it can slightly fix it but is this a common problem?
hkalienati is offline   Reply With Quote
Old 11-23-2011, 12:41 AM   #19
BSOD2600
Member#: 126760
2011 WRX Limited
No. 4 door WRX, the shelf in the back above the seats which separates the trunk from passenger compartment.
Old 11-23-2011, 12:42 AM   #20
OK11WRX
Member#: 273066
I have not had any moisture issues, this is the first I've heard of it as well.
Not to thread jack, but I had some similar rattles. After multiple failed trips to the dealer to get them all fixed, I spent some time trying to reduce them last weekend. So far, the results have been great!
I am glad that your dealer is apparently FIXING the problem. Mine claimed that the rattle from the rear deck was my license plate....
http://forums.nasioc.com/forums/show....php?t=2272086
OK11WRX is offline   Reply With Quote
Old 11-23-2011, 01:45 AM   #21
hkalienati
Member#: 301803
Can you take a picture of what they did? If it can be seen with the seat down? I think I have a similar issue but I only hear it when I'm revving too low. Is that when you heard that rattle too? I just assumed it was my catback that was causing too much vibration but if it's not, its good to hear it can be fixed
Old 11-23-2011, 05:18 AM   #22
davidmount
Member#: 173026
2003 WRX
double post.
Last edited by davidmount; 11-23-2011 at 05:29 AM. Reason: oops, hate this computer....
davidmount is offline   Reply With Quote
Old 11-23-2011, 05:27 AM   #23
davidmount
Member#: 173026
2003 WRX
+1 for Big-E's instructions. The HVAC computer doesn't really work that way in Subaru's. The controls to close the vents only work with the vents in the cabin, the area where external air enters the system for "fresh air" are always open. At least that's what my old shop foreman and one of our techs explained to me. Hence the need to set the system to fresh air mainly and recirc occasionally.
Old 11-28-2011, 11:45 PM   #24
BSOD2600
Member#: 126760
2011 WRX Limited
Ever since getting the car back from the dealer on the 22nd, I've been turning the fan to OFF (instead of typically leaving it on AUTO), as they instructed to prevent the moisture. Overall I thought it was helping...
Today, according to the local weather stations its only rained 0.01" and had a high of 51F. After leaving the car sit at the local park and ride for 10 hours, this is what I returned to find. Please excuse the crappy cell phone picture. All the moisture is on the inside. The picture is before the HVAC system was turned on, so there was no moisture transfer from the cowl-area to window.
This is still far from acceptable in my book.
Old 11-29-2011, 10:03 AM   #25
jonklein611
Member#: 117776
WR Blue Pearl
Your temp indicator says it's 40F outside. If it was 51F when you parked, the air inside had enough moisture to condense @ 40F. Rain doesn't matter, what was the humidity and dew point for the day?
jonklein611 is offline   Reply With Quote
2011 WRX - Stage 2 + E85 Tune - Dyno Results xluben Proven Power Bragging 71 04-07-2015 04:52 PM
Ap Log for 2011 WRX - Stage 1, 93 - CYLINDER KNOCK - PLEASE HELP.......... thegarius AccessPort 3 04-09-2011 09:03 PM
UOA - 2011 WRX - 4,700 Miles on GC jddssc121 Service & Maintenance 7 04-07-2011 06:47 PM
2011 WRX - Stage 2 - COBB Downpipe and SPT Exhaust (VIDEO) xluben General Community 47 01-19-2011 02:32 AM
2011 WRX - Boost Taper - Stage 1 vs Stage 2 xluben AccessPort 8 01-18-2011 05:24 PM
