Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-28-2013, 09:02 PM   #1
Lakesrider
Member#: 315683
2012 Impreza Hatch
Default Defroster not very good?
I was just wondering if anyone else is having issues with the windshield defroster (2012 Imprezza) during a snow storm. even on full hot, full fan and set on full defrost the windshield never really gets completely cleaned off of ice. Especially the far right side. The windshield wiper tips keep getting loaded with ice and I have to stop,and get out to clear them. Kind of a pain, and not safe at all. It is almost as if the defroster just isn't directing air correctly. If anyone has had that problem and fixed it let me know...I can handle it but I don't like my wife getting out on the side of the road to do this and she may get hit.
Other than that 11,000 miles and no problems what so ever with the car. Love it in the snow....
Lakesrider is offline   Reply With Quote
Old 01-28-2013, 10:59 PM   #2
Irongrave
Member#: 325040
2012 Impreza 5door
DMG
turn your blower speed down to 2 or 3. You'll get warmer air at lower speeds. your moving too many CFMs threw the heater core and it cant recover quickly enough. Lower speeds means less CFMs but higher BTUs aka warmer air. same is true in the summer for colder air.
Irongrave is offline   Reply With Quote
Old 01-28-2013, 11:02 PM   #3
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
with the front set to defog and the a/c button illuminated and rear set to defrost, I have never had this issue, I did however switch to bracket less wipers from bosch so that may explain why I have not encountered this issue. I am certain others in the snow belt can chime in.
Old 01-29-2013, 12:27 AM   #4
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
I have Bosch Icon wipers on mine and Prestone De-Icer in the washer. The only time I had a patch of ice in the center of my windshield that didn't clear off was last week on the way home....but it was between 5 above and -10 and I didn't scrape it off to good.....too damn cold to do so!
BajaGuy68 is offline   Reply With Quote
Old 01-29-2013, 12:35 AM   #5
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Irongrave is correct. What makes it worse is that since recirculation is disabled in defrost mode, all the air being blown through that heater core is outside air. This can actually cool off an already warmed-up engine.
Either stick with the lower fan speeds on defrost mode, or use another mode with recirculation.
If you have the cold weather package, you can force the windshield de-icer on by holding the defrost button until the LED turns off and back on.
Old 01-29-2013, 01:47 AM   #6
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
I drove through a rain-sleet-ice-snow storm last month and experienced just about the max the car could handle.
I was taking a friend down to the Ozarks to pick up a Mazda Speed6 (awesome car btw) and on the way back is started raining, the next hour it was sleet, then ice, then snow, and by Kansas City clear =0
On the way the defroster had little trouble in keeping the window free of ice, but the wiper blades froze slightly making them stiff and not in full contact with the window. I stopped twice in what became a 7 hour drive to knock off ice and get them back in full contact with the window.
In severe conditions like that, the only thing that would have prevented the wipers from icing up would have been heating elements integrated on the wipers.
The car did very well though overall =) I was quite happy.
Xafen is offline   Reply With Quote
Old 01-29-2013, 03:54 PM   #7
finklejag
Member#: 318622
2012 Impreza
My car always has two fog spots on the lower center windshield. I don't know why they are always there?
finklejag is offline   Reply With Quote
Old 01-29-2013, 08:22 PM   #8
M45
Member#: 333446
2013 Impreza SL CVT
no problems here yet but i haven't really required too much.
M45 is offline   Reply With Quote
Old 02-02-2013, 09:13 AM   #9
Lakesrider
Member#: 315683
2012 Impreza Hatch
Thanks. I guess I'll have to try a few of the suggestions to see if it makes a difference. It is odd as the air coming out of the defroster vents seems hot enough, yet it does not seem to get all the way to the top of the windshield to get the ice off the middle/top of the glass. Only other thing I noticed the other day is the tip of the passenger side blade ices up pretty badly. I do have the Bosch blades on it as well.
Thanks.
Old 02-03-2013, 01:58 AM   #10
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
When full defrost or split defrost is on the A/C compressor automatically kicks on to dehumidify. The A/C button doesn't need to be pressed.
SleepNMnky is offline   Reply With Quote
Old 02-03-2013, 08:21 AM   #11
Zeeper
Member#: 299286
2015 WRX CVT
And apparently on some cars the AC light illuminates when the defrost setting is set, others it does not, but either way the AC cycles on and off.
Old 02-03-2013, 11:04 AM   #12
gravitylover
Member#: 334328
2013 BRZ Premium 6MT
Mid Life Crisis White
I've had the windshield freeze up on me twice now. Both times it was in the low 20's and sleeting mixed with freezing rain and I was doing highway speeds. When this happens the headlights usually freeze up too. What really makes it bad is that the windshield wiper heater is on if the defroster is on so the wipers are warm and spread a micro thin layer of warm water on the glass and that's what freezes up on me because the top of the glass is so cold. I wish the defroster could be run independently of the wiper heater. So far the only solution I've found is using a really good low temp washer fluid and blasting every minute or so depending on need.
gravitylover is offline   Reply With Quote
Old 02-03-2013, 12:12 PM   #13
ans2k
Member#: 315631
2012 Impreza Sport
wait, what am i missing here? so the windshield wiper de-icer will not work while the windshield defogger is on?
Old 02-03-2013, 12:20 PM   #14
SleepNMnky
Member#: 302491
The windshield wiper de-icer is connected to the rear defrost button as that activates the entire all weather package. So you can have the defrost on independent of the wiper de-over but then the rear defrost won't be on.
Old 02-03-2013, 12:42 PM   #15
abxex
Member#: 295269
Holding the [rear] defrost button until the LED turns off? I thought you just had to press it until the LED turned on.
On another note related to the defrost setting, does anyone else feel this car fogs up easily? I feel like no matter the season or weather, the front windows get partially fogged unless the front defrost setting is constantly on. I think I radiate an average amount of heat for a human being lol. I don't remember my previous cars being like this.
abxex is offline   Reply With Quote
Old 02-03-2013, 12:49 PM   #16
SleepNMnky
Member#: 302491
I agree. I usually end up cracking the back window a tiny bit to alleviate it. Shouldn't be necessary but it works. I thought maybe its because I have the hatchback. When I had an SUV there were defrost elements in the side hatch windows & that helped. Do you have be hatch or 4 door?
Old 02-03-2013, 01:13 PM   #17
abxex
Member#: 295269
Hey sleep. I have a hatch. Ya, those extra side/rear defroster vents that the '12+ is missing would probably make a big difference.
Old 02-03-2013, 06:39 PM   #18
gravitylover
Member#: 334328
The windshield wiper de-over is connected to the rear defrost button as that activates the entire all weather package. So you can have the defrost on independent of the wiper de-over but then the rear defrost won't be on.
What I want is to be able to have the rear window defroster and mirror heaters on but not the wiper heater.
I'd also like to figure out a way to have the headlights either burn hotter or add some sort of heater element there so they don't freeze over. My Volvo had heated headlight washer nozzles and they were critical to winter condition driving safety.
Old 02-03-2013, 07:58 PM   #19
SleepNMnky
Member#: 302491
Without disabling them altogether, I don't think it's possible.
Old 02-03-2013, 08:22 PM   #20
Commander Keen
Member#: 319157
If it's below 41F, the windshield de-icer will come on with the rear defroster. Otherwise, you can force it on by holding the button.
