Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 01-31-2013, 09:27 AM   #26
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Nice write-up.
Note: I would suggest using the copper Never-Seize for the studs and exhaust hardware. It tends to work better with the heat than the silver/gray Never-Seize.
I also coat the exposed threads when done to make life easier down the road.
Old 01-31-2013, 10:15 AM   #27
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Thanks, and thank you for the tip.
As a side note to my latest video: I did notice a much smoother power delivery/ acceleration across the whole rpm range while doing my several highway pulls. The butt dyno noticed a difference :P
Duvanator is offline   Reply With Quote
Old 02-01-2013, 12:53 PM   #28
Distant.Calling
Member#: 230167
2006 2.5i
CGM
First off, thanks a ton for the write-up as the instructions are quite clear/simple. Second, thanks AGAIN for making/posting vids of how it sounds (and how great your car sounds at that!).
Question: are you running a stock cat or do you have something aftermarket? I'm semi-on the fence about getting these headers and wondering if I should either stick with a stock cat, get a high-flow cat, or do a test-pipe ().
Distant.Calling is offline   Reply With Quote
Old 02-01-2013, 01:42 PM   #29
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Thanks! My exhaust is composed of the uel header to the stock mid pipe which houses the second cat then bolted up to the OBX catback.
So the header has the highflier cat, and the secondary stock cat remains in the system... For now lol
Old 02-01-2013, 01:59 PM   #30
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Pull the trigger on the headers u wont regret it
Steve2.5i is offline   Reply With Quote
Old 02-01-2013, 02:04 PM   #31
Distant.Calling
Member#: 230167
2006 2.5i
CGM
Awesome. Considering the quality and fit, the price offered for the headers seems like a steal! Thanks for answering, looking forward to seeing more about your car in the future.
As much as I would love to buy them, kind of roughing it with my car as is since I've been doing a lot of routine maintenance PLUS I know sooner or later the HG is going to have to be replaced and I was quoted ~$2k for the job. So there's that. Plus being in school with no job also presents issues in terms of buying stuff for the car.
Old 02-08-2013, 06:41 PM   #32
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Here's out on a lake
The once peace and quite broken with the rumble from a boxer
Old 02-11-2013, 08:51 AM   #33
AJB001
Member#: 338330
Man I hope the 12+ imprezas will sound this good with the rallisport uel hedder. Mike is working on ours next...great thread!!!
AJB001 is offline   Reply With Quote
Old 02-14-2013, 01:29 PM   #34
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
I hope mine comes soon! I just received my Perrin axle back and I can't wait to add the headers!
reide181 is offline   Reply With Quote
Old 02-15-2013, 03:43 PM   #35
jamesonp16
Member#: 347149
2007 impreza 2.5
red
When the snow falls = some donuts, some drifting, and even driving into a ditch because I was too afraid I was going to hit my friend holding the camera haha, but awd and snow tires got me out instantly.
And of course that sexy uel exhaust note
Subaru's - Winter Fun - YouTube
hey man i love the videos! its alot better than most of the ones i have found on youtube. it really gives me a better ide of what the headers will sound like. what is your exhaust set up as far as a catback?
jamesonp16 is offline   Reply With Quote
Old 02-15-2013, 10:21 PM   #36
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Thanks guys!
Well then you'll enjoy this one too
I have the headers paired with an OBX cat-back
Old 02-17-2013, 10:33 AM   #37
09subi2.5i
Member#: 331636
09 impreza
paprika
7. The header is now off of the car
Now you want to move over the o2 sensors from the old to the new. Make sure to place them in the same respective spots as the sensors are different. Apply some anti-seize to the threads before installing and be careful not to get any on the sensor itself.
**Note: The o2 sensors are seemingly tightened by the Subaru gorilla and might not come out without a fight. My front sensor came out with no issue but the rear would not budge. I used an oxygen acetylene torch to heat up around the sensor and was then able to easily remove it. **
8. Its now time to bolt it back to the car. Place the new gaskets on the studs prior to fitting the header. With the help of a friend raise it up into place. Secure it with one (1) nut on each side to hold it in place. Then continue with the rest. The header bolts/nuts should be torqued to approximately 30nm (265 in-lbs)
With the three (3) new bolts/nuts provided attach the header to the mid-pipe. Making sure to place the new gasket in between.
9. I would recommend placing the o2 sensor wires on top of the header (no dangling down) to make it easier to reach them from above to reconnect them.
10. Reinstall the under-tray. It is easiest to line up and insert the plastic clips in the wheel wells first, then the bolts underneath.
11. Lower the car down and re-plug the o2 wires
12. Reinstall the air-intake
13. Reconnect the battery
14. Thatís it, youíre all done. Shouldnít take more than an hour or two at a leisurely pace in the company of a friend or two
If there is anything unclear donít hesitate to ask. And if you have any questions about the company or product Mike at rallisport is by far the most caring respectful business owner you will come across. His customer service is beyond exceptional.
Here is the very first start. It is worth noting that it is -14c outside so it is indeed a very cold start.
I have an obx cat-back installed as well. All the details can be seen in my log here : http://www.toronto-subaru-club.com/f...2008-2-5i.html
Video:
UEL 08 Impreza - YouTube
Make sure to check back for more videos/soundclips
Thanks for looking
Eric
Is that also the Eibach front sway bar? do you have the kit that comes with both? fix any understeer problems? any complaints? how long have you had it?
09subi2.5i is offline   Reply With Quote
Old 02-17-2013, 02:10 PM   #38
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Keen eye lol
Yes that's an eibach 25mm hollow front bar. I did not get the kit as I had already had a 22mm whiteline solid bar in the rear. I never auto-x'd the car before the sways but now the car is so planted. Almost zero body roll at all. It's grips and grips up to the limit. But once you're at the limit it will still plow/under steer.
So I went from stock (front 19mm, rear nothing) had this for over year.
To front 19mm, rear 22mm. Which transformed the car from night to day. Highly recommend this to ALL 2.5i owners. Had the rear bar on its own for almost a year.
Then I upgraded to front 25mm, rear 22mm. And again this made a big difference. Not quite as drastic as the rear bar. But still very noticeable, even in regular street driving/cornering. And I've had this set up for maybe 6 months. And I've auto-x'd on it several times so I've actually taken the car to the limit. And the limiting factor now is the tires. The sidewalls give the most when cornering lol
The big sways with the soft springs has turned out to be a winning combo and I couldn't be happier! If you have more questions about any of it I'm glad to help
Old 02-17-2013, 07:25 PM   #39
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Keen eye lol
You are full of useful info for me, what are the next winning lotto numbers?
I think I will get me a 22mm rear bar and fix a LOT of my body roll... yet another thing to add to the list
So I just checked out Whiteline's site and dont see a solid (Im reading that as non adjustable btw) rear sway bar. Am I wrong in assuming its not adjustable??
Ralph47 is offline   Reply With Quote
Old 02-17-2013, 08:50 PM   #40
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Haha. The winning lotto number is.... 1
This is exactly what I have
http://www.whiteline.com.au/product_...number=BSR51XZ
Most bars are solid unless otherwise stated. And yes it is adjustable, but not with the endlinks that the kit comes with. It is a rigid endlink that I was only able to fit in the middle set of holes. Not a big deal for me.
Old 02-18-2013, 03:34 PM   #41
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Thanks again for the info
Old 02-18-2013, 03:59 PM   #42
09subi2.5i
Member#: 331636
09 impreza
paprika
Keen eye lol
Thank you very much. What made you upgrade the front as well? Did it help with the under steer problem?
Old 02-18-2013, 04:36 PM   #43
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
I wanted to upgrade the front as there was still body roll and I wanted to eliminate it. The understeer is difficult to explain, yes it helped a lot, but the design of the car and drivetrain still promotes the understeer. So by stiffening everything up like I have, the understeer doesn't happen until your going way to fast into a turn. I discovered and proved this multiple times during auto-x racing lol.
With the large front a rear bar the tires remain in full contact with the ground. Letting you use all the grip poissible. Since body roll would pick up the tire and reduce the contact area. So the limiting factor is the tires, and the sidewall stiffness.
With this current set up I have LESS body roll than a stock 2011 sti sedan (raced in the auto-x)
Old 02-18-2013, 08:23 PM   #44
jamesonp16
Member#: 347149
2007 impreza 2.5
red
Default headers
I noticed that in one of your posts that you said you are running 2 cats ( the stock and the high flow). I have an 07 2.5 and the stock cats are both in header pipe. so if i do the header swap do you think ill run into CEL issues?
also is it worth the extra money to get the coated headers? is it really worth the $250 extra.
thanks for your help again
Old 02-18-2013, 09:17 PM   #45
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Your cats are located in the same locations as my own. It's the same exhaust layout. Only the front cat is IN the header. The second cat is immediately after the header. Only the front cat is monitored with o2 sensors (as seen in the DIY pics).
I opted for the coating as I didn't not want any chance of a cel. I've already experienced temperatures in the -20's and -30's and no issues. So if lack of heat was going to be the cause for the cel then the coating has definitely helped.
But I haven't compared with and without coatings obviously so I can't recommend or say for sure. But the coating does work, it protects the product and keeps the heat in the cat. The main reason the cel comes on is like I said in the first post, the high flow cat doesn't run hot enough to run within factory tolerances.
So it's up to you if you feel you can justify the expense or if you need the coating. You are already spending this much for them, so in the long run what's a little more.
Old 02-18-2013, 09:43 PM   #46
09subi2.5i
Member#: 331636
09 impreza
paprika
I'm sold haha gonna buy the set now.
Old 02-24-2013, 06:28 PM   #47
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
I'm curious if there is any other sound clip, or form of video anyone would like to see? I can easily do more, just let me know what you want to see/hear
Old 03-02-2013, 01:20 PM   #48
LowerLevel
Member#: 343743
2007 Legacy
Diamond Grey Metallic
Please allow me to be another to thank you for the write up! Oh my tax return...
LowerLevel is offline   Reply With Quote
Old 03-03-2013, 10:00 AM   #49
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
You're welcome!
and since no one has any video requests....
I'll just leave this here:
( real world driving you know...)
take special note of the exhaust on the rc car... hahaha
Old 03-08-2013, 03:31 PM   #50
Tmangt650
Member#: 277258
2008 Hatch 2.5i
Nice write up Eric, thought it was more difficult then that, my only issue would be getting it to pass smog out here in CA. Might be worth looking into after my first smog. Thanks again. Another thing to add to the list
Tmangt650 is offline   Reply With Quote
