Old 01-13-2013, 09:32 PM   #1
Flat Face
Member#: 275220
2000 Bugeye
Blue Ridge Pearl
Default Rear window rubber popped out
It's been like this for quite a while and I've got no clue what to do.. I spent ages trying to just pop it back in, I tried taking the trim off but it's all one piece so it didn't help at all.. any ideas?
ALSO the carpet mat on the drivers side under the pedals has come off from the carpet *bad glue* I'm just wondering what kind of glue I should use to stick it back on? it's the leathery mat on the actual carpet, not a mat that you take out
Flat Face is offline   Reply With Quote
Old 01-14-2013, 09:25 PM   #2
nabokovfan87
Member#: 340943
sounds like the heat dried it out. I wouldn't know what to use here, but some 3m double side contact tape (3055 seems like the right number I recall). That can be used for either.
It is typical of PC modders modifying their doors on the case for grommet (to hold plexi in place).
I'm sure it will work on the carpet, but with that heat it is just a matter of time before it comes off.
nabokovfan87 is offline   Reply With Quote
Old 01-15-2013, 07:30 PM   #3
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Literally that window seal should just pop back in. I just had mine out when I painted my car. Try tucking the side that goes under the trim first and then the lower edge should just pop into the grove. Lightly using a flat screwdriver may help.
On a side note, thirsty much? lol 2 liter in the center console.
Jackie leggs is offline   Reply With Quote
Old 01-21-2013, 03:18 PM   #4
JustinM88
Member#: 156688
2007 WRX TR
Urban Gray Metallic
same thing happened to mine and I just can't get it back in. I can't get the rubber to stay tucked into the window, even though it seems like it should just "hook" right in..
JustinM88 is offline   Reply With Quote
