Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-14-2013, 10:56 AM   #1
matigas_TT
Member#: 322775
2012 WRX-4Dr
Default Problems with my 2012 WRX - Popping on exhaust / Whistle on Half Throttle
Car: 2012 WRX
Mileage: 5941
Mods: Nameless Axelback
Issues: below
So.. I'm on my 8months of owning this WRX and the first issue was a fluid leak shown here (intercooler hose problem) http://forums.nasioc.com/forums/show....php?t=2422067
Then last week same problem occured but this time with additional issues!
1. On half throttle whistling noise can be heard on driver side (boost leak maybe?)
2. Changing gears on half throttle produces a loud popping noise on the exhaust.
Any of you 2011-2013 owners experienced this ?
Dropped my car off the dealership this morning and they said there is an ECM update or system they have to do and look at the leaks..
Car is completely stock..
matigas_TT is offline   Reply With Quote
Old 01-14-2013, 11:02 AM   #2
cineris
Member#: 263329
2011 Impreza WRX
Is it a muffler delete axle back? Mine pops all day. Also, that whooshing sound is most likely intercooler to throttle body hose.
cineris is offline   Reply With Quote
Old 01-14-2013, 11:06 AM   #3
matigas_TT
Member#: 322775
2012 WRX-4Dr
Yep, but this only started happening. This wasn't happening before
Old 01-14-2013, 11:09 AM   #4
cineris
Member#: 263329
2011 Impreza WRX
Are you talking about the popping or the whooshing? Popping happened to me as soon as I put the axle back on. The whooshing could be a problem with the IC-throttle body hose getting kinked. Very very common with 08+ WRXs.
Old 01-14-2013, 11:10 AM   #5
1wrxtra
Member#: 316364
2012 WRX
Car: 2012 WRX
Mileage: 5941
Issues: below
Where are you located? What about the sound at WOT? Is it much louder? Is it a whistling sound or like a high powered kazoo type sound? I have a sort of whistle but it's not a boost leak... the turbo spooling is definitely louder at colder temps. Do a search for "wrx whistle" and you'll find quite a few threads on this same issue with videos and sound clips for your comparison.
I have Nameless's catback on my '12 sedan with a 5" muffler and resonated midpipe, and I get these pops too. It's my understanding that the cause is hot air meeting with cold air as the exhaust leaves the pipe. I didn't really like them at first but they've grown on me. If I go 60-100% throttle for a few seconds and let off it make a pretty aggressive growl/pop.
The ECU update is for the coolant thermostat, my understanding is that it's related to emissions in certain states.
Message too short
1wrxtra is offline   Reply With Quote
Old 01-14-2013, 11:26 AM   #6
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
I've got the "exhaust popping" noise with the Nameless Axleback as well. It started doing this as soon as I put the exhaust on. I don't really hear the popping too much during shifts, but if I am idling and rev the engine, it pops almost every time. I consider it to be normal in my situation. Is there a chance you could make a video of the sound?
CO11WRX is offline   Reply With Quote
Old 01-14-2013, 11:50 AM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'm 100% sure it's a boost leak. Very, very likely it's the throttle body to TMIC hose. See here:
http://forums.nasioc.com/forums/show....php?t=2453485
http://forums.nasioc.com/forums/show....php?t=2447983
In your last thread people told you to remove those caps. It is a known issue and the dealer won't do it because it's not factory spec. Remove the caps and tighten it back down and it will never be an issue again.
xluben is offline   Reply With Quote
Old 01-14-2013, 12:28 PM   #8
matigas_TT
Member#: 322775
2012 WRX-4Dr
Originally Posted by 1wrxtra View Post
Message too short
1. NJ, I did look at youtube and it's a boost leak, again this only happened two weeks ago and we had colder temps before this happened
2. Interesting..
3. Thanks for the heads up
I will when I have the car back
I was going to do this but I'm afraid that dealership will put this blame on me when I get a different issue and they saw that I did this method "You did this, you did that" just paranoid. but I might just do this... no aftermarket park for this ?
Old 01-14-2013, 01:49 PM   #9
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
There are aftermarket hoses for that location, but you do not need one. You just need to remove the pieces of rubber from both ends of that hose. With those on it leaks at stock boost (as you've seen). With them off my car does double the stock boost and it holds fine.
Old 01-14-2013, 03:46 PM   #10
GrumpyPitbull
Member#: 313311
You are afraid to remove the IC hose rubber thingy, but are willing to bolt in an aftermarket hose?
If your stock, then do not waste money on a new hose ... simply remove the rubber cap things and never worry about it again. However, if you are terribly worried about the dealership, then yes there are aftermarket hoses available.
GrumpyPitbull is offline   Reply With Quote
Old 01-14-2013, 04:44 PM   #11
whitesoorex
Member#: 336393
2010 WRX
the nameless is a complete muffler delete, not an exhaust system. I have it too on my car and yes it pops and grumbles. If you dont like it you probably should have got a muffler. I love it.
whitesoorex is offline   Reply With Quote
Old 01-14-2013, 04:59 PM   #12
momoscoobiedoo
Member#: 276198
Plus one for nameless I have a complete cbe from them with a invidia probably te loudest Subaru on the west coast lol
momoscoobiedoo is offline   Reply With Quote
Old 01-14-2013, 07:49 PM   #13
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
this doesnt seem like alot of problems as your title states. you are under warranty. see what the dealer says.
424wrx is offline   Reply With Quote
Old 01-14-2013, 08:13 PM   #14
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
As stated dealer won't fix it because they can't.
OP youve been told already how to fix it! Listen to Xluben. I'd say him and i have more underhood time on these than anyone so listen. Also oil shouldn't be there on your air pump hose. Not sure why or where it's coming from. look into it further. If it is your IC hose then you're dumping oil into the intake system from the valve and crank vents and its leaking out. All these cars need an air oil separator no matter what! Get one and keep oil out of there.
synolimit is offline   Reply With Quote
Old 01-14-2013, 08:17 PM   #15
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
OP youve been told already how to fix it! Listen to Xluben. I'd say him and i have more underhood time on these than anyone so listen. Also oil shouldn't be there on your air pump hose. Not sure why or where it's coming from look into it further. If it is your IC hose then you're dumping oil into the intake system from the valve and crank vents. All these cars need an air oil separator no matter what! Get one and keep oil out of there.
this guy knows. i had oil issues major in my perrin tmic. bought and installed a grimmspeed aos. no more oil in the tmic. also, the endcaps are a must like theyve said.
Old 01-15-2013, 08:26 AM   #16
matigas_TT
Member#: 322775
2012 WRX-4Dr
Got my car from the dealership yesterday, everything is back to normal now, no more loud whistle and popping on exhaust.
So this is what's written on the service paper
1. Check for oil leak found on intake cooler
2. Check PCV Line found PCV clogged
Work Performed
Installed 11810AA120: Valve Comol Cont
Replace PCV Valve
Perform ECM Reprogramming Per WQC39 Bulletin Code 145583CK with no Reprogram B14558 UPV48 .3CK
When the temps get lower in NJ I will do this, thanks for the recommendation!
I'll just use the OEM hoses they shouldn't be cheap to buy just in case
It doens't pop anymore after the fix but still grumbles
How much was it ? Noticeable power increase ?
I know.. My mistake probably my frustration, I'll change the title
Yes I will follow the fix and thanks
Yup next on my list when the weather becomes better
THANKS FOR ALL THE RESPONSE!!!
