Old 01-15-2013, 11:47 PM   #26
WoodsWagon
Member#: 180769
lots of junkers
You can do the combustion chamber work yourself if you can't send it out to one of the shops that does CNC head milling.
Use the 2.5l headgasket to mark the cylinder bores on the heads, go by pictures of the 2.5l heads and use a burr and a flap wheel to open them up. CC the chambers and trim to get them all balanced. The aluminum is easy to work and you can get both heads done in a couple hours. Be patient and careful, you don't want to nick the valve seats or score across the deck surface.
Opening up the chambers is much better than using a thick headgasket because you don't loose the quench zones where the piston is nearly touching the head at TDC. That helps a lot with even combustion pressures and reduces the tendency to detonate.
The hybrid build I helped on was an 05 EJ257 shortblock with 02 EJ205 heads. Stock td04 and everything else.
The result ran great, but the car wasn't driven that much longer because the owner had a ton of other maintenance issues he hadn't taken care of and it was parked. It's now been sold to someone who's in the process of fixing it up right.
WoodsWagon is offline   Reply With Quote
Old 01-16-2013, 07:51 AM   #27
04WRX_Boost
Member#: 331408
2005 WRX STi
My plan is to use the stock sti HG and just drop it in with no other work and see how it goes. Wgat should i expect for a compression ratio.
04WRX_Boost is offline   Reply With Quote
Old 01-16-2013, 11:06 AM   #28
danger1138
Member#: 279525
04 rex luger!
Expect a higher than normal compression ratio, not sure the exact figures but if you search you'll find out. Since running higher than normAl compression ratio id suggest not to boost the hell out of this machine.
danger1138 is offline   Reply With Quote
Old 01-16-2013, 02:07 PM   #29
04WRX_Boost
Member#: 331408
2005 WRX STi
Yeah I hear the higher compression is better for off boost driving and the turbo spools alot quicker. I only plan to be on about 17-20 pounds max on a 16G
Old 01-16-2013, 03:17 PM   #30
danger1138
Member#: 279525
04 rex luger!
If your not doing head work, i would advise u to run thicker head gaskets. (Cometics)
Old 01-16-2013, 03:39 PM   #31
04WRX_Boost
Member#: 331408
2005 WRX STi
I don't wanna run a thicker HG. I should be fine with stock. Just gonna have a higher CR
Old 01-16-2013, 03:56 PM   #32
danger1138
Member#: 279525
04 rex luger!
Yea if thats the route u wanna take. But usually most people wanna run higher boost, hence u would want lower or close to stock compression ratio.
Old 01-16-2013, 04:09 PM   #33
04WRX_Boost
Member#: 331408
2005 WRX STi
Yea I'm gonna have to sacrifice boost
Old 01-16-2013, 04:54 PM   #34
danger1138
Member#: 279525
04 rex luger!
Yea that added torque with a hybrid is def worth it.
Old 01-16-2013, 05:36 PM   #35
04ScoobyWtf
Member#: 287974
I was gonna go stock sti hg in my hybrid also but my tuner convinced me it would be easier to tune and I would get more life out of my engine if I run a lower compression so he recommended .051 cometics. Also note that u have 8.9.1 pistons also so I would of been up there
Edit: compression came out at 10.1 so even with a thicker hg it's high
04ScoobyWtf is online now   Reply With Quote
Old 01-16-2013, 05:43 PM   #36
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
My concern with your setup would be that you're using stock STi pistons, which are not known for their knock resistance. I would at least throw in some forged pistons for peace of mind, but to each their own. I don't deny it will be fun as a DD with high compression. Just make sure you have a very good tune and keep the boost low.
03SubyWRX is offline   Reply With Quote
Old 01-17-2013, 05:02 PM   #37
04WRX_Boost
Member#: 331408
2005 WRX STi
Would you reccomend just getting the cometic thicker head gasket? To run more boost
Old 01-17-2013, 05:45 PM   #38
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
I would personally have the heads machined; I wouldn't bother running a hybrid without doing that. However, if you absolutely can't, then I'd run a thicker head gasket for more room to breathe when tuning it.
Old 01-17-2013, 08:43 PM   #39
04WRX_Boost
Member#: 331408
2005 WRX STi
I'm gonna run a cometic, .51. Head gasket. Do they fail? What kind of CR should I see with this? Or should I go thicker ?
Old 01-20-2013, 12:44 AM   #40
dinggoo
Member#: 295432
2003 WRX
MBP
If your going with that thickness dont go with cometic, just go with OEM gaskets
But if your not getting the heads machined and going to use the HG to lower the compression ratio you would nee like a 1.1mm or 1.5 depending on what compression ratio you wanna go with
dinggoo is offline   Reply With Quote
Old 01-21-2013, 11:24 AM   #41
04WRX_Boost
Member#: 331408
2005 WRX STi
I want the low end torque of the higher compression ratio, but I'm not sure exacly how much boost I will be safe on, 20? Maybe ?
Old 01-22-2013, 05:12 PM   #42
04WRX_Boost
Member#: 331408
2005 WRX STi
What does anyone think of the stock NA 2.5 head gasket
Old 01-23-2013, 12:29 PM   #43
gfx2043
Member#: 205174
working on my build. I'm waiting on the heads to get dome by Ed at Eq, then I can finaly get it put together. at the momen I have the following
New Ej257 2009+ with carillo rods and CP pistons with side skirt coating.
EJ205 heads CNC work is being done to the chambers by Ed, full P&P, BC 272 cams,
new Gates water pump and full timing kit, ARP head studs, OEM complete EJ205 gasket kit with OEM STI head gaskets, 11mm STi oil pump, K&N typhoon intake, Perrin catless up and down pipe, Cobb cat back, 06 sti trans, DW800cc injectors DW 200 fuel pump, Excedy light weight STI flywheel, Excedy stage 1 HD STI clutch. Up in the air about the turbo not sure if I want an FP green HTA or a Blouch 20G-xt.
gfx2043 is offline   Reply With Quote
Old 01-24-2013, 06:12 AM   #44
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
HTA FP green hands down. Love that turbo and would recommend it to anyone.
Bamofo is offline   Reply With Quote
Old 02-14-2013, 12:13 AM   #45
dinggoo
Member#: 295432
2003 WRX
MBP
IDK about these gaskets but I believe the bore is different than the STI so you would need a wider HG
Old 02-14-2013, 02:19 AM   #46
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Check your notes
FuJi K is offline   Reply With Quote
Old 02-26-2013, 04:00 AM   #47
Evo-killr
Member#: 252905
2002 Fully Built Wrx
gon rotated psm
so whats safe boost level if your not using a thicker headgasket or chamber matching the heads?
Evo-killr is offline   Reply With Quote
Old 02-26-2013, 04:01 AM   #48
Evo-killr
Member#: 252905
gon rotated psm
andrew himself at andrewtech told me he would NOT recommend to chamber match or use a thicker gasket.
Old 02-26-2013, 09:37 AM   #49
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
When you run a 2L head on a 2.5L block, especially the EJ257 with its pistons or pistons with the same dish, the compression ratio rises. You run less boost with the same timing. Wanna run the same boost, have to lower timing a little.
If you wanted to run a hybrid on pump gas, i would recommend getting pistons to lower the compression ratio to reduce detonation. If afraid of losing lowend torque? You shouldn't be because you have a 2.5L and you should drive according to your powerband. I have no problem driving a 2L around town.
If the quench really mattered, the pistons should have matched the chambers with a pad on them as well.
Old 02-26-2013, 11:03 AM   #50
Evo-killr
Member#: 252905
gon rotated psm
Ahhh wtf I can't decide what to do I just don't wanna spend the extra money to do it. When it's possible to have high compression and run less boost. Is it really that unsafe? I wouldn't think so
