![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#151 |
Member#: 280838
Vehicle:MY12 WRX DGM EFI Stg2+ |
^Don't forget with slightly bigger tires you will get a height gain too. For example i'm going from factory 235/45/17 to 245/40R18 and I will be gaining 5 mm in ride height from that alone. Arch wheel gap will also effectively decrease by 5 mm so that affords the look of being lower while actually raising ground clearance.
#152 | |
Member#: 272675
Vehicle:2011 WRX hatch WRB |
#153 |
Member#: 280838
^I know I won't have the gearing advantage, but it's my winter A/S setup, not my summers.
#154 |
Member#: 272675
#155 |
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
#156 |
Member#: 322385
Vehicle:2006 Civic LX Stage a lot 140BHP |
16's will, I'm actually looking for a set of 15" Braids for winter.
#157 |
Member#: 339148
Vehicle:2011 WRX Sedan Silver |
Before: OEM shocks and springs...
![]() ![]() After: Bilstein shocks and yellow springs, Rear set to top circlip, car has fully settled, before alignment... ![]() ![]() |
#158 |
Member#: 248364
SCIC
Vehicle:2010 WRX 331hp/374tq VF52 silver |
People, I know some of you may not want a stiff ride, but I am willing to guarantee that the yellows with the Bils are NOT going to give you a rough ride. It is still relatively plush to me. And yeah, the drop is minimal, I'd believe 15-20mm. But I didn't measure before I swapped them. I am running the rear 5mm up to compensate for my 2 kids in the car. I wouldn't want to go any lower. I like susp travel and not having to slow down for everything.
IMO, this is a great "set it and forget it" setup for someone who wants a no-hassle susp upgrade. And btw, I have never had any passenger in the last 15 months comment that my car rode stiff or rough, etc with the RCE yellow/Bils. |
#159 |
Member#: 280838
My Blacks with the revalved Bilsteins have settled. Too bad for lake effect snow though. Will take better pictures when I see the sun again!
![]() ![]() ![]() Rears are at +5mm. This retains the factory rake, but honestly I think +10mm would be better. I will change it when the weather warms up. Ride is good, a bit stiffer than my GSR Evo X but not harsh. My alignment is: -1.8 camber FL/FR 0 toe FL/FR -1.3 camber RL/RR 0.05 toe in RL/RR I actually wanted less camber in the rear for rotation but due to compression even with rolled rear fenders it was safer with current settings. |
#160 |
Member#: 322385
Good job doing it the right way and getting those bils revalved!
#161 |
Member#: 280838
Thanks! There doesnt seem to be any evidence of the revalve as far as serial #'s go. Unless Myles wants to chime in and let me know how I can tell. Can everyone who has either Yellows/Blacks post their hub to fender distance?
#162 |
Member#: 322385
Check out earlier in the thread, everything should be posted somewhere.
#163 |
Member#: 329681
Vehicle:2012 WRX Sedan SWP |
I'm leaning towards the GTWorx kit with the black springs for my '12 sedan. Does anyone have any more pics they can post up. It's kind of hard to see the drop on most of these pics. Also, do you guys recommend having the bils re-valved for the black springs? Does that cost anything extra?
#164 | |
Member#: 277915
Vehicle:2011 WRX Premium SWP, Stage 1 |
#165 | |
Member#: 277915
#166 |
Member#: 280838
Heres 2 pics showing the drop with a slightly larger ratio tire (245/40R18):
![]() ![]() Camber is F-1.8 R -1.5 |
#167 |
Member#: 326317
SCIC
Vehicle:2011 Impreza WRX SSM |
I never saw this thread previously, but after going through it there was alot of misinformation (assumptions) I saw so I thought I would post the link to my review comparing the yellows and blacks.
http://forums.nasioc.com/forums/show...t=rce+bilstein Not sure where anyone got an idea that the blacks are bad on the track, but I assure you they aren't with adjustable sway bars. Certainly the yellows are better & if you want a dedicated track car its the right setup (for not fully adjustable), but if you want your car to not be uncomfortable through snow and rough roads which I deal with for work I would highly reccomend the blacks having used both in all situations. Just my .02... Also I didn't revalve mine when switching springs after consulting with my local alignment shop and RCE. Absolutely no issues, 15K miles and 3 track days on them... Last edited by mkvaron; 04-04-2013 at 01:47 PM. Reason: bottom comment |
