Old 01-21-2013, 06:12 AM   #1
Ilovecugars
Member#: 299442
2005 Forester XT
Default Idel afr unsteady
Hi guys.
I have a 05 Fxt with a stage 3 setup and a pro tune through AP. The car have been like this for a while and has worked well. However lately it has had rough idel and has been a tough one for me to figure out.
At idel is the only time it does this, the rpm are steady within about 50rpm either way. But monitoring the afr I see it is jumping around a fair bit. It will fluctuate from 14 to around 15.5 and anywhere in between and when it jumps around it is causing a roughness felt through out the car. Once the car is rolling it has no issues and works great and even seems to improve a bit when the AC is on and has no idel issue when it is cold warning up on high idel.
I was having some surging issues at part throttle so I replaced my front o2 which did solve that issues but did not fix the idel. At least I can narrow it down to know that sensor is not at fault.
If any one has any suggestions of where to look for causes to this problem it would be a great help. The only ideas I have at the moment are perhaps a leaking bpv as it is stock or maybe a bad maf sensor. Both of which I can switch from my wifes car to rule those out.
One again any one with experience with this some help would be awesome.
Ilovecugars is offline   Reply With Quote
Old 01-21-2013, 06:14 AM   #2
Ilovecugars
Member#: 299442
2005 Forester XT
I posted this in the tuning section in the AP category as well but I don't think there is a lot of traffic there so I thought it might be best to try and ask this here.
Old 01-21-2013, 07:41 AM   #3
tuzzio
Member#: 292532
05 STI
I'd assume that you have a vacuum leak. You should be around 14.5 at IDLE. Is your BPV/BOV leaking under vacuum?
tuzzio is offline   Reply With Quote
Old 01-21-2013, 08:51 AM   #4
Leafy
Member#: 330625
2006 WRX
Oscillating idle afr is normal. It'll also do it in cruise. This is how closed loop systems work. But it shouldnt mess up your idle. I would just check for vac leaks and post maf leaks before going back and making your tuner fix it.
Old 01-21-2013, 11:24 AM   #5
Ilovecugars
Member#: 299442
2005 Forester XT
I don't really think the tune is to blame as it has worked well for awhile on this tune. I know what you mean about the afr changing slightly at idel but it seems to be having lean spikes and that is when it is felt thought out the car.
I have checked for vac leaks already but I could have missed it, if there was a vac leak tho would I not see a high number in the a,b,c,d fuel learning tables?
I'm waiting on a new bpv ago I will be able to rule that out in a few days.
Old 01-21-2013, 11:31 AM   #6
tuzzio
Member#: 292532
05 STI
Unplug your MAF sensor and see if problem occurs. If it doesn't occur, it's a vacuum leak.
Also, it's IDLE*
Old 01-21-2013, 11:47 AM   #7
Ilovecugars
Member#: 299442
2005 Forester XT
Okay thanks I'll try that.
Hmm its seems even tho I'm on a smart phone it doesn't help my bad spelling.
Old 01-21-2013, 03:39 PM   #8
Ilovecugars
Member#: 299442
2005 Forester XT
Okay, I tried the test of unplugging the maf and running the car and this is what I have found.
When I unplugged the mad and start the car which was already warmed up the afr were locked at 14.7 andthe car ran smooth as can be. However after about 45 seconds then the car comes out of what I assume to be a sort of warm up closed loop and the afr starts to change up and down then the car started to run rough again.
Then I shut the car off plugged the maf back in and started the car again. Again the afr is locked at 14.7 and runs smooth as can be until it comes out of that warm up cycle and the afr start to fluctuate and then its almost instant it starts to run rough. So maf plugged in or unplugged there is no difference.
However I feel like I am getting closer to the problem with the roughness starting as soon as the afr's can fluctuate. But at this point I'm not really sure where to look next.
Old 01-21-2013, 03:43 PM   #9
Leafy
Member#: 330625
2006 WRX
Can you log open loop/closed loop state? Or not even log it, just read it? I bet its coming out of its start up open loop, and when it enters closed loop it has the problem. That would point to an issue with a sensor that is in use while the car is in closed loop but not open loop, IE the O2 sensor.
Old 01-21-2013, 04:01 PM   #10
Ilovecugars
Member#: 299442
2005 Forester XT
Yes I can do that, is the open loop on off category on the ap the same open loop we are taking about? So you are saying that when its first started its in an open loop at that set 14.7afr and then when it goes into closed loop is when the afr can fluctuate, that makes sense then.
I just replaced the front o2 less than 1000km ago and the car had the issue then and there was no improvement. Is there any other sensors I should check that could be at fault?
Old 01-21-2013, 04:02 PM   #11
Leafy
Member#: 330625
2006 WRX
If it start to fluctuate in closed loop and doesnt do it in open loop it can only be the o2 sensor. The sensor could be fine though, it could be a wiring issue.
Old 01-21-2013, 04:18 PM   #12
Ilovecugars
Member#: 299442
2005 Forester XT
Okay I'll have to start checking out the wiring and see what I can find.
This may be a dumb question but I might clear somethings up for me, if the car is in closed loop at idle and runs rough is the a reason why just cruising down the road in closed loop the afr are steady and everything is nice and smooth. The idle also improves when the AC is on, why does a bad working sensor seem to improve when there is load on the car? That is the only thing I can't get my head around.
Btw thank you for the help trouble shooting, things like this is not my strong point.
Old 01-21-2013, 04:28 PM   #13
Leafy
Member#: 330625
2006 WRX
That brings up a good point about cruise, I dont know. And the AC part I've seen it before and cant explain why it happens. The afr varying from 14 to 15.5 is not that bad a little bit wide than you normally see with properly functioning closed loop. The hunting idle is the weird one. I wonder, when its hunting idle is the spark advance changing or the throttle plate position changing.
Old 01-21-2013, 04:45 PM   #14
Ilovecugars
Member#: 299442
2005 Forester XT
That is what I found rather odd, from everything I've read its fairly acceptable to have your idle afr fluctuate up to one whole point and the rpm is very steady that had never been an issue. I have found if I up the rpm at idle it does improve but still not as smooth as it should be. I do see the ignition timing fluctuate a few degrees at idle, but I don't believe that will change the afr. I could be wrong tho.
