Old 01-14-2013, 03:51 PM   #1
JJL91
Member#: 320380
2012 wrx
rally blue
Just installed a cobb catted downpipe on my car a few days ago. Just wondering how this log looks. It's a 2nd and 3rd gear pull.
JJL91 is offline   Reply With Quote
Old 01-15-2013, 08:37 AM   #2
Cobb Tuning
Member#: 4803
If you can do so safely, try to get a 3rd gear pull only from 2500 RPM on up. What octane map is this?
Bill
Old 01-15-2013, 11:46 AM   #3
JJL91
Member#: 320380
2012 wrx
rally blue
Here are two third gear pulls. 93 octane map. Looks like I'm getting knock.
Old 01-16-2013, 10:32 AM   #4
Cobb Tuning
Member#: 4803
The fine knock learning appears to have been learned previously and not in these logs. Try adding the 4 knock sum values to the logs. You'll see values in these parameters (usually higher in cylinder 4), but don't be concerned with the values themselves - they are meaningless. We want to see if they increment during the WOT run.
Bill
Old 01-16-2013, 03:37 PM   #5
JJL91
Member#: 320380
2012 wrx
rally blue
No knock in this log and another one I did. So I think everything is good. Thanks for the quick reply's.
Old 01-16-2013, 04:29 PM   #6
Cobb Tuning
Member#: 4803
Looks good. You can continue logging with the knock sum to see if the fine knock learning is learned again - may have just been on lift-throttle at the end of the WOT run (that can happen at times and is just noise).
I would try to post up future logs up on google docs if possible - it can be hard to read a small screenshot like that.
Bill
