#1 |
Member#: 337037
Vehicle:03 wrx black |
So I was cruising the Internet the other day ad I came across a product called the "camber tire". It's designed with a 2,3,4 degree roll in the tire. So it no longer is square like today's current tires. So I was wondering if anyone had read anything on these? Possible bought a set and ran them? Just curious to see? I might try them out and see if they actually work, I run a -3 camber on my rear wheels on my wrx. Ill try to post a link up about it. http://www.cambertire.com/
#2 |
Visiting NASIOC Timeout
Member#: 254130
NWIC
Vehicle:2004 STI Hurr hurr |
That's pretty interesting. I haven't seen anything like that before.
#3 | |
Member#: 97135
NWIC
#4 |
Member#: 337037
I bought the car this way, and I like the flush look
#5 |
Member#: 97135
NWIC
#6 |
Member#: 337037
Well I have to be cambered for the width of my wheels to sit flush
#7 |
Member#: 87067
AKIC
Vehicle:02 Old but tasty SRP |
Because flushcar?
#8 |
Member#: 337037
You know brother
#9 |
Member#: 238173
South East
Vehicle:04 impreza JBP |
Insane stance ftw! Execution is key lol!
Anyhow, nitto neo-gens were designed for lowered cars running more than factory spec negative camber. The inner tread blocks are reinforced to handle the extra load. This seems like a whole new level of camber accommodation. |
#10 |
Member#: 337037
Giza these tires are legit! The price not so much lol
#11 |
Member#: 337037
Ill have to look into those neo gens
#12 |
Member#: 100300
Vehicle:06 WRX CGM |
First time last night I saw video of multiple cars with around 30-40 degrees of camber. It's beyond over the top. Would there be any legal issue with doing that on the US? Videos seemed to be from foreign countries.
#13 |
Member#: 254130
NWIC
#14 |
Member#: 129833
Vehicle:2005 Forester XT Obsidian Black Pearl |
It might be hard to match rolling the radius from the front to back, unless you are going to run the same camber and tire in the front and rear.
#15 |
Member#: 23561
NWIC
Vehicle:2013 Impreza CVT White |
I'm not buying the tire's performance gains. A true accounting of the tire's performance superiority would be an independent instrumented test. The closest I could find was a link to an Automobile Magazine article from 3 years ago and the editors state the article was intentionally short on specific testing, but don't say why. Usually, that means it is not a true evaluation article, but closer to one of those articles you see where the word "advertisement" is in tiny letters on the border of the article. There is no reason to NOT do a full evaluation of what looks like the most dramatic shift in tire design in 50 years, right? So it's a bit fishy in that respect.
Then, I read the article and looked at the data chart which only has 5 pieces of data on each of the 3 tires. The leaning camber tire did NOT do better than the stock tire on the Mitsubishi EVO's tires - the STOCK tires that come on it. Of 5 measurements, the leaning camber tire managed to do better in one single measurement. However, the leaning tire company also sent along another set (the 3rd set of tires in the chart). What's this? This third set - a leaning camber tire set stopped much shorter? While that's impressive, it made me suspicious because camber should not impact braking like that. So I looked again and then started laughing that Automobile Magazine would be taken in so easily. The 3rd set of tires are a race set of super sticky, super soft rubber. That short stopping distance would be expected when you use such a compound, and Automobile Magazine's own chart shows you something Automobile should have noticed themselves. The stock tires on the test EVO are the hardest tires in the test at 180. The leaning camber tires are much softer at 140, yet the stock tires STILL beat them. Then the 3rd set of leaning camber tires are the exact same tire and tread pattern, just a softer compound, and they did finally beat the stock tires. So Automobile should have realized that the already softer leaning camber tire did NOT improve on the stock tires, it was only when they used the wildly softer leaning camber tire that they got improvements. So the VERY obvious conclusion should have been that the improvement in the EVO handing was 100% due to the soft rubber compound, and 0% due to the leaning camber tire's unusual design. In full disclosure, I have no interest whatsoever in posting this, other than to help people make good tire decisions. I have never heard of these leaning camber tires until about 30 minutes ago when I read the thread. However, I have had a long career in vehicle design and also in data analysis. I see no advantage to these tires in overall vehicle performance that could not also be achieved with stickier high performance tires of a conventional design. DougM |
#16 |
Member#: 337037
I agree with what you said, but I can't say personally I haven't ran them on my car. Also, I think the only way I would run these is if I go back to running a more negative camber in the rear, as my front end is toed in to compensate for the pull to either side. I'm glad you posted all the information and didn't make a smart ass remark about the thread I has posted. And with saying that, with the career or experience you have behind you, what tires would you recommend for us enthusiasts that like to run a really negative camber. I know another member had posted about the neo gens, any other input that you may have will be appreciated.
#17 |
Member#: 272675
Vehicle:2011 WRX hatch WRB |
im so slamed bro. luk at mah tyt stanse im jdm brah. all dem civics jeluz of mah drawp. it meeks me kewl to bee low and hit all da sped bumpz.
mah camber is a sine of mah insecuriteez and i want attenshun from all da peepz. pay attenshun to me daddy!!!!!!!! in 10 yeerz i'll luk bak and c i wuz a compleet returd, ruineeng mah handlin cuz i wuz dum and taut stanse waz kewl. if only i wunt two skool and saw how returded i wuz beeing, tinkin mah wrx had sum of dat vtec yo |
#18 |
Member#: 337037
I'm glad you have an opinion
#19 | |
Member#: 307359
South East
Vehicle:'05 STi Stage II OBP |
#20 |
Member#: 272675
#21 |
Member#: 337037
I don't need ramps to get up my drive way and I clear speed bumps fine as well
#22 |
Member#: 288037
NWIC
Vehicle:2013 Orange XV 11' WRX *sold* |
Picture of your camber!
#23 |
Member#: 288037
NWIC
#24 | |
Member#: 272675
#25 |
Member#: 97135
NWIC
wait...why do you have any toe at all?
tramlining is pretty much unavoidable with wide wheels/low offsets. its easier to just get used to driving with it, instead of chewing through tires due to retarded toe settings. |
