Old 01-15-2013, 03:15 PM   #1
dartdude72
Member#: 310505
2005 Legacy GT
Default 3 port boost control solenoid question
In the search for finding out why my car suddenly runs rich, I found that the hose that goes from the compressor housing nipple to the boost control solenoid was unplugged. I also saw that the nipple on the solenoid that should have a hose going from it to the intake was also missing. I haven't seen any stray hoses that look like they would go to that so I was wondering if its possible to tune it without having that hose hooked up?
Link to my solenoid HOA Solenoid
dartdude72 is offline   Reply With Quote
Old 01-15-2013, 03:43 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If that hose is unhooked then you have a large boost leak and your wastegate has nothing allowing it to open. Your car will probably have a poor idle and boost so high it will blow itself up.
xluben is offline   Reply With Quote
Old 01-15-2013, 09:21 PM   #3
Tut4u2
Member#: 40424
05 STi
You need to have the lines hooked up.
Tut4u2 is offline   Reply With Quote
Old 01-17-2013, 04:24 PM   #4
dartdude72
Member#: 310505
2005 Legacy GT
Well it hasn't been blown up yet, I guess the build helped a lot for that. I got everything hooked up properly now. I don't think it ever had a line for the 3rd port which is odd since it was built by AWD Tuning...thought they would have done that.
Old 01-17-2013, 05:04 PM   #5
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
one port can vent to atmosphere
m1r4g3 is offline   Reply With Quote
Old 01-17-2013, 09:51 PM   #6
spoolinej25
Member#: 176392
05 STG 3 STI
Flat Black Sleeper
^ correct on my setup I have one port open to the atmosphere the nipple that is supposed to be connected to the turbo inlet. Yet I run an EWG idk if that has anything to do with it but P&L Motorsports hooked mine up like that.
spoolinej25 is offline   Reply With Quote
Old 01-18-2013, 06:39 PM   #7
dartdude72
Member#: 310505
2005 Legacy GT
Well, I found that the reason I was running rich was because I had a MAP sensor with the nipple broken off.
