Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 01-15-2013, 04:58 PM   #1
chris07sti
Member#: 177312
2005 STI
Aspen white
Default Injectors seated all the way?
I just had my injectors serviced at deatschwerks and now am reinstalling them. I put the bracket on and tightened it down but I can see a little of the top o ring still. These are pe 850 injectors. Are they tight enough? I tried tapping with a hammer to seat further but don't move. The metal lip of injector isn't touching the rail.
chris07sti is offline   Reply With Quote
Old 01-15-2013, 05:06 PM   #2
Fuel Injector Clinic
NASIOC Manufacturer
Member#: 270262
Hi Chris, are these top feed or side feed injectors that you are using on your car? I'll be happy to try and help but I just want to make sure I understand what we're looking at here.
Fuel Injector Clinic is offline   Reply With Quote
Old 01-15-2013, 05:12 PM   #3
chris07sti
Member#: 177312
2005 STI
Aspen white
These are side feed injectors
Old 01-15-2013, 05:52 PM   #4
NASIOC Manufacturer
Member#: 270262
Hi Chris, its hard to see in your photo so I'm not positive, but I did find this photo which should be a good representation of how the injectors look installed. I don't think there should be any of the o-ring showing but since we don't deal with side feed injectors often hopefully someone else can come in and confirm this info.
Old 01-15-2013, 06:10 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I see no bracket installed in that pic, can you still see the o-ring with the bracket installed? How much compared to that pic? Did you lube up the o-rings before installing the injectors?
the suicidal eggroll is online now   Reply With Quote
Old 01-15-2013, 06:33 PM   #6
chris07sti
Member#: 177312
2005 STI
Aspen white
The bracket goes over injector and bolts down.lubed with grease provided by deatschwerks
Bracket installed
Old 01-15-2013, 06:51 PM   #7
Member#: 51961
2005 STi
2012 WRX
That gap seems fine, mine always pop up a bit when I remove the brackets, just enough to get a flathead screwdriver under the metal lip. Just make sure the o-rings are seated properly, it's very easy to tear an o-ring during install and hydrolock the engine with fuel on the side feeds.
Old 01-15-2013, 07:09 PM   #8
chris07sti
Member#: 177312
2005 STI
Aspen white
So is it safe to try it? I'm just worried fuel coming out the gap and starting on fire. Is that possible?
Old 01-15-2013, 07:17 PM   #9
Member#: 51961
2005 STi
2012 WRX
Connect the green test connectors under the dash and turn the key on but don't start the car. The fuel pump will cycle on/off indefinitely. Then you can walk to the engine bay and look/listen to all of the injectors and fuel connections to make sure none of them leak. This won't let you pressure test the fuel system to the full ~65 psi that you get at WOT, but you can at least get to ~45 psi.
Message Board Statistics All times are GMT -4. The time now is 05:06 PM.
