Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 02-09-2010, 07:26 PM   #1
JeankySti
Member#: 170370
2006 STi
Precision 6262 Powered...
Default New Fuel Injector Clinic High impedance 1100cc!!!
I just received my 1100cc for my car and also got the word that they are out for the public. Here is a brief description:
The Fuel Injector Clinic 1100cc Injector is a saturated / High Impedance Ball & Seat Injector. This 1100cc fuel injector provides great trailing throttle response and minimum pulse widths resulting in a perfect cold start and idle.And, it will work with E85 or other high performance fuels. The FIC 1100cc fuel injector will fit to Jetronic harnesses. (Resistor pack removal recommended when applicable.)
This new Fuel Injector Clinic 1100cc/min @43.5psi (3Bar) high impedance injector is 22 percent larger than FIC’s similar 900cc injector (also called the 1000cc injector by others) when flowed with calibration fluid, n-heptane or similar.
(Approximately 97 percent of fuel injectors sold today are flow tested using calibration fluid, n-heptane or similar allowing for ‘apples to apples’ comparisons when upgrading or purchasing fuel injectors.)
The FIC 1100cc fuel injector fills the gap between the 900/1000cc injector applications and the 2150cc injector application.
JeankySti is offline   Reply With Quote
Old 02-09-2010, 07:33 PM   #2
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
let us know how they work
Old 02-09-2010, 07:58 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Those look like they will poke into the TGV pretty far. Will their nozzles contact anything? I'm curious to see what the spray pattern results in if they are really close to the divider between the two intake runners in the head or the divider on unported (completely) TGV's. (If I'm remembering this correctly.)
Old 02-10-2010, 03:02 PM   #4
JeankySti
Member#: 170370
2006 STi
Definitely will let you guys know how they do. The engine is out of the car we are rebuilding it. I will take pics of the injectors in the tgv.
Old 02-11-2010, 01:24 PM   #5
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
[email protected] / JR Tuned
sure the 1100s will be big enough? how much power are you looking for? what motor work are you doing?> curious i have the same turbo but i have the ID2000s
OVeRBOOSTn is offline   Reply With Quote
Old 02-12-2010, 05:01 PM   #6
JeankySti
Member#: 170370
2006 STi
This injectors should be enough to make around 550-600whp with a good fuel system. I already have drop-in cp pistons, eagle rods, arp studs, and cosworth bearing. Now Im going with 100mm Cp 9.1 compression pistons, sames rods, cosworth bearings and maybe Darton sleeves still not sure.
I already did 420whp running out of stock modified injectors and with stock fuel rails. With that I ran an [email protected] with some problems up top.
Old 02-12-2010, 10:17 PM   #7
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Default injectors
these are top feeds??pricey??
EROCS04SBRUSTI is offline   Reply With Quote
Old 02-13-2010, 01:09 AM   #8
JeankySti
Member#: 170370
2006 STi
These are top feed and they sell for a good price $445.
Old 02-23-2010, 11:23 PM   #9
Joker 13
Member#: 38669
2008 FSXT
How come I'm not seeing these on their website?
Joker 13 is offline   Reply With Quote
Old 02-27-2010, 03:14 PM   #10
JeankySti
Member#: 170370
2006 STi
They still have not updated the site I pmed you with more info!
Old 03-29-2010, 11:19 AM   #11
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Did you installed these bad boys?
gaby is offline   Reply With Quote
Old 05-16-2010, 02:12 PM   #12
gaby
Member#: 94097
[email protected]
They are great and easy to tune.
Old 05-16-2010, 02:17 PM   #13
El Guapo
Member#: 234937
2004 STi
20G'd Blue
are those bosch style clips?
El Guapo is offline   Reply With Quote
Old 05-16-2010, 02:25 PM   #14
gaby
Member#: 94097
[email protected]
They are Ford style clips. They are true bolt-on injectors but you have to change the electrical connector, included pig tails.
Old 03-27-2012, 12:26 AM   #15
jstevens
Member#: 275318
2004 Impreza WRX
How did they fit?
I don't see these at this price, is it just that the price has gone up by $50 in the past year, or am I just looking in the wrong places?
jstevens is offline   Reply With Quote
Old 03-27-2012, 01:05 AM   #16
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by jstevens View Post
How did they fit?
They do stick out of the TGV into the airstream but I don't see that as being a problem. Its better than not protruding far enough. My tuner loves them and from what I've heard, other tuners do too.
kellygnsd is online now   Reply With Quote
Old 03-27-2012, 01:05 AM   #17
kellygnsd
Member#: 32669
LINK G4 hybrid STi
How did they fit?
I'll tell you more when my car is running
Old 03-27-2012, 01:56 PM   #18
jstevens
Member#: 275318
2004 Impreza WRX
Sweet...
BTW, are you running stock ECU, or a standalone EMS of some sort?
Old 03-27-2012, 02:06 PM   #19
Badler
Member#: 133597
Looks like he's using a Link standalone.
Badler is online now   Reply With Quote
Old 03-27-2012, 02:53 PM   #20
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You are correct sir.
Old 03-27-2012, 04:21 PM   #21
jstevens
Member#: 275318
2004 Impreza WRX
K, I'm looking into these, but am not ready to make the jump away from the stock ECU.
Sorry if I missed the info on the Link standalone. I didnt' see it written, and if it was in a pic then that's why I didnt' see it (I'm @ work, & most pictures are blocked)
Edit: .... And now I see it in the vehicle info on the left, LOL. yep, I missed that.
Old 03-27-2012, 05:26 PM   #22
kellygnsd
Member#: 32669
LINK G4 hybrid STi
These injectors work with the stock ECU also.
Old 03-27-2012, 06:43 PM   #23
jstevens
Member#: 275318
2004 Impreza WRX
Sweet... Now to find wherever has them for $445 New
Old 03-27-2012, 07:59 PM   #24
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I don't think you're gonna get 2010 prices in 2012. I got mine for $495 straight from the source.
Old 03-27-2012, 08:48 PM   #25
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
The FIC 1100cc topfeeds are a nice option. We run a lot of these at the shop I work at. Dave Brown, our tuner/owner of the shop likes them more then some other options out there.
So far they are working great on pump gas and E85. We used to run the 1680cc injectors alot but they didnt hold up to pump gas. I think they are discontinuing the 1680 till further notice, but thats old news.
Ian @ Performance Auto Solutions
Fuel Injector Clinic "FIC" 625cc top feed injectors RALYGC8 Engine/Power/Exhaust 1 05-28-2010 05:07 PM
New fuel injectors. Torben Engine/Power/Exhaust 4 04-01-2008 01:14 PM
New fuel injector o-ring pack. neko Engine/Power/Exhaust 0 03-25-2007 01:48 PM
WRX fuel injectors, high or low impedance? gpd323 Engine Management & Tuning 10 04-30-2003 01:30 PM
Hooking up new fuel injector clips and KnockLink Fitz New England Impreza Club Forum -- NESIC 5 10-13-2001 10:49 AM
