Old 01-16-2013, 12:54 PM   #1
IvanFA20
Member#: 227738
16' WRX CVT
Default Close Thread!!
Close thread!
IvanFA20 is offline   Reply With Quote
Old 01-16-2013, 06:55 PM   #2
allroy81
Member#: 62260
2004 sti
2013 forester
Are you sure you greased everything? I had a similar problem, I missed a spot and my buddy went under there and found something I missed, no more squeaking.
allroy81 is offline   Reply With Quote
Old 01-16-2013, 10:41 PM   #3
IvanFA20
Member#: 227738
16' WRX CVT
I ended up spraying WD-40 on basically everything down there, and it still persists.. The squeak is really starting to annoy me.
Old 01-16-2013, 10:54 PM   #4
CraftyCraft
Member#: 340451
2008 Corvette Z06
Atomic Orange
I am a big fan of white lithium grease. Maybe you could try some of that?
CraftyCraft is offline   Reply With Quote
Old 01-17-2013, 08:43 AM   #5
allroy81
Member#: 62260
2004 sti
2013 forester
I used white lithium grease to fix mine, it hasn't squeaked in a few years now
Old 01-19-2013, 01:06 PM   #6
IvanFA20
Member#: 227738
16' WRX CVT
I just used like half a can of white lithium spraying EVERYthing down there, still squeaking... Is there anyway that one of those springs is just bad? I dont even know how I could go about replacing one of them..
Old 01-19-2013, 01:42 PM   #7
IvanFA20
Member#: 227738
16' WRX CVT
I think the culprit is this spring right here, I tried spraying it all over with WD-40 & white lithium grease and it is still the same. Any way I could easily take this thing off and inspect it??
Old 01-19-2013, 01:53 PM   #8
allroy81
Member#: 62260
2004 sti
2013 forester
My problem was actually above the gas pedal, look under there and press the clutch a little bitt with your hand, and you'll see part of the assembly moving, there's a joint there, try the white lithium grease in there.
Old 01-19-2013, 03:40 PM   #9
IvanFA20
Member#: 227738
16' WRX CVT
Yea i also tried slathering it on there with no luck
You can only hear it when i press in my clutch fast too, if I do it slow its tolerable.
