Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 01-16-2013, 06:12 PM   #1
StealthWRX
Member#: 50175
RHD Bugeye & '11LGT
Brainchild Customs
Default MODIFIED Magazine Cover - January 2013!
I wanted to start a separate thread for this cover feature so as not to confuse my build thread. Got some extra unused photos from the shoot as well from the photographer, Matthew Jones. This guy is good!
Thanks as always to all my sponsors and everyone involved with the build: Andrewtech Automotive, Piper Motorsport, TurboXS, Falken Tires, Team EMOTION, Brainchild Customs, Boomba Racing, and Congressional Bank.
Check it out, it's on newsstands now! Support print
Modified Magazine has now made the entire article available online, so If you didn't get a chance to check it out in print yet, just follow the link and be happy
LINK TO THE FULL ARTICLE
StealthWRX is offline   Reply With Quote
Old 01-16-2013, 06:13 PM   #2
StealthWRX
Member#: 50175
RHD Bugeye & '11LGT
Brainchild Customs
ENGINE
RIGHT HAND DRIVE CONVERSION
• JDM v7 STi Center Console
o Celcius-scale Climate Control Unit
o JDM-only Business Card Holder
• JDM v7 STi Front Crossmember
• JDM v7 STi Lower Dash Panels
o Passenger: Glovebox with JDM-only Map Pocket
o Driver: inc. JDM-only Rear Wiper and Headlight Leveling Switches
• JDM v7 STi RHD Pedal Assembly
• JDM v7 STi RHD Steering Rack
• JDM v7 STi RHD Steering Column and Trim Surround (inc. reversed control stalks)
• JDM v7 STi RHD Dashboard and Airbag Cover
• JDM v7 STi RHD Window Controls (inc. Master switch on right side)
• JDM v7 STi RHD Windsheild Wiper Cowl, Wiper Motor and Wipers
• JDM v7 STi VIN Plate
SHAVED/TUCKED/TUBBED ENGINE BAY
• Custom Engine Wiring Harness
o Andrewtech Custom Wired 62-pin MilSpec Connector
o Rewired Connectors/Repinned ECU
• All Unused Holes Welded Shut and Shaved & Smoothed
Relocated:
o Alternator with Custom Bracket
o Radiator Fan
o Coolant overflow and Oil Catch Tank
o Deleted:
o Power Steering
o Air Conditioning
o Brake Booster
o ABS
o Heater/Blower Motor, etc.
• Enlarged Wiper Cowl (to accommodate RHD wiper assembly)
• Aluminum Firewall (replaced 90% of oem firewall)
• Aluminum Headlight Boxes
• Shaved Pitch Stop Mount and Battery Tray
• Shaved Strut Top Mounts with Inverted Hardware
• Tubbed Front Wheel Wells
• Extensive use of Russell ProClassic II -AN hose fittings throughout engine bay
PERFORMANCE
• JDM Subaru EJ25 Aluminum Block [2.5L]
• EJ20 Cylinder Heads
o Kelford 264 Duration Cams
o Supertech Titanium Valve Springs and retainers
• Prototype Aluminum "Inverted" Intake Manifold (Custom One-off Prototype; 1 of 1)
o Designed by Alex Witkin of Brainchild Customs
o Built by Piper Motorsport
o Flipped Manifold and Inverted Runner/Plenum Design
o Tumbler Generator Valve (TGV) Shave (reduced in height by 1")
o Equal length runners
o Runners welded from inside plenum for clean look
o Custom internal velocity stacks
• Brainchild Customs 3” Turboback exhaust system (Custom One-off Prototype; PRE-PRODUCTION)
o Section welded, downturn tip
o Inspired by the discontinued Gram Light exhaust
• Boomba Racing Polished Billet Aluminum 75mm Throttle Body
o Mounted upside down to hide wires and connectors
o Tucked throttle cable
• Custom Clutch Line
• MSI Solid Billet Lower Engine Mounts (20mm Drop)
• HKS Turbo Velocity Stack
• Nitrous Express Direct Port Nitrous Kit w/ Gen-X2 upgrade
• “Race Gas On the Fly” Two Tank Fueling System (Custom One-Off; 1 of 1 in the world)
o 10 Gallon ATL Fuel Cell (Custom)
o ATL Dual Dry Break Fuel Filler Nozzle
o Weldon 1000hp External Fuel Pump
o Dual Weldon In-Line Filters (40 micron, 10 micron)
o Modfied and Flowed Subaru Fuel Injectors 780cc
o Various Russell Braided Line and AN fittings (Classic and ProclassicII)
o Check and return valves to route fuel to proper tank (tucked behind dash)
o SARD Fuel Pressure Regulator (tucked behind dash)
o Walbro 255 High Flow In Tank Fuel Pump (for pump-gas system)
• Tial 38mm Wastegate, v-band, ext. dump (wastegate body and dumptube Jethot Coated)
• TurboXS v-band Downpipe (MODIFIED turbo angle; Jethot Coated)
• TurboXS Blow-thru MAF conversion
• TurboXS DELTA Engine Management System
• TurboXS High Flow Fuel Rails (modified to fit 2.5L motor)
• TurboXS High Performance Boost Controller
• TurboXS Front Mount Intercooler (MODIFIED)
o Enlarged Cold Side to 3" Piping
o Adel Wiggins Clamps used throughout with 6 total connections
o Hidden Blow off Valve and MAF sensor
• TurboXS Racing Bypass Valve RFL (Polished)
• TurboXS Remote ECU Map Selector
• TurboXS T04R Turbo Kit 1 of 1 (Custom Prototype; PRE-PRODUCTION)
• TurboXS v2 Up-pipe
• Zero/Sports Unequal Length Exhaust Manifold (RARE)
COOLING
• ARC Aluminum Radiator (MODIFIED)
o Shaved Fan Mounting Tabs
o FAL Slimline Pusher Fan forward mounted
o Custom upper radiator endtank with -20 AN fitting
o Custom lower radiator outlet with -20 AN fitting
o Custom Aluminum Coolant Overflow Bottle (attached left side)
o Custom Aluminum Catch Tank (Attached right side)
• Cusco Radiator Cap
• Jet Hot Coating (Downpipe, ext. housing of turbo, wastegate, dumptube, exhaust manifold)
• Process West Grill Mounted Oil Cooler
OTHER/DRESS UP
• Steeda Small Billet Aluminum Oil Filler Cap (Polished)
• Piper Motorsport Oil Filler Neck (Custom)
• Custom Engine Coolant Crossover and Lower Thermostat housing to use -20 AN for upper and lower radiator fittings
• GrimmSpeed Lightweight Aluminum Crank Pulley
• Kartboy Exhaust Hangers
• Prova Brake Fluid Cap (Custom Polished)
• Prova Clutch Fluid Cap (Custom Polished)
TRANSMISSION/DRIVETRAIN
• Pfitzner Performance Gearbox (PPG) Dogbox Gearset [Straight cut 1-4, stock 5] (FIRST ONE IN UNITED STATES)
o PPG Billet Dog Engagement Gearset with Custom Gear Ratios
o PPG Billet Shift Forks
o PPG Billet Interlocker
o PPG Brass Speedo Gear
• Drive Shaft Shop Level 5 800hp Front Axles
• Drive Shaft Shop Level 5 800hp Rear Axles
• Drive Shaft Shop Lightweight 1 pc Aluminum Driveshaft
• Energy Suspension Shifter Bushings
• B&M Short Throw Shifter
• Cusco Solid Transmission Mount
• Exedy 3-Puck Racing Clutch
• Exedy Flywheel
SUSPENSION/BRAKING
BRAKES
• StopTech Front Big Brake Kit (4-piston ST-40 Caliper, 355mm 2 piece rotor) (Custom Coated)
• StopTech Rear Big Brake Kit (2-piston ST-20 Caliper, 328mm 2 piece rotor) (Custom Coated)
• ABS and Brake Booster Delete
• Brake Booster Delete Plate
• Custom Front Brake Lines
• Custom Rear Brake Lines
• Custom Brake Line (Master Cyl to Prop Valve)
• Wilwood Master Cylinder
• Wilwood Brake Proportioning Valve
• Stoptech Brake Fluid
• Hawk HP Brake Pads
SUSPENSION
• Beatrush 12-point Aluminum Subframe (Polished)
• Beatrush Front Compliance Brackets
• Cusco Front Sway Bar
• Cusco Rear Sway Bar
• Cusco Front Sway Endlinks
• Cusco Rear Lateral Links
• Cusco Front Lateral Links
• Cusco Trailing Arms
• Energy Suspension HYPERFLEX Master Bushing Kit
• Front Control Arm Bushings
• Rear Trailing Arm Bushings
• Front Sway Bar Bushings
• Rear Sway Bar Bushings
• Perrin Rear Sway End Links
• STi Aluminum Front Control Arms (Custom Coated)
• TEIN Type FLEX Coilovers w EDFC
INTERIOR/ELECTRONICS/SAFETY
SAFETY
• AP Racing Air Jack System (1 of 1 - Only known fully-enclosed, onboard system in the world)
o Custom install by Piper Motorsport
o 4 x AP Racing Aluminum Air Jacks (tied into cage)
o Russell Performance Hard Air Line (Blue)
o Distribution Block with Raise/Lower controls (Custom One-off; 1 of 1)
o Modified Nitrous Express 10lb. Bottle to power system (Custom One-off; 1 of 1)
• Piper Motorsport 9-Point JGTC/WRC Style Roll Cage
o Full gusseting on A and B pillars, cross bar, door bars, and along roof line
o WRC-spec mounting boxes
o Integrated rear strut “V” brace with integrated fuel pump and filter mounts
o Custom mounts for 2 x Nitrous Express Bottles
• Battery Relocation to Trunk
o Piper Motorsport Aluminum Battery Box (Custom One-off; 1 of 1)
o Optima Red Top Battery
o Sparco Battery Master Kill Switch
o Griot’s Garage Battery Manager III
• BRIDE Stradia II LowMax Seats - Carbon Kevlar
• BRIDE Seat Sliders (Driver and Passenger)
• Piper Motorsport Aluminum Trunk Floor Trim and Fuel Cell Firewall (Custom One-off; 1 of 1)
• SpA FIRESAFE Electronic Halon Fire Suppression System
o Bottle mounted behind rear firewall
o Bottle control unit on center console
o 2 nozzles in passenger compartment
o 2 nozzles in trunk for fuel system
• Takata 340mph 4-pt Racing Harnesses
• Tow/Tie Down Hooks - Custom welded to chassis (2 in front, 2 in rear)
ELECTRONICS/DATA MONITORING
• STACK ST81101sr Programmable Digital Dash Display
o Tachometer sensor
o Wheel Speed sensor
o Water Temp sensor
o Oil Temp sensor
o Oil Pressure sensor
o Fuel Pressure sensor
o Exhaust Gas Temp sensor
o Battery Voltage
o Infrared Lap Timing sensor
o Boost pressure sensor
o Fuel level sensor
o Odometer
• Blitz FATT 2 Dual Turbo Timer
• Defi Link EGT Gauge
• Defi Link Fuel Pressure Gauge
• Defi Link Boost Gauge
• Defi Link Gauge Controller
• Wire thinning and tuck throughout interior
• Removed unnessecary wires and connectors
• Rerouted remaining wiring in Milspec looms
OTHER/DRESS UP
• JPM Coachworks - Black Alcantara Wrap w. Red and Black Contrast Stitching:
o Full Right Hand Drive Dashboard with airbag cover
o Glovebox
o Lower Dash - Driver side
o Center Dash
o Gauge Hood
• AeroSpace Components Billet Aluminum Nitrous Bottle Brackets x2
• Beatrush White Delrin Shift Knob
• Carbon Concepts Center gauge pod
• DZUS Fasteners for quick removal of interior paneling
• Piper Motorsport Aluminum Center Console (Custom One-off; 1 of 1) With mount for:
o Fire suppression nozzles, control unit, and activation switch
o Battery kill switch
o Instrument Cluster Control Switches
o Toggle switch for dual fuel system
• Piper Motorsport Aluminum RHD floor pans with grip tape (Custom One-off; 1 of 1)
• Prodrive WRC Rally-Spec Carbon Fiber Molded Front Door Cards (designed for cage clearance)
• Prodrive WRC Rally-Spec Carbon Fiber Molded Rear Door Card
• Prodrive WRC Rally-Spec Carbon Fiber Rear Bulkhead/Firewall
• Prodrive WRC Rally-Spec Carbon Fiber Rear Parcel Shelf
• Prodrive WRC Rally-Spec Carbon Fiber Rear Seat Trim Panel
• KEYS! Racing - 325mm Semi-Cone Suede Steering Wheel
• Works Bell Short Steering Wheel Hub Adapter
• Works Bell Rapfix Steering Wheel Quick Release - Yoshioka Special Edition
• ZeroSports Leather Shift Boot
IN CAR ENTERTAINMENT
• Pioneer AVIC-D1 In-Dash Touch-Panel DVD Multimedia AV Navigation Receiver
• Polk Audio speakers (x 2; 4") (Painted)
• TommyKustom molded fiberglass enclosure in glovebox (paint matched)
EXTERIOR
PAINT
• Exterior - paint by Dale E. @ Old School Enterprises
o Custom mixed Ferrari Rosso Corsa (Traditional Ferrari Racing Red)
o Shaved engine bay
o Shaved door sills
o Shaved antenna
o Shaved sidemarkers
o Custom molded rear door trim
• Interior - paint by Dale E @ Old School Enterprises
o Fully resprayed
o Ferrari Rosso Corsa inner roof, pillars, and roll cage
o Rosso Corsa inner floors and trunk space
• Other painting and Coating
o Paint matched:
 Interior
 Engine bay
 Hood Dampers
 NX Bottles
 Speaker Enclosure
o Painted:
 Engine Block
 Engine cradle
 Cylinder Heads
 Windshield Wipers
 Trunk Floor
o Powder Coated:
 Transmission Case
 Clutch Master Cylinder
 Alternator
 STi Control Arms
 Coolant crossover
 Uppipe Brackets
o Polished:
 Valve Covers
 Intake Manifold
 Alternator Bracket/Pulley
 Intercooler Piping
 PCV Block-off plates
 Intercooler Endtanks
 Radiator and integrated catch can & coolant overflow
 Fluid Reservior Caps
 Beatrush Front Subframe
 Blowoff Valve
 Turbo Compressor Housing
 Fuel Rails
 Oil filler Cap and Neck
o Jet-Hot Coated:
 uppipe
 Downpipe
 Wastegate dump tube
 Exhaust manifold
 Turbo Exhaust Housing
AERODYNAMICS/BODY
• Chargespeed D1 20mm Widebody Front Fenders (shaved markers)
• CWEST Rear lip v1
• CWEST v2 Front Bumper (alternate for Street/Shop/Winter)
• Do-Luck Carbon Fiber Duck Tail Trunk Lid (2nd in US to have)
• Prodrive WRC Rally-Spec Carbon Fiber Side Mirrors
• RAYS Engineering Gram Lights Door Trim Pieces (molded) (1 of 1 in United States)
• RAYS Engineering Gram Lights Front Bumper with Carbon ducts (1 of 1? in United States)
• RAYS Engineering Gram Lights Side Skirts (1 of 1 in United States)
• Subaru JDM OEM STi Projector Headlights
• Varis Vented Carbon Fiber Hood with Molded Scoop
• Voltex Type V Carbon Fiber Wing
• Custom 245mm Titanium Wing Risers by Iparkharder Designs
OTHER/DRESS UP
• Quick Release Front Bumpers
o DZUS fasteners for quick removal of bumper
o Able to Swap between my two bumpers using the same DZUS connections
• Plastics4Performane Custom Molded Polycarbonate Window Kit
o 4mm molded rear screen
o 5mm molded front door windows (with lexan sliders)
o 5mm molded rear door windows
• PIAA Wiper Blades
• Rolled rear fenders
• Subaru JDM OEM Door Visors
• Subaru OEM Weathertrim kit (ALL NEW)
• TEIN Hood Dampers (custom painted)
WHEELS AND TIRES
WHEELS
• BBS 3pc Forged Aluminum e88 Race Wheels [18x9.5 ET35] (Custom; 1 of 1) (Show/Street Use)
o Custom painted faces: Antique White
o Custom Spoke profile [specifically designed to clear the custom stoptech brake system]
• Rota Torque R [18x9.5 ET35] (White)
TIRES
• Advan A048 R-Compound Semi-Slick Tires [265/35/18] (Show/Street Use)
• Falken FK452 [255/40/18] (Shop/Winter Use)
MISC. WHEEL ACCESSORIES
• ARP Extended Front Wheel Studs
• ARP Extended Rear Wheel Studs
• 5Zigen ProRacer+ Lug Nuts (Extended, Open ended; Blue)
VEHICLE TUNING SETUP
TECHS
• Mechanical, Wiring, Assembly: Andrewtech Automotive
• Fabrication and Race Prep: Piper Motorsport
TUNING
• TurboXS Custom Dyno Tuning: Jermaine Riddick
• 403WHP @ 20psi, 93 oct. pump gas (OLD TUNE)
Old 01-16-2013, 07:50 PM   #3
vms150
Member#: 172917
2004 WRX
The only thing I like about that car is the super clean engine bay.... but that's just one mans opinion.
Seriously though, Congratulations on grabbing a cover and a full spread!
vms150 is offline   Reply With Quote
Old 01-16-2013, 09:58 PM   #4
1VIPWRX
Member#: 107554
yellow
awesome car..
1VIPWRX is offline   Reply With Quote
Old 01-16-2013, 10:36 PM   #5
Boost is Best
Member#: 102858
2015 WRX
ISM
Which Airjack system are you using?
Boost is Best is offline   Reply With Quote
Old 01-16-2013, 10:39 PM   #6
EM2Brande
Member#: 186815
91 MR.Two
Red
This is what... The 3rd transformation. Claps hand to you sir. I have loved all 3 looks this car has had.
EM2Brande is offline   Reply With Quote
Old 01-16-2013, 10:44 PM   #7
JON-E25WRX
Member#: 225389
03 WRX MBPwidebody
rotated 35R VOLTEX bugeye
wow O.O that bay doh
JON-E25WRX is offline   Reply With Quote
Old 01-16-2013, 11:08 PM   #8
fantabulous
Member#: 57364
05 Saabaru
Congratulations, Alex. I was reading it at the airport last week. Very cool
fantabulous is offline   Reply With Quote
Old 01-16-2013, 11:13 PM   #9
silverwerx
Member#: 81246
. .13 EVO X MR
.03 Cosworth Wrx, 14 Jeep
ap racing yo!
silverwerx is offline   Reply With Quote
Old 01-16-2013, 11:20 PM   #10
silverwerx
Member#: 81246
. .13 EVO X MR
btw this car is just alright i mean my car is way better and stuff duh. plus this car doesnt even have a cano installed like mine does soooo where can you pack it? wtf? you really should consider the pack it mod and stop wasting your money on stupid stuff like jdm bling and air jacks or super clean shaved engine bays. s*** make the car run on sour diesel instead of gas now thats a sick f'ing mod yo, probably pickup like 800whp plus it would smell uber bomb. this is my 2 cents though i mean think about it. not everyone can be a baller like me i know everyone try's and im not trying to jack your thread or nothing but from a friend to a friend bro, pack it mod ftw. stop wasting your money on all these "cool" mods and just make the car run on sour diesel. i heard its the ish, and if you dont concider yourself un-friended on facebook AND XBOX. this is real s*** dont test me our friendship depends on this!!!!!!!!!!!
Old 01-17-2013, 01:02 AM   #11
SubyStud555
Member#: 185048
07 Legacy Spec B
06 SGM Sti
SEX
SubyStud555 is offline   Reply With Quote
Old 01-17-2013, 04:13 AM   #12
Miguel_D
Member#: 339036
2007 B9 Tribeca
Cool!
Miguel_D is offline   Reply With Quote
Old 01-17-2013, 07:14 AM   #13
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
awesome! congratulations! overall some amazing work, engine bay looks stunning. not everything is my style, but i respect how much has gone into it. What are your plans for this car now? keep adding/modifying things? strip it down and start over? start a new project?
VTSubieRS is offline   Reply With Quote
Old 01-17-2013, 08:49 AM   #14
Hate
Member#: 304868
2015 WRX
I believe he said this is how the car will ultimately sit and that he is never getting rid of this thing. Thank god because it's stunning in every form you've had it in and it would be nice to see someone not finish a car and the next day part it out or sell it.
Hate is offline   Reply With Quote
Old 01-17-2013, 09:40 AM   #15
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
Congrats!
old_duwel is offline   Reply With Quote
Old 01-17-2013, 11:27 AM   #16
BrendanTheGreat408
Member#: 271207
2011 WRX
nothing but sickness. fantastic build and congrats
BrendanTheGreat408 is offline   Reply With Quote
Old 01-17-2013, 01:09 PM   #17
mkvaron
Member#: 326317
2011 WRX hatch
SSM
A stunning piece of work!!! Congrats!!! SOOOOO jealous of those air jacks haha, that would make swapping my wheels on/off a breeze haha
mkvaron is offline   Reply With Quote
Old 01-17-2013, 10:23 PM   #18
StealthWRX
Member#: 50175
RHD Bugeye & '11LGT
Brainchild Customs
Thanks guys! I am well aware that this won't be everyone's style, but I truly appreciate the fact that most people can understand and respect how much work goes into creating something like this.
I don't think I could ever part this car out, I'm the original owner of the car and I will likely own it for the forseeable future. I may change a few things, but probably not going to evolve much past this point. I need a bit of break from it to be honest. My goals for this coming year are to sort out some minor issues and just enjoy the car, drive it on the weekends etc.
About the airjacks, as silverwerx said, its an AP racing airjack system customized to run off of a modified nitrous bottle. Each jack weighs less than 1lb!
Old 01-17-2013, 10:57 PM   #19
leokatero
Member#: 343897
leokatero is offline   Reply With Quote
Old 01-17-2013, 11:23 PM   #20
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
Your car is unreal, and so are the pictures.
Thank you for sharing this automotive porn. Please never stop building cars.
JSchell1309 is offline   Reply With Quote
Old 01-17-2013, 11:29 PM   #21
yetogetanrs2
Member#: 153106
All that "pretty stuff" and only 403whp?.....not impressed
yetogetanrs2 is offline   Reply With Quote
Old 01-17-2013, 11:30 PM   #22
ScoobySubyDoo
Member#: 329311
2003 WRX
Satin Black
OMG ENGINE BAY AND AIR LIFTS. Seriously, the engine bay looks so sweet
ScoobySubyDoo is offline   Reply With Quote
Old 01-17-2013, 11:30 PM   #23
Serge777
Member#: 163573
SILVER STAGE 2
God Bless America!!!!!
Serge777 is offline   Reply With Quote
Old 01-17-2013, 11:31 PM   #24
Strawhatrr
Member#: 267395
I can only imagine how cool it must be to stroll through a Barnes & Noble, or drug store or something and look through the magazine section and know that car on the cover is tucked away in your garage.
Must be nice. lol
Strawhatrr is offline   Reply With Quote
Old 01-18-2013, 01:54 AM   #25
StealthWRX
Member#: 50175
RHD Bugeye & '11LGT
Brainchild Customs
thanks for the feedback. This car wasn't designed to break any HP records. And to be fair, that dyno figure was over 7 years ago and before the heads, cams, intake manifold, exhaust manifold, and many other bits.
