Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-21-2013, 09:14 PM   #176
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
I just love your build. You have basically the same setup I want on my next project. Rotated is the way to go.
Slimsti is offline   Reply With Quote
Old 12-29-2013, 01:47 AM   #177
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Car is back in my possession Unfortunately it has a hg failure Went with the oem subaru HG with this build, so not sure what I should use when I change it out. Recommendations?
Going with some new built heads from Curt Brown (the recent TPG build showed off his awesome work)...full bowl blend port, ferrea valves, gsc beehives, gsc s1 cams, etc. Curious how you all think this will effect the power band I'm hoping to keep low end good, but let it breathe more. If I can hit the same power at 25psi that would rock!!!
I'm also debating whether to swap out the rods, since I just have manley h-beams. Kicking myself for not requesting i-beams with the Rallispec block
pet3r is offline   Reply With Quote
Old 12-29-2013, 02:16 AM   #178
rustler753
Member#: 372764
Same boat as me. What pressures were you running daily that lead to failure?
1) Go with the I-beams...I did and grateful looking back at all the money I've spent on the block. If you are dropping it for headwork, might as well. You still have the potential for failure at 500whp+ for h-beams, it'll be something less to worry about
2) My builder at ASF Machine recommended to go with a +1mm exhaust size and leave intake alone on valves. That coupled with headwork should shift power slightly to the left if anything.
Similar builds that I've seen have done 500whp+ at 25psi with no headwork, so there is that.
rustler753 is offline   Reply With Quote
Old 12-29-2013, 02:29 AM   #179
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
It had peak at 29psi, but really didn't see it much. I had sold the car to a friend, and he ran it around 25psi max on E85. The last month he was driving on 93pump around 20-21psi I believe. So the pressure's weren't huge
I spoke with guys at Headgames and he said that +1 valves are really unnecessary, unless you want to push 800hp. I don't
Old 12-29-2013, 12:59 PM   #180
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Go with stock hg again, it wasnt the fact it was a stock head gasket that caused the failure,do not go with the cometic, and not sure I would even trust the cosworth as well as oem hg, try it again maybe with a more rep. builder or ask for more precise work done and ask to be shown clearances or make sure torque plates are used during honing and all that
Thats odd about the headgames comment of +1 not being needed til 800hp, it helps velocity with a decent sized turbo, & I'm SURE it helps at 550+whp
Irv Weissmanhowerton is offline   Reply With Quote
Old 12-29-2013, 04:11 PM   #181
bjohnson_55
Member#: 216580
Good info. Just adding a couple things. Definitely true about not using cometic. Im not a fan either.
Make sure the builder understands the importance of a good surface finish for the hg to mate properly. You should be fine with standard arp studs.
bjohnson_55 is offline   Reply With Quote
Old 12-30-2013, 01:53 PM   #182
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Stock head gaskets.
Stock size valves.
I beam rods.
ARP 625+ headstuds.
xluben is offline   Reply With Quote
Old 12-30-2013, 06:13 PM   #183
HeadGames Motorworks
Member#: 323899
we make double that with stock size valves (1k whp)
Stock size valve flows better at lower lifts, and the 45 degree seat angle is not at the edge of the seat as it is with the 1mm.
HeadGames Motorworks is offline   Reply With Quote
Old 03-10-2014, 09:30 PM   #184
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Car is under the knife now...lots of updates coming from the original build.
We pulled the engine for the HG failure and had very poor leakdown results. Everything looked fine though...no scoring, pistons looked good, cross hatch was there, oil was clean, no consumption either. We decided to open the block because the leakdown was so bad and just rehone with new rings to make sure it was fine.
My 704 case halves were out of round when we went to re-hone. I've never heard of this so I'm not sure what to think :/ Cosworth pistons had some damage at the wrist-pins and the machine shop said they probably shouldn't be used. I took this as a hint to build a better block that can handle the power
Changes coming:
-Outfront Motorsports closed deck block
-full ported W25 heads from Curt Brown
-ferrea valves, gsc beehives, GSC S1 cams, CA65 head studs
-new CP pistons @ 9:1 CR, Manley I-beams, fully balanced to .25g
Next week will be a good week...fingers crossed.
Old 03-10-2014, 09:36 PM   #185
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Out-of-round is proly from the machine work being done without a TQ plate
This time around I'd upgrade the piston pins to Tool Steel or another stronger pin
Old 03-10-2014, 09:46 PM   #186
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Originally Posted by Paul View Post
Out-of-round is proly from the machine work being done without a TQ plate This time around I'd upgrade the piston pins to Tool Steel or another stronger pin
No torque plates on original bore or from the new home?
Which pins do you recommend?
Old 03-10-2014, 09:53 PM   #187
Paul
Member#: 56203
00 RSTI Coupe
IDK what that means but I doubt Rallispec used plates on your previous motor
For the pins ask your builder or piston manufacture for a stronger pin and they will hook you up
Old 03-10-2014, 10:26 PM   #188
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
What head studs were you running?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-10-2014, 11:00 PM   #189
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Thanks Paul.
EQ - was running standard arp studs before.
Old 03-11-2014, 12:32 AM   #190
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks Paul.
Might be part of the problem. I've seen a couple instances of heads lifting with high boost on standard ARP's. Switched to MAP H11 studs and no more problems.
-- Ed
Old 03-11-2014, 12:33 AM   #191
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Yep, thats why I bought CA65 studs
Old 03-12-2014, 11:36 PM   #192
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Look what came today Thanks Outfront!
Old 03-13-2014, 12:32 AM   #193
NA STI
Member#: 285083
2006 STi
Looks good man, sounds like you doing it right. Good luck with the rebuild process
NA STI is offline   Reply With Quote
Old 03-13-2014, 10:23 AM   #194
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
702 case. I like.
Old 03-13-2014, 10:33 AM   #195
subbi7
Member#: 241967
02 wrx
There are any difference between the blocks (702,703,704)?
Sorry if it anoob question...
subbi7 is offline   Reply With Quote
Old 03-13-2014, 10:51 AM   #196
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
The latest 704 castings have been known to be weaker and crack more easily. Happy I got a 702 as well
Old 03-13-2014, 11:48 AM   #197
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Excellent choice on the short block.
I ended with a 702 casting as well which I was happy about.
What specs did you have yours built to?
WRXt4cy is offline   Reply With Quote
Old 03-13-2014, 11:54 AM   #198
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Their standard bore is 99.75, you actually can't order it at 99.5 from what they told me. Don't know how much more you could customize a block
Old 03-13-2014, 12:21 PM   #199
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Got the upgraded wrist pins on order. Called CP, they gave me 3 different options, all of which are a tool steel material with a hardened surface, but 3 different wall thicknesses:
-190 wall
-200 wall
-260 wall
I went with the 200, hope it won't be too heavy. They told me to call Race Engineering and gave me the part # for anyone interested: 905-2500-20-CP3S
Old 03-13-2014, 01:59 PM   #200
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I assumed they were assembling a whole bottom end for you and this was just a picture of the case halves for you build. My mistake.
Let me rephrase: What specs are you building it to?
The only other option you might have opted for would be the machining for 1/2 studs but I'm guessing you skipped that.
