#1 |
Member#: 341981
Vehicle:2008 STI Charcoal |
I'm still sorting through some things on my car. When I had the air cleaner out tonight, I noticed there was a wiring harness with two connectors underneath it inside the passenger fender well. There is a large two wire connector that looks similar to the one the smog pump plugs into, and then there is a smaller one beside it that looks more like the size of a micro usb cable end. What used to be plugged into these plugs? The car is an 08 STI. It's not for the fog light, because that is plugged in, but they are right behind the fog light.
#2 |
Member#: 342941
Vehicle:2008 Impreza WRX Black |
Is it a yellow wire and a black (ground) wire together?
And does it appear to be a male end? |
#3 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
the daytime running lights relay?
#4 |
Member#: 341981
The large gray plug has a green and a white wire. I don't remember what the smaller plug had going into it. The big gray one was female. The smaller one I figured out. It fell off of the horn. They are both on the same subharness that comes from the headlight and radiator fan. I tried to take a pic of the gray one, but it didn't turn out very good.
