Old 01-25-2013, 08:45 AM   #26
Girion47
Member#: 240113
2010 WRB WRX 5dr
2013 DGM WRX 4dr
Originally Posted by Darth Wagon View Post
THIS!
My sister had an A4 and IIRC, in order to turn on the rear fog you had to first rotate the headlight switch to turn on the lights then pull the knob out wards one click to turn the front fogs on and then to the second click to turn on the rears. How these people drive around all the damn time with the rears on is beyond me.
My old Volvo had a dedicated switch for the rear fogs. Way better solution I think.
on mine there's a button above the radio. well two buttons actually, one turns on the front's only, and the other turns on front/rear. So if someone is tailing you it feels very bondish to reach over, push a button, and then see the car behind back off 50 ft automatically.
Girion47 is offline   Reply With Quote
Old 01-28-2013, 02:14 PM   #27
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Here's a closer up pic of my foglight installed. From a few feet away it looks great, up close the silicone I used around the edge of the cutout looks a little rough. I plan to try to clean it up a bit.
Also, when wiring the light up I used a male/female connector I found at Pepboys so I can disconnect the light if I need to remove the bumper.
atf78 is offline   Reply With Quote
Old 01-29-2013, 01:04 AM   #28
Girion47
Member#: 240113
2010 WRB WRX 5dr
2013 DGM WRX 4dr
I bet a small rubber strip around that would provide a great looking frame for the light.
Old 01-29-2013, 03:06 AM   #29
AaronCKC
Member#: 338621
2013 WRX Limited
Satin White Pearl
Wow cant wait to see it. been thinking about this mod
AaronCKC is offline   Reply With Quote
Old 01-30-2013, 07:46 PM   #30
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
It just arrived in the mail yesterday and Ill try to get some pix up once I get it bolted and wired up
wirthless is offline   Reply With Quote
Old 02-03-2013, 12:02 PM   #31
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
Ok I did it today and I just need to upload the pics , give me a little bit
Old 02-03-2013, 12:09 PM   #32
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Satin White Pearl
This is a very neat looking mod. Can't wait to see some more pics!
Decipher is offline   Reply With Quote
Old 02-03-2013, 01:30 PM   #33
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
pictures and write up posted
Old 02-03-2013, 04:33 PM   #34
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
I found this thread very interesting and thats a pretty cool idea, I never thought of a rear fog light.. I know this is off subject but is there a difference in body between 08+ Sti hatches?
SubieSnacks02 is offline   Reply With Quote
Old 02-03-2013, 06:38 PM   #35
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
08+ STI hatches and 11+ WRX hatches all have the same rear bumper.
Looks good wirthless, any night pics with it lit up?
Old 02-03-2013, 07:41 PM   #36
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
I will post some maybe later bc I'm hosting a Super Bowl party right now
Old 02-03-2013, 07:45 PM   #37
ixwrxxi
Member#: 334215
2015 Forester
I don't see any pictures?
ixwrxxi is online now   Reply With Quote
Old 02-03-2013, 08:05 PM   #38
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
1st page and post
Old 02-03-2013, 08:26 PM   #39
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
Is there any difference exterior and interior wise? Through out 08+, just Sti hatches
Old 02-03-2013, 08:47 PM   #40
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
Originally Posted by wirthless View Post
OK So seeing this car inspiried me to add a rear foglight for my 2013 WRX
I just ordered this from ebay and Ill do a write up on it, should be pretty be pretty straight forward:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=140899894960
Its all red and Im going to tint it , but they also make them clear as well
1st remove your outsude taillight using a big Phillips head screwdrivier, electrical tape, grab some extra speaker wire along with (2) wire taps, (2) zip ties and (2) but connecters for the wire. You will need the but connecters so extend the ligth wires to reach the taillight harness, and the ire taps to tap into the Green(power wire) and Black(ground) of the 194 bulb connection in the taillight harness. the zip tires are to secure the wires to anything you see fitting to hold the wires in place so there isnt any issues in the future, same as the electrical tape, make sure you wrap all 4 connections to insure that no moisture gets into your wiring.
So I Started by measing the rear section which on the top side is 4", So I cleaned off:
And I was undecided to run the light i bought Horizontally bc it just flowed better in my eyes light the 2 rear reflectors:
I measured for the center bolt whole to be 2" centered and about 3/4" down from the center point:
Then i drilled 2 holes, one for the wiring(3 wires) and one for the center mounting bolt:
I had some extra double sided tape from one of my old Hid ballasts so I trimmed it to fit:
Then I extended the wires with some extra speaker wire I had lying around and cripped and taped them up with electrical tape, for the power I tapped into the 194 bulb on the passenger outside taillight. You can use either the driverside or passanger side.
There are 3 wires that came with my light, Blue(dimmer lighting), Red (brighter lighting), and black for ground, I selected to use the dimmer light(I liked it for my application, its up to you for your application)
I then tightned down the 10mm bolt and washer that it came with, then tested it out off and on, I just did it so I dont have a night shot yet but I will add some when it gets darker out.
ON:
There you go Ladies and Gents, its not too difficult.. But it is a nice simple exterior mod !!
So glad I did it , just need to take some pix at night and I'm also planning on tinting the light so it won't look like its there during the day , and mainly see it night
Old 02-03-2013, 09:22 PM   #41
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
Couple night shots:
Old 02-03-2013, 10:20 PM   #42
SubieMonte
Member#: 264803
2005 WRX Wagon
Couple night shots:
Why wouldn't you have white? Seems like it would like up more.
SubieMonte is offline   Reply With Quote
Old 02-03-2013, 11:00 PM   #43
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
I chose to go with red to make it look oem and not too aftermarket and if you want more light you can hook up the red wire (brighter) vs choosing the blue wire (more dim) . They do sell the same setup with a white lense , just wasn't what I personally was looming for
Old 02-03-2013, 11:04 PM   #44
SubieMonte
Member#: 264803
2005 WRX Wagon
Gotcha. That's cool too. I'd like white because I have (no too) tinted windows but sometimes it's dicey. I might get a more intense reverse bulb or two instead. It's winter here in Michigan so I will add it to the spring list!
Old 02-04-2013, 02:19 AM   #45
Trunx
Member#: 341122
2013 wrx
dgm
Agreed. I like the shape of this light more but it is bulky and can't really stick on the exterior of the bumper. Wonder if they have that shape but thinner?
Trunx is offline   Reply With Quote
Old 02-04-2013, 01:54 PM   #46
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
bump....
Old 02-04-2013, 09:08 PM   #47
scx89
Member#: 269388
2011 Impreza WRX
obp
looks awesome
scx89 is offline   Reply With Quote
Old 02-04-2013, 09:56 PM   #48
philip0415
Member#: 345965
2006 WRX Wagon
looks great
philip0415 is offline   Reply With Quote
Old 02-05-2013, 06:28 AM   #49
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
Originally Posted by scx89 View Post
looks awesome
Thank you
Old 02-05-2013, 06:29 AM   #50
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
Originally Posted by philip0415 View Post
looks great
It's a nice cheap and easy mod that I think is well worth it
