Old 01-18-2013, 09:39 AM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default strange misfire....
On my girlfriends car, a 98 subaru legacy gt with a dohc 2.5l, its got a cylinder 2 misfire. So I did the usual, plugs, wires, ignition coil, front O2 sensor and some fuel injector cleaner. No change at all.
The car has 160k miles on it, headgaskets both done at 155k miles, both valve cover gaskets have been changed. Basically the car should be in great shape. Fuel filter was even replaced about 4k miles ago. I'm at a loss.
sorrowfulkiller is offline   Reply With Quote
Old 01-18-2013, 10:58 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Years ago, on my then stock '97 2.5GT, I had a misfire on #2 that turned out to be a burned exhaust valve. A problem with plug wire or plug is much more common, but since you've already done all the "normal" stuff, it could be something mechanical.
That was at 50-something thousand miles, so it's certainly not hard to imagine that the same sort of thing could happen on an engine with 3x as much mileage.
Pat Olsen
Old 01-18-2013, 12:12 PM   #3
chickennecks?
Member#: 247605
2002 impreza ts
I'm in the exact same boat. So what exactly causes a burnt valve, and what's the fix?
chickennecks? is offline   Reply With Quote
Old 01-18-2013, 04:59 PM   #4
sorrowfulkiller
Member#: 170439
I <3 Lamp
Say it isn't so! Eh oh well. She can drive it til it breaks.
Old 01-20-2013, 11:15 PM   #5
myslowgrandmacar
Member#: 316137
2008 Impreza 2.5i
Pearl Blue
I am also currently having misfire issues. I am already in the process of changing out all the usual culprits but I am going to have a hard time troubleshooting because it's not something that is happening on a consistent basis. Hoping it is not the worse case which is valve issues.
myslowgrandmacar is offline   Reply With Quote
Old 01-20-2013, 11:18 PM   #6
boostjuice
Member#: 89492
2006 STi
Grounding kit? Heard it helps with this type of stuff - Im getting random misfires as well and the Grounding Kit is next on my list
boostjuice is offline   Reply With Quote
Old 01-21-2013, 09:59 AM   #7
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Have you checked the resistance of your fuel injectors with a multimeter? Should be 11-12 iirc.
monkeyposeur is offline   Reply With Quote
Old 01-26-2013, 01:26 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
When does the misfire happen? Under load, coasting, warm out/cold out, wet out/dry out?
Also check the intake manifold bolts, they can loosen up a bit.
Old 01-26-2013, 01:34 PM   #9
sorrowfulkiller
Member#: 170439
I <3 Lamp
misfire happens at low load and idle situations only. Under high load all i well.
I'll have to check into injector resistance.
