Old 01-18-2013, 10:26 PM   #1
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Default how do you scale your maf?
Just looking for some other strats to maybe open my mind...
Jeffman44 is offline   Reply With Quote
Old 01-19-2013, 08:19 AM   #2
Bizko1288
Member#: 151260
2005 Sti
423whp/422wtq on 93
Bizko1288 is offline   Reply With Quote
Old 01-19-2013, 02:27 PM   #3
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Yea I've been using that method as well, at least the maf scaling function in romraider that does all the work for me haha. I was more interested in the 2.5v and higher. Anything easier than logging and just doing trial and error? I was thinking along the lines of maybe making fueling static at a safe value like say 11 afr across the whole table. forcing open loop 24/7 to avoid learning being an issue, and then any values in my logs that aren't 11 could be attributed to maf scaling. I haven't tried it yet because im a little uncertain. does that sound like a good idea?
Old 01-19-2013, 06:25 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
closed loop -- romraider has pretty decent tools already built in. I believe these are based largely on willaty's methods.
open loop, load WOT runs into airboy along with the correct fuel map. Then copy to Bad Noodle's MAF spreadsheet.
Concillian is offline   Reply With Quote
Old 01-19-2013, 09:57 PM   #5
Jeffman44
Member#: 239072
2005 WRX Wagon
white
Ahh yea I forgot about those spreadsheets. Do you think my method would work though?
Message Board Statistics All times are GMT -4. The time now is 07:36 AM.
