Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 01-19-2013, 12:06 AM   #1
rushdylan
Member#: 337170
2003 wrx
Default sti splitter to my wrx hood
maybe im just blind and half or 3/4 retarded but im having a hard time finding good info on this subject. the pop up "here are some similar threads we found" after you type the title in, ALMOST saved me a post but it didnt
let me start off by saying im putting a 2006 sti motor into my 2003 wrx. everything is figured out, except the splitter. will the sti splitter bolt to my wrx hood with small modification or none? i WANT to keep my wrx hood/scoop setup to make it a full sleeper. need to figure out before i buy it!
rushdylan is online now   Reply With Quote
Old 01-19-2013, 12:43 AM   #2
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Save money, take your splitter out, cut it and modify it to fit your hood scoop exactly, gives you the same results. Or you could buy a JDM sti splitter.
Old 01-19-2013, 01:08 AM   #3
rushdylan
Member#: 337170
2003 wrx
but i should purchase the sti sealing pieces correct?
Old 01-19-2013, 06:17 AM   #4
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
I installed an Sti tmic and kept my oem hood scoop on my wrx hood, and then combined 2 wrx splitters to make a custom splitter. Pop rivets are the bomb. Used garage door seal an foam blocks to seal. Took a long time and lots of handwork. pics:
mhoerath is offline   Reply With Quote
Old 01-19-2013, 02:26 PM   #5
SuperScubi
Member#: 233407
2004 Aspen White STi
DomTune380.5whp/415.8torq
An 06/07 splitter will not directly bolt onto your 02/03 WRX hood or fit into your hood scoop. Your better off buying a JDM hood scoop and splitter and having that paint matched. There's plenty of people running STi motors or STi tmic on their 02/03 and running the stock hood scoop and splitter. I'm sure you'll be fine...
SuperScubi is offline   Reply With Quote
Old 01-19-2013, 05:06 PM   #6
rushdylan
Member#: 337170
2003 wrx
hey good job!
Old 01-19-2013, 06:46 PM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 01-19-2013, 08:42 PM   #8
rushdylan
Member#: 337170
2003 wrx
Originally Posted by Unabomber View Post
thank you! I even user name searched you to find that and never found it!
Message Board Statistics All times are GMT -4. The time now is 11:22 AM.
